List of Joyo Pedal Clones
Re: List of Joyo Pedal Clones
Postby shiflet » 30 May 2013, 02:55
In case you know which pedal is clone the Hot plexi?
shiflet
Have thanks: 2 times
Postby atreidesheir » 30 May 2013, 17:08
It is supposed to be a wampler plexi drive, but some people complain it cannot reach unity gain on the output. I would avoid that one.
The new line is not as well made as the original pedals.
atreidesheir
Has thanked: 452 times
Have thanks: 43 times
Postby Dave_Mc » 09 Jun 2013, 23:57
^ I would suspect it's more likely to be the carl martin plexitone- the colour of the box is the same, and the clips i've heard of the carl martin sound almost identical.
Obviously you'd need to trace the circuit to be sure- but at the moment my (unfounded) suspicion is it's the carl martin clone.
mine goes way over unity, but obviously QC could be all over the place on such cheap pedals.
Dave_Mc
Postby Flotrain » 29 Jul 2013, 02:37
I haven't seen much mention of the Joyo JDI-01 direct box. The Joyo DI is similar to (can't say if it's a clone) the Radial JDX, Palmer, Red Box, Behringer Ultra G or similar guitar amp direct boxes. It's main function is to go between a guitar amp and speaker box. The amp sound goes through the DI's (4x12 or combo) speaker simulator and comes out at line level. Live sound and studio engineers sometimes like this type of DI for consistent predictable sound and lack of stage bleed vs a mic'd cabinet. Obviously the quality of the speaker simulation is critical to the usefulness of the DI. ASFAIK only the Behringer is also a load box (no speaker cabinet required). cheers 8)
For this message the author Flotrain has received thanks:
rocklander (29 Jul 2013, 04:32)
Flotrain
Postby Flotrain » 29 Jul 2013, 06:24
Correction, in fact you DO need a speaker plugged in or a dummy load with the Behringer Ultra G. It appears you need a speaker or dummy load with all the guitar amp DI's...
rocklander (29 Jul 2013, 06:51)
Flotrain
Postby nickthemen » 29 Jul 2013, 22:11
Is clone of the purple plex
nickthemen
Has thanked: 32 times
Have thanks: 11 times
Postby atreidesheir » 01 Aug 2013, 16:32
So, it is based on the COT and Electra family tree?
Do you like your plexi drive?
atreidesheir
Postby induction » 01 Aug 2013, 19:23
The purple plexi is built around an LM386. It's actually pretty similar to the ROG Little Gem (plus a tone control and a modified gain control) used as a pedal instead of as an amplifier.
induction
Has thanked: 63 times
Have thanks: 132 times
Postby atreidesheir » 01 Aug 2013, 23:43
oh. wrong lovepedal design. :P
atreidesheir
Postby BuryMeInSmoke » 16 Aug 2013, 03:18
Pulled apart my Joyo Noise Gate pedal the other day, haven't completely checked it but it looks like it could be the MXR Noise Gate when comparing to a couple of schematics I found online. I've got gutshots I can post if anyone wants them, it's all SMD though.
BuryMeInSmoke
Has thanked: 10 times
Have thanks: 16 times
Postby Fender56 » 05 Dec 2013, 13:45
shiflet wrote:In case you know which pedal is clone the Hot plexi?
FYI, I've opened my Joyo Hot Plexi last week. It is a LM386 driven by an opamp.
For this message the author Fender56 has received thanks: 3
candidate (18 Dec 2013, 09:56), Dave37LP (13 Sep 2015, 19:02), Dave_Mc (18 Dec 2013, 19:30)
Fender56
Have thanks: 5 times
Postby Dave_Mc » 17 Dec 2013, 00:14
^ Thanks for that :) So that means it's not a wampler clone, right? Most of the wamplers are JFET-based, aren't they?
As I said before, I have strong suspicions it's a Carl Martin Plexitone clone. I have nothing to back that up, other than the clips I've heard (which I admit are pretty much no proof whatsoever).
Dave_Mc
Postby induction » 17 Dec 2013, 00:38
The PlexiTone uses 4 op-amps. According to Fender56, this is an LM386 driven by an op-amp. Based on that alone, I think nickthemen is probably right, it's a Lovepedal Purple Plexi, possibly with an op-amp input buffer.
For this message the author induction has received thanks:
Dave_Mc (17 Dec 2013, 18:32)
induction
Postby Dave_Mc » 17 Dec 2013, 18:29
Interesting, thanks. :)
Dave_Mc
Postby rrroo » 10 Oct 2014, 13:21
has anyone looked at the Joyo Compressor more closely? I hear it is more transparent than dynacomp but i hate transparent compressors. i want the squashy sound that dynacomp gives. could the Joyo compressor be modded to give more squash or does it have any relation to dynacomp/ross?
rrroo
Postby mirosol » 27 Nov 2014, 00:01
Flotrain wrote:I haven't seen much mention of the Joyo JDI-01 direct box....
A shop around here was eliminating their stock of these DIs. Guess these weren't a big seller. They were giving them away for 4,60€ a piece, so i got three. Once i find some time i could confirm if it's a Red Box. Features do seem to match H&K Red Box MKIII all the way to every single feature, including in/out impedances. (http://87.106.71.220/oma/huke/manual/REDBOXMK3.PDF)
+m
For this message the author mirosol has received thanks:
rocklander (27 Nov 2014, 00:33)
mirosol
Has thanked: 159 times
Have thanks: 369 times
Postby howmuch » 09 Apr 2015, 10:49
To help fill in some blanks and confirm the list on the first page, a nice person at Joyo has said the following:
Code: Select all
JF-01    Vintage Overdrive       = IBANEZ TS-808
JF-02    Ultimate Drive          = Fulltone OCD
JF-04    High Gain Distortion    = Marshall Shredmaster
JF-05    Classic Chorus          = IBANEZ CS-9
JF-11    6 Band EQ               = MXR 6 BAND EQ
JF-17    Extreme Metal           = EH metal muff
JDI-01   DI Box                  = H&K red box classic
JF-35    Pocket Metal            = EH pocket metal muff
JF-36    Sweet Baby              = Mad Professor Sweet Honey
JF-37    Analog Chorus           = BOSS CE-2
JF-38    Roll Boost              = Mi-Audio Boost 'n' Buff
JF-39    Deluxe Crunch           = "is unique"
From the outside, the JF-39 looks like a "Mi Audio Crunch box" with Presence control to me.
And as we know by now, they might not be exact 1:1 clones, but "heavily inspired by".
howmuch
Have thanks: 22 times
Postby nammy » 14 May 2016, 18:50
Thanks for this thread.
I am having a FATAL ERROR while trying to access the JF-03 link.
A problem with the site i guess.
For this message the author nammy has received thanks:
modman (17 May 2016, 17:03)
nammy
Postby modman » 17 May 2016, 17:03
nammy wrote:Thanks for this thread.
fixed now
Has thanked: 3192 times
Have thanks: 599 times
Postby floris » 03 Jan 2017, 21:44
How about the Joyo Tai Chi?
Looks like a Hermida Audio Zen Drive from the outside.
floris
Has thanked: 171 times
Have thanks: 55 times
Users browsing this forum: No registered users and 9 guests
