List of Joyo Pedal Clones
Re: List of Joyo Pedal Clones
Postby atreidesheir » 06 Nov 2012, 03:58
opened a joyo tremolo for a friend. The trimpot just beneath the rate pot is maxed and gets close to unity gain. You can bend the guard on the trimpot and turn the trimmer up just a bit more and makes the pedal a real winner.
read about this on tdpri and can confirm it is a great little move to make for this great pedal.
atreidesheir
Has thanked: 452 times
Have thanks: 43 times
Postby analogguru » 11 Nov 2012, 05:06
Joyo Classic Chorus = Ibanez CS 9 (in mono)
For this message the author analogguru has received thanks: 2
atreidesheir (11 Nov 2012, 21:48), rocklander (11 Nov 2012, 05:53)
Have thanks: 116 times
Postby atreidesheir » 11 Nov 2012, 21:49
analogguru wrote:Joyo Classic Chorus = Ibanez CS 9 (in mono)
close enough for rocknroll :applause:
atreidesheir
Postby Dave_Mc » 11 Nov 2012, 22:22
cs9? interesting. my chorus is about the only one of the joyos i have that I don't like so much- i mean, it's alright, and for the price it's hard to complain, but it's a bit noisy and a little thin-sounding. my tonerider chorus (i think it's based on a ce2, but don't think it's an exact clone) sounds a lot richer (and has no noise).
Dave_Mc
Postby analogguru » 11 Nov 2012, 23:22
Joyo Tremolo (JF-09) = Fulltone Supa-Trem =~ Demeter Tremulator
atreidesheir (12 Nov 2012, 01:55), rocklander (11 Nov 2012, 23:41)
Postby atreidesheir » 12 Nov 2012, 02:11
Dave_Mc wrote:cs9? interesting. my chorus is about the only one of the joyos i have that I don't like so much- i mean, it's alright, and for the price it's hard to complain, but it's a bit noisy and a little thin-sounding. my tonerider chorus (i think it's based on a ce2, but don't think it's an exact clone) sounds a lot richer (and has no noise).
For a cheap analog chorus the Moen Holy Choir sounds good. A friend has one in his rig. Sounds good.
I like the pt2399 delays, analog or not. They sound sweet to me.
I am glad AG is clearing this up for us.
I have been very curious about the origins of the circuits. There is NOTHING wrong with the sound of joyo pedals.
atreidesheir
Postby atreidesheir » 12 Nov 2012, 02:15
For this message the author atreidesheir has received thanks:
Buctuswaw (03 Jan 2013, 04:52)
atreidesheir
Postby Dave_Mc » 19 Nov 2012, 22:24
analogguru wrote:Joyo Tremolo (JF-09) = Fulltone Supa-Trem =~ Demeter Tremulator
interesting. mine sounds pretty good, but it's fairly subtle. I think it has a trimpot which adjusts how subtle it is, but i'm kinda scared of taking it apart and not being able to get it back together :lol: As you can tell, i registered here to keep an eye on what pedals were based on what, rather than because I'm any good at building them myself :oops:
atreidesheir wrote:(a) For a cheap analog chorus the Moen Holy Choir sounds good. A friend has one in his rig. Sounds good.
(b) I like the pt2399 delays, analog or not. They sound sweet to me.
(c) I am glad AG is clearing this up for us.
(d) I have been very curious about the origins of the circuits. There is NOTHING wrong with the sound of joyo pedals.
(a) thanks for the heads-up- any idea what it's based on? I was thinking of maybe picking up the mooer chorus, i think it's a ce2 with a level control (but could be wrong on that).
(b) yeah my joyo delay does sound pretty good.
(c) agreed :)
(d) yeah the ones i have (apart from the chorus) sound pretty good. Not saying they necessarily sound as good as the real thing (or are as reliable), but if they sound 90-95% as good for a fifth of the price...
Dave_Mc
Postby Effectsiation » 20 Nov 2012, 14:56
I'm just going by the ad copy and knob count here, but could the "Roll Boost" be the Super Chili Picoso? Does anyone have a gutshot of the Roll Boost?
Effectsiation
Postby Effectsiation » 20 Nov 2012, 15:08
Also, they added a "JF-39 - Deluxe Crunch" to the list, if someone could add that to the first post.
