Snarling Dogs - Erogenous Moan
Postby acdc518 » 07 Jul 2011, 01:13
Here are the guts to a cool volume pedal that can simulate a backwards guitar. Sorry about the picture quality my camera refuses to focuswhen i use the zoom.
Image Image Image
the IC chips say: U5: too small to read.
U3 and U4: HCF4016BE
W990A9735
Malaysia
U2: 4558D
JRC
7398B
U1: MC14013BCP
FOL9806
acdc518
Have thanks: 5 times
Re: Snarling Dogs: Erogenous Moan
Postby !@#$%^&* » 01 Nov 2011, 04:58
I would love to have schematic for this one w/ layout and soundclip :D
Postby RnFR » 01 Nov 2011, 06:05
do you have a macro setting on your camera? that usually helps a lot for gutshots.
Has thanked: 150 times
Have thanks: 174 times
Snarling Dog Erogenous Moan Pedal Issue
Postby Stevenrb718 » 13 Mar 2018, 20:40
I have a Snarling Dog Erogenous Moan Pedal where only the volume pedal side of the unit works. Clicking the switch to use the reverse side does nothing, no change in sound or LED lighting up. The wiring seems to be stock but I have nothing to compare it to, so I'm not sure. Any help on this would be greatly appreciated!
Stevenrb718
Re: Snarling Dog Erogenous Moan Pedal Issue
Postby dv8r601 » 13 Mar 2018, 21:56
Take good pics of the front and back of the pcb. The guys here are experts at pointing out dodgy solder joints and other faults.
dv8r601
Has thanked: 406 times
Have thanks: 21 times
Postby Stevenrb718 » 17 Apr 2018, 06:11
Here are some pics. Is there a way to test the switch firstly?
Stevenrb718
Re: Snarling Dogs - Erogenous Moan
Postby digi2t » 22 Apr 2018, 20:21
This is what I have so far. I'm working on the schematic.
No matter how many times I cut it, it`s STILL too short!
For this message the author digi2t has received thanks:
karul (23 Apr 2018, 01:48)
digi2t
Has thanked: 56 times
Have thanks: 356 times
Postby Aharonimacaroni » 31 Oct 2018, 20:46
I have one and love the enclosure,the pedal developed a click at the end of the run,I gave it a whirl and changed the volume pot side and the click was gone ,the original pots are sealed,the backwards tape effect sucks but I will try changing the pot and see how it goes.
Aharonimacaroni
Postby scoop » 02 Nov 2018, 19:44
thanks everyone for investigating this thing, I've always wanted to try it but never shell out for.
Aharonimacaroni wrote:I have one and love the enclosure,the pedal developed a click at the end of the run,I gave it a whirl and changed the volume pot side and the click was gone ,the original pots are sealed,the backwards tape effect sucks but I will try changing the pot and see how it goes.
I might be wrong I have never used this pedal but based on the description, I thought the "click" was an intended feature on the pedal
The Erogenous Moan is a volume/reverse volume pedal, and can be used as a straight volume pedal. Pushing the footpad causes the volume to swell. At the end of the sweep, the volume cuts off completely. Reversing the process, the volume kicks in, and swells again. At the top of the sweep, the volume cuts off with a simulated click of a guitar pick. The effect is haunting.
More than 23000 guitar effects pedals from 4000 brands:
http://www.effectsdatabase.com/model/sn ... genousmoan
scoop
Postby roseblood11 » 03 Nov 2018, 01:03
@digi2t: Did you finish the schematic?
roseblood11
Has thanked: 352 times
Have thanks: 310 times
Postby digi2t » 03 Nov 2018, 11:46
Yeah. Here's what I have. Didn't have time to validate it to the board trace tho, so you might want to check it yourself.
For this message the author digi2t has received thanks: 5
dv8r601 (05 Nov 2018, 18:32), FUZZZZzzzz (19 Nov 2018, 21:42), Manfred (05 Nov 2018, 08:17), MrFidget (18 Apr 2019, 04:02), roseblood11 (03 Nov 2018, 12:52)
digi2t
Postby Manfred » 30 Dec 2018, 18:06
I create this approximate PCB-Clone:
Ready to print PDF-files:
erogenousMoanComponentSide.pdf
erogenousMoanSolderSide.pdf
erogenousMoanSolderSideMirrored.pdf
SprintLayout6-file:
ErogenousMoan.zip
For this message the author Manfred has received thanks: 3
digi2t (12 Jan 2019, 22:34), karul (30 Dec 2018, 20:13), ozzy666 (30 Dec 2018, 21:52)
Manfred
Has thanked: 1009 times
Have thanks: 599 times
Users browsing this forum: No registered users and 10 guests
