AMT Electronics - S1 Legend series  [schematic]
Re: AMT Electronics - S1 Legend series
Postby Ice-9 » 13 Jul 2018, 17:59
Great, I can measure those for you, it will have to be tomorrow though as I am working tonight.
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby temol » 13 Jul 2018, 20:33
That's great. I'm waiting patiently.
Meanwhile - short comparison of three 5150's. VST sim, 5150 by TrueVAL and AMT P1 on a breadboard. Separate recordings for L and R, Marshall cab IR. Soundcloud link.
T.
temol
Have thanks: 127 times
Postby temol » 14 Jul 2018, 07:11
Ice-9 - can you also check the diode D7/VD6, the one next to VT10? Is it BAT54 or 1N4148?
T.
temol
Postby Ice-9 » 14 Jul 2018, 14:37
temol wrote:Ice-9 - can you also check the diode D7/VD6, the one next to VT10? Is it BAT54 or 1N4148?
T.
I have taken measurements for VT1-VT10 as they are marked on the original AMT P1 PCB.
First though VD6 is a small Glass SMD type diode with no visible markings which I can't remove as it has been glues to the PCB before solder flowing. Educated guess is that it is NOT a BAT54 as there would be no reason to fit this type of package diode when all other BAT54's are SOT-23.
PSU VOLTAGE READING on pcb = 9.46V
VT1 Gate =1.76V , Drain =9.32V Source = 2.1V
VT2 Gate =3.55V , Drain =9.32V Source = 4.8V
VT3 Gate = 0V , Drain =1.77v Source = 0v this jfet may be part of the psu switching for the cab sim ? (i really can't remember and haven't time to trace it out)
VT4 Gate =3.7mV , Drain =5.41V Source = 200mV
VT5 Gate =51mV , Drain =7.36V Source = 360mV
VT6 Gate =52mvV , Drain =4.92V Source = 223mV
VT7 Gate =12mV , Drain =4.98V Source = 183mV
VT8 Gate =33.2mV , Drain =5.39V Source = 240mV
VT9 Gate =0V , Drain =1.45V Source = 5.09V
Hope this helps for now, any questions or checks you want to make just let me know.
VT10 Gate =0V , Drain =3.72V Source = 53.5mV
Ice-9
Postby Ice-9 » 14 Jul 2018, 14:42
Just to clarify, VT3 is not the cab sim PSU switching device as that is only on the AMT 2 series pedals, VT3 looks like part of the actual cab sim.
Ice-9
Postby temol » 14 Jul 2018, 21:58
Ice-9 wrote:First though VD6 is a small Glass SMD type diode with no visible markings which I can't remove as it has been glues to the PCB before solder flowing. Educated guess is that it is NOT a BAT54 as there would be no reason to fit this type of package diode when all other BAT54's are SOT-23.
I've tried BAT85 and 1N4148. With BAT85 output signal is a bit lower, and drain voltage drops about 0.2 - 0.3V. With 1N4148 or without any diode - I could not hear any difference.
Ice-9 wrote:VT1 Gate =1.76V , Drain =9.32V Source = 2.1V
My voltage readings are not much different. Sometimes 0.3V off.. sometimes 0.5V off. The biggest difference - VT5, 7.36V vs 6,3V. It sounds even better after fine tuning some resistor values.
And (I hope ) last question: R45 on this schematic is before C29. In this configuration the pedal is too bassy. I had to set bass pot almost to zero to get rid of thumping lows. With R45 after C29 it ok. I've checked some photos of AMT series pcb's - looks like the resistor is after the capacitor (like on this schematic).
T.
temol
Postby Ice-9 » 14 Jul 2018, 22:35
I would say R45 after C29 should be correct, ie C29 directly to treble pot wiper
Ice-9
Postby temol » 15 Jul 2018, 09:33
Thank you very much for your help.
T.
temol
Postby temol » 16 Aug 2018, 23:19
Here's my P1.
T.
For this message the author temol has received thanks: 4
bajaman (17 Aug 2018, 04:01), bmxguitarsbmx (17 Aug 2018, 21:59), Ice-9 (17 Aug 2018, 20:49), zzztop (29 Sep 2018, 11:21)
temol
Postby mensur » 17 Aug 2018, 15:39
How does it sounds, can you make any clips?
mensur
Have thanks: 27 times
Postby temol » 19 Aug 2018, 23:16
mensur wrote:can you make any clips?
Sure. Soon.. :)
T.
temol
Postby blacky » 12 Feb 2019, 15:58
temol wrote:Here's my P1.
[ Image ][ Image ]
T.
Hi man I'm new here but this is looking amazing, great work, how does it sound?
blacky
Previous
Users browsing this forum: No registered users and 10 guests
