DOD - FX40B Equalizer [schematic]
I'm in the process of repairng this DOD FX-40b eq. Here are the gutshots. When i received it, the offboard wiring had been tampered with. Does anyone have a schem or diagram showing the switching / offboard wiring ? Or, can anyone lend some clues as to how the power is supposed to be supplied?
Anyway, enjoy the gutshots:
- analogguru
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 281 times
nice pictures!!!
First message here, I hope it's okay to revive an old thread.
I own one of those. Years ago I needed a 9v battery connector so I unsoldered the one from the FX40b because I wasn't using it at the time and I was in a hurry.
Now I would like to fix it, I don't care for the 9v battery connector because I have a power adaptator.
I don't have much experience with electronics but this is a very simple fix. The input connector for power is now connected to nothing and I have a yellow wire that is hanging. Would someone kindly explain to me how I should connect these?
Will do some picture tonight if it helps.
However it's hard for me to understand these schematics.
What I've done is I've open another DOD I have (FX57, shitty distortion/delay) to see how it is wired and I repaired the FX40B that way.
And it works.
Cheers guys.
And it works.
Cheers guys.
The FX40B Equalizer was a seven-band graphic equalizer. Initially the pedals were grey with red graphics and slider covers. Circa 1992, the cosmetic appearance of the FX40B was revised with brown paint/white graphics and all-plastic slider pots, eliminating the risk of losing a rubber slider cover. In 1998, when all other pedals were revised to the final version casing (in preparation to the made-in-China VFX series), the DOD FX40B remained the same (albeit with new graphics at the top of the pedal), probably to help use up the supply of old casings. ( http://www.americaspedal.net/fx40b/ )
Last version 1999, - factory schematic:
- FX40B factory schematic 1999.pdf
- (37.32 KiB) Downloaded 320 times
Not liking the bypass on this much, and have a relay bypass board ready to go.
Looking at the schematics above I can see Q1 and Q2 are involved somehow.
Am I right in thinking removing one of these, or maybe D1 or D2 would force the circuit to be always on?
Miles
Miles
