Guyatone - WR-3 Wah Rocker 3 [schematic]
- LooseCannon
Hey guys, this is my first vero layout and I picked a damn hard one to start with!
I first tried to make it fit inside a 1590B with a battery but after many hours realized it's not gonna happen... So this one should fit inside a 1590B without a battery.
Special thanks goes to Square Wave for his help with removing the switching from the schematic and answering my questions regarding it.
This is unverified so if anyone spots a problem please let me know.
- Guyatone WR-3 Wah Rocker(1).pdf
- Guyatone - WR-3 Wah Rocker 3 schematic
- (78.83 KiB) Downloaded 297 times
- WR3.png (45.41 KiB) Viewed 6114 times
- LooseCannon
I've just noticed a mistake- the "Out" connection should be two rows up, but I can't seem to edit my post? Admins?
I have also noticed that I didn't leave enough room for some of the offboard wire connections, for example in the 9v row.
- square wave
Did this work on the breadboard? I'm wondering if my advice was right or wrong.
- LooseCannon
Nope, didn't work on the breadboard, but it's pretty complex for a breadboard so I might have made a mistake that I missed there.
- LooseCannon
From the other thread:
Let me know if you get it to worksquare wave wrote:Without opening a Wah Rocker and seeing what they use, I couldn't tell ya. What I would do is try several different standard types (2N5089, MPSA18, etc) and see if they have any significant effect on the sound.
I am new to this forum and first of all I would like to thank you for sharing the Guyatone WR3 schematic, which I couldn't find anywhere else.
I re-drew the schematic omitting the switching circuit to build it as a true-bypass pedal and I made a layout to use perfboard (which is what I usually use to build my pedals), so I would like to share!
The layout is as compact as possible, with resistors mostly "standing".
I built the circuit and it works! I will let you see it in a box and hear it as soon as possible.
Have a nice day!
Giulio
Have a nice day!
Giulio
PS: Regarding the "nameless" transistor in the original schematic, I realized that higher gain transistors work better, since low gain ones like the 2N3904 give quite a high threshold before the "quack" starts... I wrote 2N5088 on my schematic, but I'm still experimenting and I will let you know if I come up with the "best" one!
I just realized the links I posted to my re-drawn schematic and layout are broken so, as I can't edit my post anymore, I'm re-posting it with (hopefully) working links:
Have a nice day!
Giulio
Have a nice day!
Giulio
- Blitz Krieg
- soupbone
Does anybody have a layout or schematic for the Guyatone Wah Rocker 3?It's the Quacky Pedal Guthrie Govan uses.I checked on EBay,and they're going for astronomical prices.
- Fredenando
- soupbone
Thanks folks!
Great news! After all this time, and keeping my build unused in a drawer, I finally realized what was wrong with it: I compared the schematic of the WR3 with the "Dr. Quack" schematic, which is different but uses the same principle, and saw that C11 in the WR3 schematic was just too small! That's why I had to play so hard to make the "gate" open, and the loud peak I heard was just me hitting the strings too hard to have the desired effect,
So the problem was a mistake in the WR3 schematic: C11 should read "223" (i.e. 22nF, or 0.022uF if you prefer) and NOT "222" (2.2nF, way too small to pass your signal in the "wah" section).
Now the circuit works as it should: by adjusting the threshold control, you can even get the "gate" open by tapping or slapping softer or louder.
That's some real satisfaction!!
Giulio
Giulio
Hi Giulioshredgd wrote:Great news! After all this time, and keeping my build unused in a drawer, I finally realized what was wrong with it: I compared the schematic of the WR3 with the "Dr. Quack" schematic, which is different but uses the same principle, and saw that C11 in the WR3 schematic was just too small! That's why I had to play so hard to make the "gate" open, and the loud peak I heard was just me hitting the strings too hard to have the desired effect,
Giulio
Can you repost the layout, the picture link from the above posts are not valid anymore
