Mxr - Noise Gate / Line Driver
Re: Mxr - Noise Gate / Line Driver
Postby .Mike » 09 Nov 2008, 22:10
I have an 80s model block logo MXR Noise Gate / Line Driver.
I can take gutshots in about 1/2 hour if you want.
Mike
My website: America's Debate | My effects site: Just one more build...
.Mike
Have thanks: 32 times
Postby analogguru » 09 Nov 2008, 22:27
This would be very nice.
Have thanks: 116 times
Postby .Mike » 09 Nov 2008, 23:32
Sorry about the crummy lighting. It's dark out on the east coast, and my camera takes terrible flash photos.
http://www.americasdebate.org/MXR-NGLD/
I hope that helps!
Mike
.Mike
Postby analogguru » 09 Nov 2008, 23:57
Very good pictures.....
One picture frontal from the back of the XLR-jack (from inside the case) would make it perfect.
It appears to me that the violet wire is connected to pin 3 (middle lug) and the other 2 pins are connected together - but I am not 100% sure.
Postby .Mike » 10 Nov 2008, 00:10
Will do after dinner... :)
.Mike
Postby .Mike » 10 Nov 2008, 02:27
Added #9 - 13. Hopefully that covers what you need. If not, let me know. :)
.Mike
Postby borislavgajic » 10 Nov 2008, 16:10
:applause: thanks .Mike :thumbsup
borislavgajic
Has thanked: 140 times
Have thanks: 251 times
Postby analogguru » 10 Nov 2008, 16:58
Perfect !!!
With this I can finish the schematic in the next couple of days.
BTW, your unit appears to be from summer 1980, but I couldn´t find any difference to the script-versions.
thanks again,
Re: noise gate/supressor?
Postby andregarcia57 » 12 Jan 2009, 13:42
analogguru wrote:All schematics on the web concerning the MXR Noisegate are wrong including the one from tonepad. Referring to version 2 from 2003 (which I have on my HD):
- Input cap is in reality 10n input resistor 10k.
- The 10µ electrolytic between the 22k and the FET is drawn in the wrong direction - plus should be on the Fet-side.
- Output cap is 10µ instead of 1µ.
- the capacitor before Q2 in parallel to the 100k is a 10n instead of a 1µ.
The source of the FET is connected to U/2 and the drain to the 10µ electrolytic
I put up this tonepad pedal mxr noise gate, and he is not working correctly, you could post schematic correct?
I thank you for your contribution.
André
andregarcia57
Have thanks: 87 times
Postby HEAD » 12 Jan 2009, 21:56
Yeah, that would be great! Even more, if someone could make an updated/corrected layout for it (although there much better solutions out there - but all of them as far as I know are much more complicated) - which could be based up e.g. on the Tonepad layout. Since such simple noisegate projects are pretty rare out there.
Regards
HeAd
HEAD
Has thanked: 25 times
Have thanks: 43 times
Postby Nikifena » 17 Jan 2009, 15:52
Here it is.
Thanks analogguru!
For this message the author Nikifena has received thanks:
modman (01 Mar 2014, 14:09)
Nikifena
Have thanks: 34 times
Postby analogguru » 17 Jan 2009, 20:40
Input resistor is still the wrong value (1k) - should be 10k.
Input cap the same: the drawn 47nF is in the original unit only 10nF.
Output coupling cap the same: 1µF after the opamp should be 10µF to match the original unit.
For this message the author analogguru has received thanks:
modman (01 Mar 2014, 14:10)
Postby Nikifena » 18 Jan 2009, 00:17
^ hm, sorry.
I don't think, that 10k - 10nf and 1k - 47nf have a big difference. Also 47nf is better for bass responce (when bass guitar is using). Output cap can be between 1 and 10uF.
I make this noice gate, but I have one problem. When I play on low strings - A and E string I have some bad sound - like hrrrr or small overdrive.
I check everything with a scope. I have a clean signal after Q1, but after 22k between Q1 and next to fixed 10uf cap I have a scratched signal. I put 33pf between 1meg resistor in the feetback at IC1a, but this doesnt fix it. Also I change a few fets.
Any ideas how to get a clean signal at the output ?
Nikifena
Postby Güero 2.0 » 23 Jul 2009, 17:01
Hi, thanks to everyone that help me to build this unit.
I am use the actual layout and wiring for Line connector.
Güero 2.0
Have thanks: 25 times
Postby audioguy » 29 Jul 2009, 15:20
Güero 2.0 wrote:Hi, thanks to everyone that help me to build this unit.
Beautiful build! What layout did you use?
audioguy
Has thanked: 24 times
Have thanks: 6 times
Postby Güero 2.0 » 29 Jul 2009, 19:02
I used my own layout and the Tonepad schematic.
Güero 2.0
Postby audioguy » 29 Jul 2009, 20:10
Güero 2.0 wrote:
audioguy wrote:
Güero 2.0 wrote:I used my own layout and the Tonepad schematic.
Care to share? :P
audioguy
Postby slash555 » 21 Aug 2009, 15:43
layout please :D
a built one from tonepad layout bud it doesnt work. i really want noise gate :)
slash555
Postby ebuprofen » 09 Jan 2010, 20:26
Hi guys
Can anyone tell me how to add GATE LED to this circuit?
ebuprofen
Has thanked: 21 times
Have thanks: 12 times
Postby Brainbender » 25 Dec 2010, 21:00
I've found this:
Brainbender
Has thanked: 19 times
Users browsing this forum: 287m, clerveans and 10 guests
