EHX - Micro Synth XO Version  [schematic]
Re: EH Microsynth, new XO version
Postby Gila_Crisis » 10 Sep 2008, 14:03
i tryed one, once i went to jam with another guitarrist who had it. well it sounds cool like the original
Gila_Crisis
Have thanks: 68 times
Postby theehman » 10 Sep 2008, 15:45
Thanks for the pics! The use of the LM13700 really makes for a smaller size. I'll have to pick up one of these soon.
Ron Neely II
fx schematics and repairs
theehman
Has thanked: 83 times
Have thanks: 85 times
Postby analogguru » 10 Sep 2008, 19:58
Looks cool.... I think that some people in little chinatown could have had a lot of work with it.
Note the Piher-Trimmer-clone: Made in Taiwan.
Have thanks: 116 times
Postby Bernardduur » 10 Sep 2008, 21:30
Hmmmm, now the guitar and bass version differs on 6 points from each other
Bernardduur
Has thanked: 87 times
Have thanks: 484 times
Postby Silent Fly » 11 Sep 2008, 22:45
Bernardduur wrote:Hmmmm, now the guitar and bass version differs on 6 points from each other
I sent an email to EHX a while ago asking what are differences between the guitar and the bass version and they told me that if I play guitar and bass I can use just the bass version.
According to EHX, the bass version can track guitar but the guitar version cannot track guitar. Moreover, some guitar players prefer the bass version because of the deeper sound. Apart from these two point, there are not noticeable functional differences.
Silent Fly
Has thanked: 20 times
Have thanks: 38 times
Postby drfrankq » 13 Sep 2008, 08:11
did they take off the gate found in the previous reissue? liked it alot but not the gate
I picked up a vintage one that sounds great with not gate, but seems to be a noticeable AC hum with fuzz after it, could be why they added the gate, what do you guys think? Anyone try to get rid of the hum? Thanks!
drfrankq
Postby Bernardduur » 13 Sep 2008, 08:49
I dunno; the tracking of the guitar on the bass version was OK but not complete. And the trigger function worked different for the guitar (I couldn't get some to trigger the bass function). When playing bass over the guitar version the tracking ends on the B on the A string. It'll track but there is a serious lag between note played and note heard; a lag of about 3 seconds :)
Bernardduur
Postby Silent Fly » 13 Sep 2008, 09:34
Bernardduur wrote:I dunno; the tracking of the guitar on the bass version was OK but not complete. And the trigger function worked different for the guitar (I couldn't get some to trigger the bass function). When playing bass over the guitar version the tracking ends on the B on the A string. It'll track but there is a serious lag between note played and note heard; a lag of about 3 seconds :)
What do you mean by "the tracking of the guitar on the bass version was OK but not complete"?
The higher (pitch-wise) notes of the guitar were not tracked?
Silent Fly
Postby Bernardduur » 13 Sep 2008, 15:58
Whahaha, I sometimes write weird things I guess
And that was exactly what I meant. I had no lag but the tracking was way off! That is why I added a switch to mine to switch between the 2 versions.
Bernardduur
Postby JiM » 14 Sep 2008, 01:09
Great pictures ! One can almost trace it ;-)
Unfortunately, there's still no expression pedal option :(
I like the small "prototype area" next to the input jack : meant to be modded ?
If you're buying one, I'd suggest to get the bass version, as 5 out of the 6 resistor values that differ are higher on the bass version : you could then dip-switch some parallel resistors to get the guitar version as well.
JiM
Has thanked: 30 times
Have thanks: 37 times
EHX - Micro Synth XO series
Postby nothingmaker » 03 Oct 2011, 08:24
Hi, I’ve bought a new Micro Synth XO series.
I notice the problem of sustain loss, that was not in the vintage version.
When I play a note, after 3-4 seconds, the effect goes down with no sustain. With each voice there is the problem, after that time the effect disappears, and the volume goes down.
There is a way to mod the pedal? Or insert a squelch regulation?
I'd like to reach the sustain of the old version.
Thank you so much
nothingmaker
Re: EHX Micro Synth XO series
Postby Sweetalk » 15 Oct 2011, 15:08
Did you adjusted the gain trimpot?. I had both, XO and the old version, the old is simply better but is big as hell!!.
Sweetalk
Has thanked: 23 times
Have thanks: 17 times
Postby lufox15 » 18 Oct 2011, 15:39
HI!!!!! everyone, i have a piece of the Micro Synth XO Version Schematic that i draw seeing a pictures on other topic on this forum, but now I have some problems with some stages (Sub-Octave that it's diferent, Attack Delay Stage) that i can't see on the pictures and MAYBE someone who have this pedal could help me :D , completing this schematic then when I'll have free days on december i could make a new little PCB using just LM13700 and not the expensive CA3094.
HELP ME PLEASE! AND THEN WE'LL have a nice topic about the new version of this amazing pedal!!!!!!! :o
with 9v normal supply and not expensive.
Cheers.
The Schematic.
microsynthxo.pdf
PD: I'm not sure if there are problem using normal components and not the SMD that uses the XO Version, could make a difference? (capacitors, resistors, transistors???) someone who answers this question? or make suggestions and corrections of the schematic or thread? :D :D :D maybe this topic must be on another board on the forum?
lufox15
Re: Micro Synth XO Version EHX (half-schematic)
Postby lufox15 » 16 Nov 2011, 01:42
someone?!
lufox15
Postby Liquids » 13 Dec 2011, 19:10
Normal through hole components will work fine if the circuit is the same, just larger.
Liquids
Has thanked: 15 times
Have thanks: 24 times
Postby lufox15 » 11 Jan 2012, 15:31
thanks for the data Liquids :) .
But there is nobody that could help to conclude the schematic.
lufox15
Postby bratpilot » 04 Mar 2012, 14:09
pieces of the scheme look very similar to the original scheme of the old version.
You could finish the circuit complete?
bratpilot
Postby rtstef » 14 Mar 2012, 10:21
Hi everybody,
My name is stephane, from France, 30y old, guitarist/bassist player since the end of 90's.
I really need a synth pedal for bass, but no money for a good one :cry:
I've build 3 pedals (fuzz, phaser and overdrive), 1 amp (nano head) and a copy of irig.
I don't have any knowledge in electronic, but I really want to build a micro synth, !XO model! (ca3094 is very expensive to buy from my country. About 30€ in my near elec shop :scratch: )
So, someone have try to build it?
Diagram is finally complete? (i've seen pics of new µsynth have disappear from forum... EHX initiative?)
A good replacement for ca3094 (with update schematic for µsynth please!)
Thanks all,
and VERY thanks to this forum.
Stephane
rtstef
Postby Dirk_Hendrik » 14 Mar 2012, 11:56
Stephane,
viewtopic.php?f=13&t=7502&hilit=microsynth
And buy parts online. Not in your local shop. Saves a fortune.
Has thanked: 253 times
Have thanks: 1015 times
Next
Users browsing this forum: No registered users and 6 guests
