MXR - Custom Badass '78 Distortion  [schematic]
Postby Nocaster » 11 May 2011, 02:19
The first in a line from the MXR Custom Badass design team, the MXR Custom Badass ’78 Distortion is a factory-modded pedal that roars with huge amp stack tones and old school tube amp-like distortion.
We took a classic distortion circuit and hot-rodded it to the next level for over-the-top soaring leads and rich, saturated rhythms. With only three knobs, dialing in Badass tone is a cinch. The CRUNCH button allows you to choose between two different modes of diode and LED clipping, boosting the harmonic content of the distortion.
The '78 Distortion's wide open amp-like sound sounds great whether it's in front of a clean amp, a slightly dirty amp, or a full on overdriven amp. Under the hood, this high performance machine features top notch circuitry and hardware meant for a lifetime of use.
Was curious as to what it was based on so I took the attached pics. Pedal sounds really good. Especially for $78 new.
IC = 2262C
I count 6 transistors.
For this message the author Nocaster has received thanks: 12
arayita (20 May 2011, 07:13), celadine (12 May 2011, 15:52), deltafred (26 Oct 2017, 20:04), george giblet (12 Aug 2019, 07:52), mcaviel (18 May 2011, 23:54), modman (27 Oct 2017, 10:54), phibes (11 May 2011, 15:46), reneshelle (11 May 2011, 21:24), sinner (25 Jan 2012, 21:00), x-tn (11 May 2011, 23:41) and 2 more users
Nocaster
Have thanks: 13 times
Re: MXR Custom Badass '78 Distortion
Postby Nocaster » 11 May 2011, 18:37
askwho69 wrote::applause:
Thanks. I am happy to provide values and more pics if someone is able to determine which classic circuit this is based on. 8)
Nocaster
Postby Steven_M » 11 May 2011, 18:58
Assuming that a couple of those transistors are probably for the switching on the LED, 4 transistors and an opamp? Does it sound at all like a Big Muff?
Wondering if maybe the opamp is an in/out buffer. Just a shot in the dark.
Steven_M
Has thanked: 71 times
Have thanks: 35 times
Postby Nocaster » 11 May 2011, 19:46
Steven_M wrote:Assuming that a couple of those transistors are probably for the switching on the LED, 4 transistors and an opamp? Does it sound at all like a Big Muff?
Not really. It has tons of high end and presence. Tone knob needs to be run around 10:00 to tame it. Doesn't sound big like a muff at all. There is a pair of 3mm red LED's in there for clipping. Before I opened it up, I was convinced it was based on the DS-1 based on how it sounded to me. The DS-1 came out in 1978.
I guess the opamp Big Muff came out in '77/'78 though, correct?
Here are a few videos of it for sound.
http://youtu.be/3MBwLhXWHt0
http://youtu.be/8XEtz8MwRTo
Nocaster
Postby Steven_M » 11 May 2011, 20:45
Yeah, that's too tight sounding to be a muff.
Steven_M
Postby Güero 2.0 » 12 May 2011, 00:32
Note that some of "transistors" could be diodes. They have the same enclosure.
Check the SMD code in the internet
Güero 2.0
Have thanks: 25 times
Postby ddpawel » 12 May 2011, 01:26
I bet that Badass '78 Distortion is really a modded version of Distortion+. Probably this one:
http://www.indyguitarist.com/temp/dist-plus-mod-406.gif
ddpawel
Have thanks: 12 times
Postby celadine » 12 May 2011, 16:01
Looks like everything is labelled, ¨Q1¨, etc. Connections should be easier to trace than most smd stuff, judging from the 1st few photos. Another Mr. Huge design?
celadine
Has thanked: 16 times
Have thanks: 16 times
Postby Rich_S » 16 May 2011, 18:15
I was thinking about picking one of these up on my next trip to the big city (next week), but would like to know more about what it is. If it's just a modded DS-1 implemented using SMD, I can save my money. I already have a modded DS-1, the final "keeper" after several different versions.
The Badass 78 is secksie, though.
Rich_S
Postby neoflox » 18 May 2011, 03:21
Yeah, any news on this? Is anyone working on a schematic? :scratch:
:popcorn:
neoflox
Have thanks: 2 times
Postby coldcraft » 18 May 2011, 05:44
the 2262 op amps sound pretty good distorting on their own actually.
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Postby Ice-9 » 27 May 2011, 00:09
Bump - Just wondering if you have managed to make a schematic yet ?
Ice-9
Has thanked: 143 times
Have thanks: 368 times
Postby houseofglass21 » 27 May 2011, 04:52
Don't have the schematic, but I bought one of these pedals tonight at GC. I A/B'd it with my old 1983 MIJ DS-1 and they sound almost identical except the MIJ DS-1 sounds better. Disappointing pedal. They basically came up with a way to sell a $20 DS-1 for $80.
houseofglass21
Have thanks: 5 times
Postby FiveseveN » 27 May 2011, 07:34
"Better?" Do tell. How so? "Better" in which what way?!
For this message the author FiveseveN has received thanks:
Satchmodog (13 Feb 2019, 18:59)
FiveseveN
Has thanked: 134 times
Have thanks: 55 times
Postby Rich_S » 27 May 2011, 14:42
MXR's own marketing materials state that the crunch switch selects between diode and LED clipping. It's the rest of the circuit I'm interested in... if it just a modded DS-1 I already have that covered and can spend my hard-earned gear $$$ on something else - like a greenback clone for my 18 Watter.
Rich_S
Postby benadrian » 27 May 2011, 18:45
A Dunlop rep told some people I know that it is essentially a Keeley-style modded DS-1 with a few more changes.
I was a bit disappolinted at first. however, a lot of people seem to dig the sound, and $80 for any good sounding pedal can't be a bad deal. It's no less valid to me than a personally-tuned FF clone for $150.
Cheers!
Ben
benadrian
Postby Rich_S » 27 May 2011, 20:27
I used to own a Keeley SEM/Ultra DS-1 and yeah... the clips I've heard of the 78 Badass sound like they're in the same ballpark. Good to know, since I can now skip it; I like my Allums Recto Mod DS-1 better.
Rich_S
Postby Ice-9 » 15 Jun 2011, 13:43
Ids anyone still interested in getting this one reversed ?
Ice-9
Postby ddpawel » 15 Jun 2011, 21:02
Ice-9 wrote:Ids anyone still interested in getting this one reversed ?
Of course.
ddpawel
Postby Nocaster » 16 Jun 2011, 19:32
Hey guys. I am the OP of the pics. Sorry I haven't been able to provide anything more than that. I'd be happy to take it apart again and list out all the values if you want. I'll admit that I have not gone down the road of trying to draw a schematic from a pedal before and I really don't have the time to attempt to do so right now. But if there is anything else I can provide (values, more pics, etc.), just ask. Sorry if this was a let down. I just thought the pics might have made it easily identifiable to the experts here! :mrgreen:
Nocaster
Next
Users browsing this forum: Google [Bot], holm and 9 guests
