Mesa Boogie - Throttle Box  [schematic]
Postby apollomusicservice » 26 Sep 2013, 16:09
Pedal excellent for hi gain but also (with gain lower settings) perfect for rock and blues.
For this message the author apollomusicservice has received thanks: 44
bajaman (29 Sep 2013, 01:48), bluetube (08 Oct 2013, 03:50), bumblebee (04 Feb 2019, 07:55), Dirk_Hendrik (29 Sep 2013, 09:46), IvIark (04 May 2014, 16:00), lietuvis (28 Sep 2013, 23:37), lohstah (27 Sep 2013, 17:16), modman (19 Nov 2014, 11:35), Sari (18 Nov 2013, 16:57), sinner (26 Sep 2013, 16:44) and 34 more users
apollomusicservice
Has thanked: 65 times
Have thanks: 794 times
Re: Mesa Boogie Throttle Box schematics
Postby LaceSensor » 26 Sep 2013, 16:15
Looks to be solidly constructed and interesting it includes and inductor.
thanks!
LaceSensor
Has thanked: 45 times
Have thanks: 249 times
Postby osiris » 28 Sep 2013, 21:58
Great work on the schematic, thank you. But I don't see S2, which switches the three gyrator tone shapers in and out in the original design. Is this your modification?
osiris
Postby apollomusicservice » 29 Sep 2013, 07:32
S2 is internal EQ boost/cut switch, on pcb picture placed at bottom left side.
apollomusicservice
Postby Dirk_Hendrik » 29 Sep 2013, 09:47
Like the approach with the fixed gyrator EQ!
Has thanked: 255 times
Have thanks: 1036 times
Postby apollomusicservice » 30 Sep 2013, 12:25
For SMD DIY-ers here is my design of pcb. Resistors and capacitors are 1206
package and C (6mm) for tatntalum capacitors. The pcb is suitable for those who
will not install additional EQ boost/cut components on the bottom side but if you wish to add EQ,
both sides are connected with 4 via holes. Of course tantalum capacitors in the picture are not SMD tantalum,
currently I did not had SMD type.
Pdf file contains top and bottom side of SMD Throttle Box. 8)
For this message the author apollomusicservice has received thanks: 6
bumblebee (04 Feb 2019, 07:56), domdec314 (19 Sep 2015, 01:24), Fredenando (01 Oct 2013, 07:11), Greenmachine (04 Oct 2013, 02:47), maungaja (02 Aug 2015, 02:12), modman (19 Nov 2014, 11:38)
apollomusicservice
Postby roberttomasz » 03 Oct 2013, 20:32
Question. Look at the picture.
For this message the author roberttomasz has received thanks:
roberttomasz
Have thanks: 18 times
Postby apollomusicservice » 04 Oct 2013, 08:45
Yes, that is the switch S2, which is located inside the housing. Pedal has enough gain at Lo position so
in my opinion it would be more useful if the switch was mounted out enclosure instead of switches for gain.
On my SMD PCB I predicted one switch in/out EQ mounted on the chassis and perhaps to add one more on/off switch to turn off gyrator for 276Hz.
apollomusicservice
Postby roberttomasz » 04 Oct 2013, 15:01
...C19 100nF ,,,???.
roberttomasz
Postby apollomusicservice » 04 Oct 2013, 15:20
roberttomasz wrote:...C19 100nF ,,,???.
Yes and it has function only in bypass mode.
apollomusicservice
Postby roberttomasz » 04 Oct 2013, 21:12
B2-B3-C19(100nF)???? ...B2-C1-YES
roberttomasz
Postby gefi » 10 Oct 2013, 17:01
Hello
L1 250 mH or 250uH?
gefi
Postby apollomusicservice » 10 Oct 2013, 17:48
gefi wrote:Hello
L1 250 mH or 250uH?
250 millihenries
apollomusicservice
Postby Bill_Mountain » 10 Oct 2013, 17:53
I just sim'd the graphic EQ portion and unless I messed up it didn't equate to much more than a bass boost.
The mid control is nice though!
Bill_Mountain
Have thanks: 4 times
Postby roberttomasz » 11 Oct 2013, 13:36
wah-wah ( Dunlop) L1= 500mH
roberttomasz
Postby Mrdorbe » 23 Oct 2013, 10:03
this is amazing, is it posible for you to upload a layout for a board with thru hole parts or a schematic file readable by a program?
i would really like to try building this one.
Mrdorbe
Postby apollomusicservice » 27 Oct 2013, 18:44
OK here is pcb done in through-hole technology, like original. There are two pcb's,
first with almost all components and second with jacks, pots and few components.
Pedal has very originally sounds and I change my prejudice about Mesa pedals. 8)
For this message the author apollomusicservice has received thanks: 5
Dave37LP (19 Feb 2014, 08:42), Fredenando (28 Oct 2013, 10:03), jymaze (27 Oct 2013, 23:10), karul (28 Oct 2013, 02:05), modman (19 Nov 2014, 11:39)
apollomusicservice
Postby Mrdorbe » 28 Oct 2013, 09:50
Amazing man!! Thank you so much! I'll try to build it and update.
Mrdorbe
Postby Mrdorbe » 28 Oct 2013, 13:49
Except the PDF has only one of the pcbs :cry:
Mrdorbe
Postby apollomusicservice » 03 Nov 2013, 15:26
...and second pcb with some minor changes in routing. 8)
For this message the author apollomusicservice has received thanks: 3
Dave37LP (19 Feb 2014, 08:43), Fredenando (04 Nov 2013, 02:59), J0K3RX (15 Dec 2013, 02:59)
apollomusicservice
Next
Users browsing this forum: darmstat, Google [Bot], lamasaxa and 12 guests
cron
