Here are the pictures. Its finally working stable, no cold solders, no short circuits etc. The 2 problems that i have are LED is still not bright enough (changed the 2k2 into a 1k, didnt work!), and the distortion character is not that "chainsaw" enough. I've ordered both 4558 and 5218 to be able to try both of them. As far as i could notice, 5218 is a little more bassy while 4558 is a little more loud and treble. So i've mixed them
By the way, i need some help of GodSaveMetal. I've ordered all of the trannies and IC's again with some sockets just to be sure they are not broken. Yet There are 3 transistors, which doesnt affect the circuit. By this i mean, when i remove them from their sockets one at a time, the sound goes away completely. BUT, the ones i've marked with "O" doesnt do that. I can play just fine with or without them. I think there is a problem with their connections on the circuit. I'm sure there are no short circuits around, else it would not work, just like it did at first
Looking for your help. Other than these, its great, it gives the basic character of that saw sound, but as you can hear, its not enough. I've used LePou Hybrid, which is a Marshall VST, in JCM Mode, all at 12 except Contour is full. And for cabinet, i've used Catharsis C1 IR. No pre-post eq at all..Guitar is Ibanez RG7321 with S.Duncan Blackout's..
https://soundcloud.com/baranismen/diy-hm-2-trial
