Joyo - JF-05 Classic Chorus  [schematic]
Postby greeny23 » 02 Aug 2011, 07:23
Borrowed this thing from a friend of mine to look at. Having seen the guts of the joyo OD and ultimatedrive i was lead to believe they have pretty good workmanship.
Seems the classic chorus is the exception.
Offboard components?
Burnt soldering?
Maybe i just got a bad one, anyone got a comparison?
the toyroom effects guy.
"My Pedals Kicked Ass! Don't be Jealous Boutique Builders! My Pedals Had Tone! AND YOU KNOW IT! Go Buy the Same LOUSY shit!"- Ken.
For this message the author greeny23 has received thanks: 2
Dirk_Hendrik (02 Aug 2011, 21:15), raindog (03 Aug 2011, 08:37)
greeny23
Have thanks: 11 times
Re: Joyo Classic Chorus- looks like they dropped the ball!
Postby Lawnchair » 02 Aug 2011, 16:27
holy shit assembled by a 4 year old. Child labor laws damnit!
For this message the author Lawnchair has received thanks:
Lawnchair
Have thanks: 16 times
Postby Barcode » 02 Aug 2011, 16:42
The leads on the ICs are oxidized. It looks to me less like workmanship issues and more like someone did some damage.
For this message the author Barcode has received thanks:
Barcode
Have thanks: 35 times
Postby Ice-9 » 02 Aug 2011, 16:50
If you look on the other side of the board, right under where that reisitor is soldered you will see a place for a resistor which is missing. That looks like a repair and whoever did it was probs not able to replace the resistor on the component side so just soldered it to the back of the board. The brown markings around this solder joint is flux from the solder, just needs a clean.
For this message the author Ice-9 has received thanks:
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby Hides-His-Eyes » 02 Aug 2011, 17:30
I'm suspect too. The others we've seen were clearly wave soldered. You can't really cock that up.
For this message the author Hides-His-Eyes has received thanks:
Dirk_Hendrik (02 Aug 2011, 21:16)
Hides-His-Eyes
Has thanked: 53 times
Have thanks: 84 times
Postby Hides-His-Eyes » 02 Aug 2011, 17:34
That said, we're taking bets on whether that underside electro is to stop LFO tick or clock noise ;)
Hides-His-Eyes
Postby atreidesheir » 02 Aug 2011, 18:50
It looks like it has been exposed to salt water to me.
Perhaps in Pacific transport? Look at those pots. Looks relic'ed to me.
For this message the author atreidesheir has received thanks:
atreidesheir
Has thanked: 452 times
Have thanks: 43 times
Postby Steven_M » 02 Aug 2011, 19:49
Yeah, I think this is an anomaly. All the joyo's I have seen have only had three common problems:
1) Parts not flat against the board. (Cosmetic)
2) Switch wiring a little light on solder. (Easy Fix)
3) General dirt/detritus on the boards. (Not a deal breaker)
I've never seen flux residue/Oxidation on any of their other pedals, and I've seen inside a lot of Freekish Blues pedals!
For this message the author Steven_M has received thanks:
Steven_M
Has thanked: 71 times
Postby Dirk_Hendrik » 02 Aug 2011, 20:54
Steven_M wrote:Yeah, I think this is an anomaly. All the joyo's I have seen have only had three common problems:
+1.
Other than that that "salt water" is flux residue too. Boards not washed after wave soldering.
That resistor + flux junk may be a Joyo mod just as well. What are you're going to do when you find an error after a production run of a couple of thousands of pedals? You find a fix and hire a low paid soldering chick. Cleaning up flux is not really required (IPC J-std class 1 case) and takes much more time than soldering that one resistor.
Bottom line,
It might not be that good.... but it's bloody much better than the soldering in an average (wannabee) boohteek pedal (what is flux anyway?)
Has thanked: 255 times
Have thanks: 1025 times
Postby Steven_M » 02 Aug 2011, 21:19
Dirk_Hendrik wrote:
Bottom line,
Indeed! Compare the soldering on the backside of this board with ANY of the soldering mods on the Freekish Blues stuff. I know who I would rather have tinkering with my pedals: J. Wong!
