Radial - Bigshot Mix
Ripdivot
Been thanked: 78 times
Post by Ripdivot »
I was going to ask if anyone wanted to see gut shots, then I thought...of coarse we do! This pedal basically gives you a parallel effects loop on your pedal board. The case is rock solid and the build quality seems really good too. Here are the pics, one of them has all the cap values filled in as well as the semi conductors. I have this pedal on loan for about a week so if you have questions just ask.
