Mxr - Noise Gate / Line Driver
Re: Mxr - Noise Gate / Line Driver
Postby daniel.madeireira » 28 Mar 2014, 06:19
daniel.madeireira
Have thanks: 2 times
Postby andregarcia57 » 09 May 2014, 04:08
The scheme has found with some changes of errors in other schematic
someone gives him? is right?
thanks
andregarcia57
Have thanks: 87 times
Postby kdude34567 » 28 Apr 2016, 23:33
I know this post was some time ago, but I have an original 1978-1980 grey MXR NoiseGate that hasnt worked for years. I finally got around to repairing it & had some issues. Then I found this thread.
Long story short, is I got it working & it is gating. But I'm having the exact same problem as you guys had that discussed on pages 3 & 4 of this thread. It's where when the gate is engaged it's filtering down or squishing the incoming guitar signal & it's at 1/2 volume & distorted. When the gate is off, the guitar input signal is full level & proper.
It should be noted that I changed a few components on my stock pedal to those discussed in this thread. It wasn't working right before I changed the components & it started gating after I did. Does that mean the original MXR design has some flaws in it? Because the pedal never did work 100% correctly since the day I bought it back in the late '70s as a teenage rock guitarist. Anyways, here the components I changed:
1M --> 1.8K (between JFet gate & 150K)
22K --> 680 (between 5.1V Zener diode & Vcc)
680 --> 4.7K (between -IN of U1 or U1a going to gnd)
1uf --> 2.2uf (same as the 4.7K)
What did you guys finally come up with that fixed the issue?
Kdude
Lead Guitarist White Lie & Guitar Gods
Musical Instrument/Gear Aficionado, Collector,Trader, Restorer, Repairs
Product Manager/Application Engineer Electronic Security Industry
Techno Geek, Half-Baked Inventor, Wannabe Scientist
kdude34567
Postby ranko0537 » 15 Dec 2017, 15:05
kdude34567 wrote:22K --> 680 (between 5.1V Zener diode & Vcc)
I am figthing with this too, but I think that this resistor shouldn't be replaced. Try to leave it at 22k.
ranko0537
Users browsing this forum: Lani, Wtfever and 4 guests
