SoloDallas - Storm
Re: SoloDallas - Storm
Postby boby6kiler » 29 Oct 2019, 15:02
i have see the led arangement 10k led 2k if you look to the pcb you will see it is not exactly like this( but this is for the led)
c6 in the schematic is not polarized but if you look the pics you will find a 1uf polarized
the rest look ok but i have not finished all the verification i can see ^^
boby6kiler
Have thanks: 9 times
Postby aionios » 29 Oct 2019, 16:54
boby6kiler wrote:i have see the led arangement 10k led 2k if you look to the pcb you will see it is not exactly like this( but this is for the led)
My PCB is not a direct copy of the Storm - the bypass LED has been standardized compared to my other projects, and the 1uf polarized capacitors have been converted to non-polar since they are better and more reliable. (There's no good reason to use a 1uf polarized capacitor in the signal path unless you're trying to save money.)
Aion Electronics - DIY PCB projects for classic and obscure circuits
aionios
Have thanks: 139 times
Postby madras » 04 Nov 2019, 22:54
Can anybody confirm is aionios' schematic an actual SD Storm schematic? Some photos showin orignal Storm internals would be welcome. :)
madras
Postby aionios » 04 Nov 2019, 23:15
madras wrote:Can anybody confirm is aionios' schematic an actual SD Storm schematic? Some photos showin orignal Storm internals would be welcome. :)
Linked in the very first post - several angles of the populated PCB as well as front and back with components removed.
aionios
Postby madras » 04 Nov 2019, 23:32
Aah! I missed it the first time. I have just seen your photos. Looks legit, thank you very much!
madras
Postby dylan159 » 06 Nov 2019, 16:13
Isn't it silly that they kept the Zobel network at the output of the 386 even though this isn't directly driving a speaker? Well, unless you are, which is perfectly possible.
dylan159
Have thanks: 14 times
Postby foxey » 07 Nov 2019, 13:20
good boost!
But I prefer SVDS...
foxey
Users browsing this forum: MSN [Bot] and 93 guests
