AMT Electronics - S1 Legend series  [schematic]
Re: AMT S1 Legend series [gut shots]
Postby Ice-9 » 30 Jan 2012, 00:59
Here is an updated schematic to look over, I have tidied it up a bit so it is more accurate. There is still a couple of things to add to the schematic but this is the main audio path not including the cab sim.
R40 is a trim pot that has the centre pin connected to the power rail and one wiper end connects to R18 to the Drain of VT7, the other wiper end goes to a voltage divider to bias VT2. VT2 goes of to the cab sim circuit which I will look at next.
AMT S1 legend ver 1 schematic below.
For this message the author Ice-9 has received thanks: 4
modman (27 May 2012, 11:15), PmCimini (20 Jan 2014, 05:47), Pruttelherrie (30 Jan 2012, 11:21), roseblood11 (30 Jan 2012, 01:29)
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby Ice-9 » 30 Jan 2012, 01:06
Ice-9 wrote:Here is an updated schematic to look over, I have tidied it up a bit so it is more accurate. There is still a couple of things to add to the schematic but this is the main audio path not including the cab sim.
Sorry typo above , where i say R40 highlighted in red it's meant to read R13
Ice-9
Postby Ice-9 » 30 Jan 2012, 21:21
Here is the final schematic of the AMT S1 legend, all fets in the schematic are 2SK208-R (Thanks for the info from KMG and help from marshmellow on this)I have left out the bypass and LED indicator along with the cab sim from the schematic. I have traced out the cab sim so if anyone would like to see it or check it i can post that.
Most component values are in the schematic although there are some cap values missing, when I can I will measure them with a meter and post the complete component list.
AMT S1 Schematic.
For this message the author Ice-9 has received thanks: 7
bossman (05 May 2012, 17:46), darthoverdrive (31 Jan 2012, 13:49), erikm5150 (01 Feb 2012, 00:20), jymaze (31 Jan 2012, 14:12), Mbas974 (31 Jan 2012, 12:26), modman (27 May 2012, 11:16), roseblood11 (31 Jan 2012, 05:47)
Ice-9
Postby Mbas974 » 31 Jan 2012, 12:30
Great job man !!
is it made with Eagle cad ? If so... any chance to get schematic file ( .sch ) file too ?
Now..... it's time to understand the difference with other Legend pedals :horsey: I think it will be just a cap and resitor values matter.
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Postby jymaze » 31 Jan 2012, 14:13
Thanks a lot for that schematic!
I would be interested in the cab sim portion of it. And I am sure I am not the only one!
jymaze
Has thanked: 87 times
Have thanks: 161 times
Postby Ihunda » 31 Jan 2012, 16:25
Thanks, thanks, thanks!
I am also looking forward to the cab sim part!
It it a simple 5Khz low pass or not ;) ?
Ihunda
Has thanked: 51 times
Have thanks: 11 times
Postby Ice-9 » 01 Feb 2012, 22:18
Mbas974 wrote:Great job man !!
I have made the schematic with Diptrace. :secret: Download the free version of diptrace though and I will post the schematic file for you.
Ice-9
Postby Ice-9 » 01 Feb 2012, 22:19
Ihunda wrote:Thanks, thanks, thanks!
there is a little more to it, but it is an active filter, I have made a mistake in tracing the sim cab so will have to check it before posting. :scratch:
gelryos (16 Jul 2012, 01:51)
Ice-9
Postby roseblood11 » 01 Feb 2012, 23:26
Is it the version that he describes on the website?
http://www.amtelectronics.com/support/a ... tor_kempf/
For this message the author roseblood11 has received thanks:
Ice-9 (02 Feb 2012, 00:11)
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby Ice-9 » 02 Feb 2012, 00:11
roseblood11 wrote:Is it the version that he describes on the website?
It has some similarities but is not as complex as the website version. That link will help in finishing the trace though.
Ice-9
Re: AMT S1 Legend series [gut shots]  [schematic]
Postby Ice-9 » 20 Feb 2012, 21:45
I finally got back to this one to finish the cab sim part of the circuit.