Dirk_Hendrik (02 Aug 2011, 21:21)
Steven_M
Postby Dirk_Hendrik » 02 Aug 2011, 21:21
Steven_M wrote:
Dirk_Hendrik wrote:
Bottom line,
Uuuh,
You're implying FB being boohteek!? :scratch:
Postby Steven_M » 02 Aug 2011, 22:12
Dirk_Hendrik wrote:
Steven_M wrote:
Dirk_Hendrik wrote:
Bottom line,
Uuuh,
I'm implying that FB is Wannabe Boutique for sure, not Boutique, Boutique.
Dirk_Hendrik (03 Aug 2011, 06:44)
Steven_M
Re: Joyo Classic Chorus- looks like they dropped the ball!  [schematic]
Postby rocklander » 02 Aug 2011, 22:38
I want to post in this thread so that Dirk will thank me too.
For this message the author rocklander has received thanks: 12
CRBMoA (15 Feb 2012, 21:58), Dirk_Hendrik (03 Aug 2011, 06:44), distortion_gfx1 (06 Aug 2011, 04:33), Effectsiation (05 Aug 2011, 15:44), Hides-His-Eyes (17 Jan 2012, 12:17), mictester (03 Aug 2011, 04:04), oscarv77 (15 Feb 2012, 09:52), reneshelle (03 Aug 2011, 06:58), roseblood11 (15 Feb 2012, 15:24), Steven_M (02 Aug 2011, 23:25) and 2 more users
rocklander
Has thanked: 1580 times
Have thanks: 289 times
Postby greeny23 » 02 Aug 2011, 23:13
a little update-
both underside components are running in parallel to resistors.. not replacements. the resistor missing is just plain missing.. the pedal is brand new from the factory.
man these guys confuse me!
greeny23
Postby ZombusWoof » 03 Aug 2011, 02:51
I modded an ultimate overdrive that had a capacitor (I think it was C5) that had a lifted/broken trace. The factory had done the same thing and stuck it through the reverse side and soldered it that way. I'm on my phone now but will post a pic when I get to my computer. I was shocked when I saw it because the other ones I saw online were clean.
ZombusWoof
Postby rocklander » 04 Aug 2011, 01:48
I've never felt so loved.. aww shucks..thanks all y'all... as you were..
For this message the author rocklander has received thanks: 2
Barcode (05 Aug 2011, 05:50), oscarv77 (15 Feb 2012, 09:52)
rocklander
Postby quaternotetriplet » 17 Jan 2012, 10:48
is this a CE2 clone?
quaternotetriplet
Has thanked: 10 times
Have thanks: 4 times
Postby Scruffie » 17 Jan 2012, 12:11
quaternotetriplet wrote:is this a CE2 clone?
One too many ICs and trimmers to be a one to one. The Biyang is though.
No clue what the BBDs is here either, can't tell from the photo if it's 3007 or 3207.
For this message the author Scruffie has received thanks:
quaternotetriplet (06 Apr 2012, 11:37)
Scruffie
Has thanked: 27 times
Have thanks: 139 times
Postby Seiche » 15 Feb 2012, 04:25
rocklander wrote:I want to post in this thread so that Dirk will thank me too.
omg you get thank yous for every little shit you say around here. i try too hard. :scratch: :blackeye :thumbsup
For this message the author Seiche has received thanks: 3
CHEEZOR (15 Feb 2012, 05:10), CRBMoA (15 Feb 2012, 21:59), rocklander (15 Feb 2012, 04:44)
Seiche
Has thanked: 251 times
Have thanks: 206 times
Postby HerrDoktor » 25 May 2012, 20:01
in the past days I received this pedal.
It seems more bright and it's my first chorus pedal, so I don't know, if is an issue or normal.
Today I've opened the pedal and this is a pic:
I thought it was a clone of BOSS CE-2 like wrote in this forum, but it seems different.
Some of you have the schematic?
For this message the author HerrDoktor has received thanks:
rocklander (22 Nov 2013, 00:30)
HerrDoktor
Next
Users browsing this forum: Bing [Bot] and 5 guests
