Marshall - ED-1 Compressor [schematic]
First post, and already I'm asking for freebies
Anyway, I have an ED-1 compressor on the bench, and trying to follow all those mini connectors is doing my head in... Does anyone have a schematic for this pedal? I've e-mailed Marshall tech support about it, but haven't gotten any response yet. I suppose they'll get back to me eventually, but I'm itching...
/Andreas
/Andreas
- The Rotagilla
Try emailing them again. I've found them to be very helpful and responsive in the past.andreas wrote:First post, and already I'm asking for freebies
/Andreas
- Dirk_Hendrik
[parrot mode]andreas wrote:First post, and already I'm asking for freebies
Since you have the thing on your bench. How' bout you being the one drawing up that schematic? I'm aware that might be difficult but it's a great learning experience and, in the end, ego boost as well It's the start of the weekend. Make fresh coffee, kick the family out and dive into this!
[/parrot mode]
- analogguru
[parrot mode]
why he should draw the schematic when he already has the factory schem in his mail ?
[/parrot mode]
you want that too ?
[/parrot mode]
you want that too ?
- Dirk_Hendrik
only if it's not another variation on a dynacomp
I stumbled upon this old post today and noticed that it wasn't resolved. I draw the schematics for the ED1 many years ago, with the Eagle freeware app. If someone is still interested, here it is. I can see that I missed some of the C and L values, don't remember why.
- Marshall ED1
- ED1.png (24.45 KiB) Viewed 5174 times
- Hides-His-Eyes
Inductors?
- IvIark
Great first post!
- mictester
Yes. They're just ferrite beads with a few turns of enamelled wire through them. They stop getting RF into the pedal. I use them throughout my gear (especially in high gain circuits) to prevent the AM receiver effect!Hides-His-Eyes wrote:Inductors?
Back in the days when I used to play USAF bases in the UK, we used to have to include lots of RF filtering in the gear to keep the radar out of the PA! The control tower AM or SSB would also cause interference, and they didn't care where their aerials pointed!
- Hides-His-Eyes
I take it that having a small cap across an op-amp will also filter out all but the most dedicated of radio stations?
Sorry, I meant Herakles' schematic - and I'm usually quite good at CaPitAl lEtteRs.
I also forgot to mention that my ED-1 came with a BA4558 IC for IC1.
All transistors and IC2 are as per Herakles' schematic.
- roseblood11
The smaller caps improve the filtering at higher frequencies. But I don´t understand why they use 4 identical caps. I read somewhere that it would give the best result, if each cap was 10 times smaller than the preceding one, say 100µF, 10µF, 1µF,...
I wonder if (and how?) the ferrite beads affect the sound.
Or what else could be done to improve the bypass sound? If a passive guitar is connected directly to the ED-1, the highs are tamed a bit.
I know that it´s quite simple to remove the small pcb with the jacks etc and make a standard true bypass switching (photo...), but if the ferrite beads don´t affect the tone, I would rather keep them where they are...
The pedal on the photo was modified by "tonesucker" and posted at musikding.de.
- RnFR
roseblood, your pic isn't showing up for me.
C16 (.01) is across pins 4 and 8 of IC1, C17 (.01) is across pins 4 and 7 of IC2 - for maximum RF rejection I guess?
The ED-1 and the other pedals in Marshall's metal beetle series use something that they describe as "passive bypass", but it's not even close to true bypass. Definite tone-suck.
Maybe we could use the inbuilt DPDT switch to make something like Jack Orman's Millenium bypass, which would make these pedals really kick arse.
- roseblood11
Here it is:
"Tonesucker" wrote that he made some changes after he took the photo: a) Changed the wiring to shunt the input to ground in bypass mode, b) added a 2,2M pulldown before the input cap.
Thanks roseblood11. That true bypass looks good....might be easier than modifying the little PCB too.
Worth a try, methinks.
- roseblood11
That makes more sense! ...and I found another version of the schematic that shows it that way.Valve Head wrote:C16 (.01) is across pins 4 and 8 of IC1, C17 (.01) is across pins 4 and 7 of IC2 - for maximum RF rejection I guess?
Shouldn´t be a problem...Valve Head wrote:The ED-1 and the other pedals in Marshall's metal beetle series use something that they describe as "passive bypass", but it's not even close to true bypass. Definite tone-suck.
I would also be interested in an improved bypass for the pedals with stereo outputs, for example the VT-1 Vibratrem or the SV-1 Supervibe Chorus.
