Tech21 - Sansamp Bass Driver  [schematic]
Postby darmstat » 05 Sep 2011, 14:49
Does anyonr have a service manual for the Tech21 Sansamp bass driver di pedal?
darmstat
Have thanks: 43 times
Re: Service manual for tech21 sansamp bass driver
Postby bajaman » 05 Sep 2011, 21:55
never seen any service documentation from Tech 21 :roll: :roll:
Behringer BDI21 is VERY similar circuit wise :wink: :wink:
Has thanked: 448 times
Have thanks: 1536 times
Re: Service manual for tech21 sansamp bass driver  [schematic]
Postby mozwell » 06 Sep 2011, 00:08
found this in my travels
mozwell
Has thanked: 22 times
Have thanks: 69 times
Postby bajaman » 06 Sep 2011, 01:41
yep - that's the Behringer - just replace IC2 with a TLC2264 and you are 99% there :wink:
modman (04 May 2015, 22:10)
Postby darmstat » 06 Sep 2011, 04:03
Thanks alot gentlemen. :lol:
darmstat
Postby skylark44 » 06 Jan 2012, 00:48
bajaman wrote:yep - that's the Behringer - just replace IC2 with a TLC2264 and you are 99% there :wink:
That's really helpfull...which one is "IC2", and where would I put clipping diodes, for mor distortion from the "drive" control? (sorry for the nOOb questions, I'm prety new to modding prdals :scratch: :| :oops: ) :mrgreen:
skylark44
Have thanks: 5 times
Postby mozwell » 11 Jan 2012, 06:24
IC2 is called U2 on the schematic.
You dont need clipping diodes, the sound of the TLC2264 is what you are after
For this message the author mozwell has received thanks:
mozwell
Re: Tech21 - Sansamp Bass Driver
Postby Leito79 » 22 Jan 2018, 19:30
First of all sorry about the necrothread... does anyone figured out how the Ground lift and line/inst switches work? I´ve built it and it works great, but i´ll like to have those 3 switches options. Had the chance to compare it to my bass player´s Original Tech 21 Bass Driver, going direct to a mixing console and using the XLR output (each pedal used a different desk channel, exact same settings, being switched with an A/B box to try to make the comparaison as neutral as possible), and with all pots at maximum, the original is way hissier/noisier than my build!!! I´ve used 1% MF resistors and Bipolar electrolytics for the 2.2uf coupling caps, maybe that´s the reason why is quieter. Also used plain vanilla TL072 & 74, they sound pretty close and with a less scooped feel, anyway I have sockets so I will try the TLCs. My build´s output level is definitely instrument level, compared to the original. I´ll like to add the switch to get LINE level, the volume difference is huge and very useful when going direct to a PA or mixing board, I believe the difference is 0dB vs -10dB, any thoughts on how to achieve this? Thanks!
Leito79
Users browsing this forum: Arnostuck and 7 guests