The ad copy says: "Updated version of classic Crunch with higher adjustability, which brings you a almighty Crunch distortion.This pedal definitely is the best of a lot of British pedals. True Bypass design"
So... it's the MI Audio Crunch Box with a Pre control? I guess we won't really know without gutshots.
Effectsiation
Postby felixmeirelles » 18 Dec 2012, 21:57
One more for the list.
The Pocket Metal JF-35 is a simplified version of Boss MT-2 Metal Zone:
Most significant changes,
MT-2 -> JF35
4 way equalizer (Bass, treble, mid1 and mid2) -> only one MID control (100KB pot)
3 M5218AL Mitsubishi -> 3 RC4558 Texas
Flip flop -> True bypass by 3pdt
Most capacitors are polyester -> Most capacitors are ceramic smd.
The values ​​of the dist and level pots are same in both pedals (50KA - 250KA).
The clipping struture are identic but uses smd diodes and transistors on JF-35.
For this message the author felixmeirelles has received thanks:
batteryacidtea (16 Jan 2013, 08:53)
felixmeirelles
Postby Brink » 19 Dec 2012, 01:23
Brink
Has thanked: 10 times
Have thanks: 20 times
Postby felixmeirelles » 19 Dec 2012, 01:26
JF-35 - MT-2 version pics:
http://imageshack.us/g/1/9925759/
felixmeirelles
Postby Lucifer » 23 Dec 2012, 20:27
This Joyo graphic EQ has an interesting spec (according to the ad I've copied below) !
"The Joyo JF-11 6 band graphic equalizer pedal gives you a great range of tonal possibilities and the option to boost your signal and get the sound you want! Excellent value for money and a solid metal construction mean you'll get years of reliable use, on or off stage! Each band provides 18Db range to help you find your favourite tone.
Frequency Band:100Hz,200Hz,300Hz,400Hz,800Hz,1.6MHz and 3.2MHz. [ ! ] True Bypass. Runs off 9 Volt battery (included) or 9v Power Supply (Optional)
Each band provides 18Db range to help you find your favourite tone."
Lucifer
Has thanked: 104 times
Have thanks: 95 times
Postby chumbox » 03 Jan 2013, 00:52
JOYO Compressor = possible Ross / older Keeley clone
Pulled it open last night and it looks like a Ross running 2sc1849 transistors (like script Dyna Comps and older Keeleys) but a newer CA3080E like the Keeley and a boutique kit company Ross. Metal film resistors, Mylar caps and some average soldering but works tops. Box is solid.
This pedal sounds amazing for the price. Less squash than a Dyna Comp but it can still squash. I like a slow attack to let transients through so the attacks control is really handy.
Sure it's not Keeley in tone but for $180 less it's a good pedal for now.
chumbox
Have thanks: 6 times
Postby artkingjw » 16 Jan 2013, 05:59
anybody read about the Dr.Js yet?
http://www.wtfaccessories.com/effect-pe ... .j-pedals/
seen demo of green crystal and arsenal distortion - they sound really good, green crystal sorta reminds me of lovepedal amp11 or a timmy, i don't own either but i've heard them on numerous occasions
artkingjw
Postby czech-one-2 » 18 Jan 2013, 23:31
Effectsiation wrote:Also, they added a "JF-39 - Deluxe Crunch" to the list, if someone could add that to the first post.
My guess is they just moved the presence trim pot outside.... just a guess though!
czech-one-2
Postby czech-one-2 » 18 Jan 2013, 23:39
atreidesheir wrote:opened a joyo tremolo for a friend. The trimpot just beneath the rate pot is maxed and gets close to unity gain. You can bend the guard on the trimpot and turn the trimmer up just a bit more and makes the pedal a real winner.
Hey that was me over at the TDPRI! This may be a first as I'm usually the guy asking for HELP! :scratch:
I still really like the joyo compressor and tremolo. Others have come and gone but those two are staying.
czech-one-2
Postby atreidesheir » 19 Jan 2013, 02:12
YAY!
I like joyo pedals. you get a bit more than you par for.
atreidesheir
Postby Frabbio » 25 Jan 2013, 11:36
I got a Joyo US Dream here with me to make some modification, and i can confirm it's a Riot clone.
The clipping section is only asymmetric in the Joyo pedal.
For this message the author Frabbio has received thanks: 2
atreidesheir (30 May 2013, 17:06), rocklander (25 Jan 2013, 13:07)
Frabbio
Have thanks: 76 times
