Ibanez - Mini Tube Screamer [schematic]
- apollomusicservice
MINI Tube Screamer guts & schematic
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
Cute pedal
Big thanks for one more contribution
Here is my version of this Screamer designed for SMD technology. Pots and switch are on the other side of Pcb, DC jack and input/output jacks are mounted directly on 1590A housing.
- Mini TS SMD.pdf
- (30.04 KiB) Downloaded 438 times
I don't think so.Ixide wrote:I think the resistor values R10 and R11 must be swapped (R10=1k, R11=220). You can once again verify the original TS MINI?
- 10.jpg (30.41 KiB) Viewed 8973 times
- Dirk_Hendrik
This is a thread I missed completely. Thanks Apollo! Also thanks Ixide for noticing this error. Makes one wonder if someone made a f-up with the BOM.
- Ice-9
- Degoop Doctor
or the pick and place machine had the wrong reel loaded that day.Dirk_Hendrik wrote:This is a thread I missed completely. Thanks Apollo! Also thanks Ixide for noticing this error. Makes one wonder if someone made a f-up with the BOM.
- Dirk_Hendrik
Hi everyone, maybe somebody knows where i can find a tone knob replacement for the tube screamer mini?
thanks very much
thanks very much
- phatt
I think you will find there is no Knob as such, the shaft is the knob. So if it's broken/damgaed then you will have to replace the whole pot.
Phil.
Phil.
hi Phil thank you very much for your response. Any place where i cand find that exact pot? in the piece it says GC203W and it has the brand ALPS on it. I did try to google it and search for it in the alps web but didn´t have any luck.phatt wrote:I think you will find there is no Knob as such, the shaft is the knob. So if it's broken/damgaed then you will have to replace the whole pot.
Phil.
thank you
Any one knows something about it?
thanks
thanks
thank you very much drewl.
