Behringer - DD600 Digital Delay  [schematic]
Postby modman » 27 Aug 2014, 06:35
Somebody requested this...
For this message the author modman has received thanks: 5
Andy2No (15 May 2017, 01:41), Bloodman (15 May 2017, 02:52), Fredenando (27 Aug 2014, 19:08), grizzlytone (25 May 2015, 18:15), jp-el (11 Sep 2014, 19:51)
Has thanked: 2788 times
Have thanks: 483 times
Re: Behringer - DD600 Digital Delay
Postby collingtech » 08 May 2015, 17:19
do you have the firmware for the atmega ? , can you copy the thing?
collingtech
Postby soulsonic » 08 May 2015, 20:59
collingtech wrote:do you have the firmware for the atmega ? , can you copy the thing?
Why would you want to steal Behringer's programming? These boxes are only $50 new... :?
The main usefulness of this schematic is to repair a broken one or to help with modifying the analog section. Why would you even consider building a clone? :|
Has thanked: 53 times
Have thanks: 248 times
Postby collingtech » 17 May 2015, 00:46
im triiyng to design a sound on sound delay eefect and have a few dsp around here , just want to give a shoot on this thing :0) , absolutly not going to clone behringer ever
collingtech
Postby Andy2No » 15 May 2017, 01:46
A bit late with this (as usual) but the Atmega16 chip is just being used for the knobs and switches. The clever stuff is being done by the DSP chip.
I quite like the idea of making a digital pedal with an Arduino Atmega 2560 or similar, but I think it would have to be more of a bit crusher, if it was all done by the Atmega chip - I don't think it would keep up with processing high quality audio.
Andy2No
Has thanked: 96 times
Have thanks: 2 times
Users browsing this forum: luckett, Xeno.Influx and 17 guests
