Guyatone - TD-X Tube Echo (Flip Series)  [schematic]
Postby GuitarManiac32 » 12 Aug 2010, 16:52
Hi!
I promised to put the schematic here already some days ago, but didn´t have enough time. So, here it is... if there is a thread about this pedal, moderators could move the schematic there or something.
GuitarManiac32
Has thanked: 10 times
Re: Guyatone Tube Echo TD-X (Flip Series)
Postby Marko9801 » 02 Nov 2010, 10:25
Hi, I've just received this pedal, used... It obviously has a problem, the echo sound is clipping to the extreme... I don't mean the slight distorting of the delay signal that is normal, but simply clipping too loud...
When analog knob is anywhere over 0 it is distorting, but even "Tape" knob clips too much on the low E string...
What is most common for this problem? Faulty tube or should I return it today? I've tried with 2 different DC12V adaptors with the same clipping result... Please help, this pedal is too expensive too be this lousy sounding! :cry:
Marko9801
Postby Marko9801 » 18 Nov 2010, 14:44
Marko9801 wrote:Hi, I've just received this pedal, used... It obviously has a problem, the echo sound is clipping to the extreme... I don't mean the slight distorting of the delay signal that is normal, but simply clipping too loud...
Nevermind, it wasn't the pedal it was my 10W solid state amp... Played it on three other amps, tube amps, with no problem...
Marko9801
Re: Guyatone - TD-X Tube Echo (Flip Series)
Postby nyklus » 31 Dec 2012, 18:56
hello, can you repost this schematic? i can find it anywhere.
thanks
nyklus
Postby Fredenando » 31 Dec 2012, 21:30
Fredenando
Has thanked: 474 times
Have thanks: 92 times
Postby sadrew » 04 Jun 2013, 22:15
please repost?
sadrew
Have thanks: 15 times
Postby madmotoscooter » 21 Mar 2014, 21:45
Bump. Please re-post.
madmotoscooter
Postby Fredenando » 22 Mar 2014, 03:42
Fredenando
Postby Goldsoundz » 22 Mar 2014, 10:53
i love this pedal, but I get the repeats bleeding through to the bypassed clean signal when they're oscillating, and the indicated led starts to light up a bit. Any thoughts?
Goldsoundz
Postby Goldsoundz » 06 Dec 2016, 10:20
The schem and layout dont seem have component values. Also, does anyone know what the delay chip is in this thing (and any other delays that might use it)?
Goldsoundz
Postby toby2 » 07 Jan 2017, 13:25
Does anyone out there have a schematic for this pedal ? Someone used the wrong power supply on mine and fried a chip or a transistor . A schematic for this pedal would be really help in troubleshooting this old effector . Thanks for your time !
toby2
Users browsing this forum: No registered users and 6 guests
