Your guess is right, there is a 1k resistor:Dirk_Hendrik wrote: And in your unit RLED is replaced by a jumper wire as well? Guess not.
Ibanez - JD-9 Jet Driver [schematic]
- tube-exorcist
- Ibanez_JD9_R-LED.jpg (32.71 KiB) Viewed 4645 times
- tube-exorcist
You are welcome.Dirk_Hendrik wrote: Thanks for the values. I had the connections already.
Yep..... only interesting is the Overdrive section - via the inverting input now.... a little bit non-standards-TSDirk_Hendrik wrote: Standard hi, gyrator mid tone control.
- Dirk_Hendrik
Draft, incomplete. Correct component numbering, connector numbering, pot taper for the Mid and Tine control, cap values would be appreciated.http://www.dirk-hendrik.com/temp/Ibanez_JD9.pdf
- tube-exorcist
Here some of the missing things:
(jumpered) L1 at the input is marked on the pcb: L2
C23: 47p
C1: 22n
Q1: 2SC1815-GR
C2: 47n
R3 is not 47k, it is: 4k7
D1 is marked on the pcb: D7
D2 is marked on the pcb: D8
C4 is marked on the pcb: C3 and is 51p
R5 is not 10k, it is: 1k
C3 is marked on the pcb: C4 and it is µ22/50V
C5: µ22/50V
C6: 220p
C11: 2n2 (f res = 650 Hz)
CX is marked C9 and is: 10n
R6 is marked R13 on the pcb
CX2 is marked C14 and is 100n
Q2: 2SC1815-GR
CX3 is marked C7 and is 47p
C15: 1µ/50V
(jumpered) L2 is marked L1 on the pcb
C16: 100µ/16V
CXX is marked C17 and is: 47µ/16V
C8, C13, C18; C19 each is: 100n
anything else needed?
C23: 47p
C1: 22n
Q1: 2SC1815-GR
C2: 47n
C5: µ22/50V
C6: 220p
Q2: 2SC1815-GR
C15: 1µ/50V
C16: 100µ/16V
- Dirk_Hendrik
Cool Thanks!tube-exorcist wrote: Change list
Update:
Connector numbering, grounding scheme and the taper for the Mid and Tone pottube-exorcist wrote: anything else needed?
- tube-exorcist
potentiometers are marked as follows:
VR1: B1M (Drive)
VR2: B10k (Mid)
VR3: B10k (Tone)
VR4: B100k (Volume)
P1/J1 (LED):
1: anode
2: kathode
P2/J2 ---------
P3/J3 ---------
P4/J4 (Footswitch):
wiring see pictures above, blue is pin 1.
P5/J5 (Input jack):
1: Tip (signal)
2: Ring (battery)
3: Sleeve (ground)
P6/J6 (Output jack):
1: Tip (signal)
2: Sleeve (ground)
P7/J7 (vol-tone-pcb) :
1: Tone, cw
2: Tone, ccw
3: Tone, slider
4: Volume, cw
5: Volume, slider
6: Volume, ccw (ground)
P8/J8 (drive-mid-pcb):
1: Drive, ccw
2: Drive cw + slider
3: Mid, cw
4: Mid, slider
5, Mid, ccw
BTW, the serial number of my unit is 1041472.
VR1: B1M (Drive)
VR2: B10k (Mid)
VR3: B10k (Tone)
VR4: B100k (Volume)
P1/J1 (LED):
1: anode
2: kathode
P2/J2 ---------
P3/J3 ---------
P4/J4 (Footswitch):
P5/J5 (Input jack):
1: Tip (signal)
2: Ring (battery)
3: Sleeve (ground)
1: Tip (signal)
2: Sleeve (ground)
1: Tone, cw
2: Tone, ccw
3: Tone, slider
4: Volume, cw
5: Volume, slider
1: Drive, ccw
3: Mid, cw
4: Mid, slider
5, Mid, ccw
- Dirk_Hendrik
Cool! That seems to cover all. Regret to see they took the lin shortcut for the tone controls.
Updated;
Updated;
I just got a used JD-9. When I plugged it in it was on and wouldn't turn off. I flushed out the switch with contact cleaner and now it will turn on only when the switch is pressed down. Bad switch? Any other ideas on a fix? I understand it's a true bypass design unlike other 9 series pedals.
I managed to get a switch from Ibanez. It took several weeks to get and was $16.00 and change, but should do the job. A friend with better soldering skills then I have is going to install it as it needs some fine circuit board work. Hopefully that's the only problem. I'll report the results.
- Dirk_Hendrik
So, in essence, you did a fine job! Excellent!
- roseblood11
So, changing R11 from 6k8 to 3k3 would bring the center frequency up to 995 Hz, and the Q will increase from 0.72 (around 2 octaves) to 1.03 8around 1 1/3 octaves).
Should be worth trying...
Hi
Thanks for this useful thread. I got a JD9, that I find pretty interresting to use on guitar (though the mid indeed is a bit low for my taste, so I keep the mod for that in mind).
I've tried this JD-9 on bass and It's very close to the sound I search : little distortion but with some nice hi-mid attack, and not too much of those "transistor" highs that can be heard on most overdrive meant for bass. So I wondered if I should try to tweak it a bit (less drive so I can use the pot above 9 o'clock, modify the mid frequently pot that I barely use by example). Or, if some of you knew a pedal with a close design that could give me that type of sound ?
Thanks in advance for your advice.
