Joyo - JF-39 Deluxe Crunch
Postby decora » 28 Jan 2013, 10:18
Picked this up last week, have not played much with it unfortunately. More than enough gain but i find that i'm wanting more from the Pre and Tone. This sounds more open than Joyo's Crunch (crunch more compressed to my ears). I stack overdrive pedals in front of it to make it tighter. Cracked it open today and took some gutshots for everyone. Cheers!
Vol - A10K, Dist - B100K, Presence B20K, Tone C10K.
i'm using Picasa, if photos doesnt show up, i'll try and get a different hosting.
For this message the author decora has received thanks: 2
Ice-9 (28 Jan 2013, 11:52), modman (28 Jan 2013, 17:53)
decora
Have thanks: 4 times
Re: JOYO Deluxe Crunch JF-39
Postby decora » 28 Jan 2013, 10:50
photos...
modman (09 Feb 2013, 17:29)
decora
Postby soulsonic » 28 Jan 2013, 14:31
Ah, LEDs for clipping diodes.
Thanks for sharing!
Has thanked: 53 times
Have thanks: 257 times
Postby Buzz Crumhunger » 11 Aug 2014, 07:01
So, should I be not at all surprised that the PCB says "Joyo DLS" right on it? Anyone hear both of enough pedals (or know the schematic well enough) to assert that this is a copy/clone of the Catalinbread DLS?
Just curious...
For this message the author Buzz Crumhunger has received thanks:
modman (11 Apr 2015, 15:47)
Buzz Crumhunger
Postby mirosol » 11 Aug 2014, 07:19
Buzz Crumhunger wrote:So, should I be not at all surprised that the PCB says "Joyo DLS" right on it? Anyone hear both of enough pedals (or know the schematic well enough) to assert that this is a copy/clone of the Catalinbread DLS?
Just curious...
Umm.. DLS is made of six JFETs and here we have one JRC4580. So no. It's nothing even remotely close to Catalinbread DLS.
+m
For this message the author mirosol has received thanks:
modman (11 Apr 2015, 15:57)
mirosol
Has thanked: 146 times
Have thanks: 330 times
Postby grrrunge » 11 Aug 2014, 08:58
An older version of MI Audios Crunch box? The pot values and circuit simplicity seem right as far as i remember.
grrrunge
Has thanked: 58 times
Have thanks: 203 times
Re: Joyo JF-39 Deluxe Crunch
Postby Desdog » 11 Apr 2015, 22:01
MI Audio Crunch Box uses this opamp: LM833
Joyo Deluxe Crunch uses the compatible 4580:
You could put this next to the gutshot:
and compare to the Mi Audio Crunch box schematic:
Desdog
Has thanked: 57 times
Have thanks: 14 times
Re: Joyo - JF-39 Deluxe Crunch
Postby Rogerio » 29 Oct 2017, 22:08
I am a beginner, and I have this pedal. I love its sound, but it's too much gainy for me, so I want to reduce gain and move it into the overdrive area. I want to ask this forum what mod to do, taking into account it will be difficult to change a small component. Perhaps to change the Gain pot to another value? Or the type of pot. I know Super Crunch Box has a low gain switch...it could be applied to this pedal? It may be a clipping section components change?
Thanks in advance.
Rogerio
Postby modman » 02 Nov 2017, 13:02
Rogerio wrote:Hi,
Thanks in advance.
We don't have a schematic of this pedal available and even lost the gutshots because they were hosted on photobucket. If you can provide good quality gut shots of this pedal, other may be able to help out. We do have the schematic for the Joyo Crunch Distortion here: viewtopic.php?f=1&t=17055&p=188698&#p188698
Has thanked: 2951 times
Have thanks: 519 times
Users browsing this forum: No registered users and 6 guests
