Harley Benton - Ultimate Drive (by Joyo)  [schematic]
Postby raindog » 29 Oct 2011, 12:41
phrikish-alfa-bluezzin'-drv...
For this message the author raindog has received thanks: 2
floris (26 Oct 2013, 13:22), Fredenando (29 Oct 2011, 14:39)
raindog
Has thanked: 47 times
Have thanks: 138 times
Joyo ultimate drive difference between v1 and v2
Postby Kaptenkork » 23 Feb 2012, 22:04
Is here anyone who knows if there is any difference between v1 and v2 beside the layout.
(hope this is the right section to ask)
Kaptenkork
Re: Harley Benton - Ultimate Drive (by Joyo)
Postby Dave_Mc » 25 Feb 2012, 21:17
^ I have a joyo branded UD, and also a harley benton-branded one from thomann, and the harley benton one has a lot more level on tap, and more gain, too. (Don't quote me on that, though, because I don't think I've ever run them head to head as I have them on separate boards... but that's the feeling I get, anyway. I certainly have the knobs set at completely different positions to achieve a broadly similar tone.)
Whether or not that's because of the different versions, or whether the harley benton ones aren't exactly the same, I don't know (I'm no electronics buff, I just lurk here to make sure I'm not getting ripped off :D )
Dave_Mc
Postby Dave_Mc » 25 Feb 2012, 21:19
ah, is there no way to edit posts here? :oops: Apologies if there is and I missed it. I was just going to say, I think the harley benton one is a little brighter, too.
Dave_Mc
Postby guitarmongot » 25 Feb 2012, 21:53
I have a Joyo UD V.2 .There is a "anti-pop" circuit a la Fulltone OCD v4 and I dont
think v1 has that circuit.It´s on the bottom of the board.
/cheers M
For this message the author guitarmongot has received thanks:
UKGreg (29 Sep 2013, 12:26)
guitarmongot
Has thanked: 23 times
Have thanks: 10 times
Postby Seiche » 26 Feb 2012, 17:53
guitarmongot wrote:There is a "anti-pop" circuit a la Fulltone OCD v4
how does that work? does the v1 pop?
Seiche
Has thanked: 264 times
Have thanks: 214 times
Postby guitarmongot » 26 Feb 2012, 19:35
Direct from Fulltone homesite :
"Q: The OCD has the brightest LED I've ever seen, it lights up my entire pedalboard, but there is NO POPPING sound like on my other booteek effects...is the OCD true bypass?
A: Yes it is true bypass, and thanks for noticing the "no pop thing." I invented an active anti-pop circuit (not simply resistors to ground ;) that eliminates almost all the snap, thump, and pop you're used to getting at higher volumes with true bypass pedals."
you could see the schematic upper right on OCD schematic.
/cheers M
Seiche (26 Feb 2012, 20:02)
guitarmongot
Postby Ice-9 » 26 Feb 2012, 20:13
The Reverse polarity protection is a bit over the top. It should have one or the other D1 makes D2 redundant. Not a biggy but it shows a lack of understanding.
Ice-9
Has thanked: 143 times
Have thanks: 368 times
Postby AAntonio » 17 Aug 2013, 08:32
guitarmongot wrote:Direct from Fulltone homesite :
/cheers M
hello
I would like to try your antipop,
I can connect it to the classic truebypass?,
how?
thank you very much
AAntonio
Has thanked: 21 times
Have thanks: 15 times
Postby UKGreg » 29 Sep 2013, 14:47
Total noob in need of assistance if anyone can help?
I have a V2 of the Ultimate Drive, the foot switch of which exploded on stage recently. I'd like to simply snip off the mini PCB which comes off the main board and wire up my replacement switch and an LED.
SO, are any of you knowledgeable guys able to jot down some guidance on which wires go where please?
Any assistance gratefully received. Thanks in advance.
Greg
UKGreg
Users browsing this forum: No registered users and 17 guests