Here is the complete schematic for the full pedal inc cabsim, the input signal to the cab sim is taken from the output jack of the effect.
For this message the author Ice-9 has received thanks: 12
darthoverdrive (27 Mar 2012, 17:42), Deny (30 Jun 2012, 12:42), Ihunda (22 Feb 2012, 17:14), IvIark (24 Mar 2012, 15:08), jymaze (21 Feb 2012, 15:28), modman (27 May 2012, 11:16), papasaurus84 (20 Jul 2012, 08:47), Pruttelherrie (23 Mar 2012, 22:30), rcustoms (24 Mar 2012, 04:25), sigmadelta (22 Feb 2012, 22:57) and 2 more users
Ice-9
Postby J0K3RX » 21 Mar 2012, 21:46
Anybody build one of these?
J0K3RX
Has thanked: 321 times
Have thanks: 492 times
Postby Ice-9 » 21 Mar 2012, 22:42
J0K3RX wrote:Anybody build one of these?
I got the 2sk208's and the bat54's but haven't had a chance to build it yet , but the schematic has been checked and retraced about 4 times so can say it's verified schematic wise but not built. Those components only seem to be available as smd parts though.
Ice-9
Re: AMT B1 Legend series [gut shots]
Postby lugburz2000 » 23 Mar 2012, 18:41
Hi
I have an Amt B1 pedal and here are some Pics
For this message the author lugburz2000 has received thanks: 2
Ice-9 (23 Mar 2012, 19:41), modman (27 May 2012, 11:16)
lugburz2000
Have thanks: 16 times
Postby lugburz2000 » 23 Mar 2012, 18:49
and here is the schematic, without Cabinet simulation, and with DC Measurements :
For this message the author lugburz2000 has received thanks: 6
BuryMeInSmoke (18 Sep 2013, 00:10), Ice-9 (23 Mar 2012, 19:39), Ihunda (23 Mar 2012, 19:16), IvIark (31 Mar 2012, 01:44), modman (27 May 2012, 11:17), Pruttelherrie (23 Mar 2012, 22:29)
lugburz2000
Postby lugburz2000 » 23 Mar 2012, 19:14
sorry for subject in previous message.. is not S1 schematic but B1
perhaps it would have been more correct to have open new thread.
sorry.
lugburz2000
Postby lugburz2000 » 23 Mar 2012, 19:41
On Pcb pictures "bottom 01" and "bottom 02" you can see a yellow wire bridging a track.
This is because when i was desoldering components to better following the circuit for drawing
the schematic, then i accidentally burnt off one solder pad.
lugburz2000
Postby Ice-9 » 23 Mar 2012, 19:45
lugburz2000 wrote:On Pcb pictures "bottom 01" and "bottom 02" you can see a yellow wire bridging a track.
Thanks for posting the B1 schematic, I also have a P1 and the circuit board is the same as for the B1 except that all the missing components on the B1 pcb are soldered in place on the P1. So it's basically the same circuit with more gain stages in there, and probs some different value comonents as well.
Ice-9
Postby Sikor » 27 Mar 2012, 16:34
A little bit OT:
AMT has just presented new series of amp-simulation pedals.
They have extended the range of simulated amps to 10 or so :)
And all of them have been revoiced and are using the same "technology" as their new SS amp.
I have made some pictures at Musikmesse (no guts shots yet ;))
Practice cures most tone issues - John Suhr
My Musikmesse 2012 gallery and more...
For this message the author Sikor has received thanks:
Ice-9 (27 Mar 2012, 23:08)
Sikor
Have thanks: 8 times
Postby Ice-9 » 27 Mar 2012, 23:15
Thanks Sikor for the pics, can't wait to see some of the gut shots of these. :wink: Mm 2 chanl clean/dirty preamps in a pedal size. I just love the stuff AMT are doing.
Ice-9
PreviousNext
Users browsing this forum: spoontex and 12 guests
