Boss - BD-2 Blues Driver  [schematic]
Re: Boss - Blues Driver (BD-2)
Postby lespauldoc » 27 Dec 2014, 23:02
Well, as a lurker here for years, I hope I don't get blasted.
Did the Galaxie mod today as I've been screwing with EVERY BD mod and came to the conclusion i HATE the pedal. This mod is truly something different from all the other BD mods out there. I pulled the schematic because I want to fully understand what is happening. That crappy diode to ground crappy-clipping is gone, and smooth. Gain is 1/3 what the stock is (like you'll ever need that much?), and actually sounds bluesy. A bit too tight bass to my ears, but reminds me of a 2x10 cab. I prefer looser bass, so I may screw with fattening that up a touch-- like a 2x12 or so. :roll:
Overall, this turns the BD2 into an amp-simulated drive, like a good preamp. The transistors (all FETs? Gotta look) are sparkling and clean. The pedal is more of a dirty boost that really sings. "Splatty decay" is gone, for real. Every other mod I've tried that "splat" is minimized at best.
Oh, and I put a hot green LED for indicator in there--- can I change the resistor to make it super bright since I switched other resistors? :twisted:
Well done on the mod. I hope people actually hear about this one! :applause:
lespauldoc
Postby DrNomis » 28 Dec 2014, 07:12
The only mod I've made to my Blues Driver is to replace the original Red indicator Led with a Blue one, other than that mine's all stock standard, for me, I find that the Boss BD2 Blues Driver is a bit like the Ibanez TS9 Tube Screamer, although the circuits are completely different, the Blues Driver doesn't have the midrangey-ness of the Tube Screamer, I tried the British Blues sound settings as illustrated in the Blues Driver manual and found that I really like it, honestly to my ears I can't for the life of me hear the splatty note-decay that some say is evident in the Blues Driver sound, maybe I just happen to have one that doesn't suffer from that issue...I don't know...... :thumbsup
Has thanked: 123 times
Have thanks: 397 times
Postby JRM » 19 Feb 2015, 16:19
I might do the Galaxie mod to my BD-2. I liked what I've heatd on youtube and I agree that if you really want to change the pedal you've got to change (at least) the values of the components. Just upgrade components might reduce noise issues (GE-7 is a great example) or give some small improvements but don't change the sound. When I read Analogman statement: "This BD-2 mod does not drastically change the circuit, but replaces many cheap, poor sounding components that Boss used. This is similar to what the high-end home audio guys routinely do when they buy a piece of equipment - they spend a few hundred dollars putting in the EXPENSIVE capacitors which lets the true sound come through. We are also changing circuit values in several places to make the tone control more useable and less shrill high end" I started to think that his mod had a lot of snake oil added... I know a bunch of high-end home audio guys and they don't change caps for sure because their equipments already have excellent quality caps. But high-end audio is flooded with snake oil, being easy to find cables that retail over €5.000 and are just two wires and lot of engineering nonsense.
JRM
Postby latestsaint » 30 Jun 2015, 21:10
hey i know this was a while back, but i wanted to try this mod out...
one question tho. is this a typo? D6 does not look like it is even close to the clipping diodes. Did you mean D7?
new_anuzzerone wrote:D6, D8, D9, D10: 3mm red LEDs (I like water clear high brightness) These are clipping diodes. LEDs make the pedal fatter, tighter and more compressed. I also find they add some dynamics to the pedal. They also clip much less than a standard diode so more headroom!
latestsaint
Postby Keith_A » 01 Jul 2015, 22:30
JRM wrote:I might do the Galaxie mod to my BD-2. I liked what I've heatd on youtube and I agree that if you really want to change the pedal you've got to change (at least) the values of the components. Just upgrade components might reduce noise issues (GE-7 is a great example) or give some small improvements but don't change the sound.
I think there's definitely merit to using "upgraded" components for means of noise reduction and such, but the purpose of an overdrive is to add clipping. I think a lot of people get too anal about background noise, much of which is masked unless you are playing in your bedroom. Or people are intently listening to the background noise, because we've been sold on the issue that it's a problem. It's a fabricated problem.
There have been tests done on the negligible effect of distortion from capacitors or resistors, and how again, with a device intended to create clipping, that hearing those effects is what I refer to as being like seeing single snowflakes in a blizzard. Maybe you can catch one here or there, but so what?
I honestly don't know what would actually need "upgrading" in the BD-2 with just component swaps that are part-for-part the same values. Boss went with very good jFETs for it. The op amp stage is simply a post-volume mild bass boost. It doesn't have a wacked out Q or it would stick out like a sore thumb. For that reason alone, what is the need to replace the op amp? General purpose for this application is okay.
I can also honestly say that I've used all sorts of general purpose components in the BD-2 and haven't heard any performance differences. I've installed the Galaxie Mod using just the original types of Boss caps, or similar mylar types, and have also used ceramics similar to what Boss used, or have used those little multilayer jobs without issues. I've A/B'ed them with cheap/upgraded/mixed and hear no audible differences.
The BD-2 has a mostly crammed up PCB. I think it makes more sense to use components that will fit without problems. The box caps or metal film types are good simply because they have 5mm spacing that allows them to drop right in. But that said, there are cheaper alternatives that usually have 5mm spacing. The BD-2 also uses 1/8-watt resistors. There's no point in replacing them with 1/4-watt (unless that's all you have), since a chain is only as strong as its weakest link. You'd have to install them like they are done in a Tube Screamer, which means there's the possibility for something to short out or make contact where it shouldn't.
There's also a pair of ribbon cables in the BD-2 that I frequently see that someone has damaged. I think it most commonly happens when they are trying to sub out the op amp, or shotgun out all the electrolytic caps, because most of them are packed in that end of the PCB.
If someone wants to replace parts just for grins, I don't have a problem with that. Some people find it to be a good way to pass the time, I guess. I'd rather just focus on changing things that are going to have what is (hopefully) a positive AUDIBLE impact, and do no more or less.
For this message the author Keith_A has received thanks:
Bozo1996 (17 Mar 2017, 14:56)
Keith_A
Have thanks: 5 times
Re: Boss - BD-2 Blues Driver
Postby Bozo1996 » 16 Mar 2017, 04:44
I modified my Blues Driver so it could be used as a boost/overdrive/distortion for both bass and guitar. Here's my list of changes.
C8 - 10nF
C9 - 100nF
C10 - 68nF
C14 - replace with jumper wire
C16 - 3.3nF
C17 - 10nF
C19 - 39nF
C22 - 100nF
C26 - 1nF (slightly lowers high frequencies)
C36 - 100nF
C100 - 33nF
C101 - 100nF
R9 - 47k (increases opamp output volume and seems to increase headroom/gives the gain a fuller feel.)
R21 - 1k linear pot (mid contour control)
R26 - switch wired across the resistor in parallel (bright boost)
R27 - 6.8k (lowers minimum gain of 2nd gain stage)
R29 - 4.7k (lowers minimum gain of 1st gain stage)
R34 - 10k with 1k resistor on switch wired in parallel (gain cut/boost)
R37 - 220k
R51 - 20k linear pot (mid control)
D2 - mosfet clipper (gate tied to drain)
D3 - remove
D7 - germanium
D8 - LED
D9,D10 - replace with a single LED
Experiment with the diodes, they don't necessarily need to be exactly what I put in mine, they just need to clip asymmetrically. I probably will use a different diode configuration for each one I modify.
Bozo1996
Previous
Users browsing this forum: EdCh3n, Google [Bot], OneArmedTRex and 12 guests
