EHX - Wiggler  [schematic]
Re: EH - Wiggler
Postby kreeper_6 » 17 May 2010, 01:33
O.K.
So how do I remove the tubes from this circuit?
kreeper_6
Re: EH - Wiggler
Postby devastator » 20 May 2010, 17:42
take off the black stuff (with screwdrive) , then you pull the tubes , softly , doing a litle movement form right to left. They come easily.
Anyway, I had to fix mine again. The wire of the weird dc jack was broken. I have , also, to put new led holder .
Why EHX stuff are so crappy ? :lol: :lol:
devastator
Have thanks: 24 times
Re: EH - Wiggler
Postby monkmiles » 01 Jan 2011, 19:12
Bumping an old thread. But anyone else try this mod to the rate knob to make it more usable? It's very sensitive and gets too fast in my opinion.
station wrote:Oh, and one improvement that I made (besides dropping the whole pedal in acid to etch the finish off :lol: ) was to to put a 100 ohm resistor between legs 1 and 2 of the rate knob. Made the usable range go from 8 o'clock to 3 instead of 8 - 10 or 11. A very easy mod that makes this pedal way more enjoyable to play.
monkmiles
Re: EH - Wiggler
Postby devastator » 01 Jan 2011, 19:23
changing the pot is the best option . I can try putting in // or serie a resistor but I gonna play also on the curve.
Mine was a real nightmare to set because of this pot and when I watched the "pulsar" vids that was the same kind of issues with its rate control (why EHX always does that ? )
devastator
Re: EH - Wiggler  [schematic]
Postby Fredenando » 02 Jan 2011, 01:18
Here are a schematics for the Rev B version:
http://img37.imageshack.us/img37/6520/ehwigglerschematicrevb.pdf
For this message the author Fredenando has received thanks: 2
borislavgajic (02 Jan 2011, 11:28), modman (06 Mar 2011, 11:20)
Fredenando
Has thanked: 475 times
Have thanks: 93 times
Re: EH - Wiggler
Postby borislavgajic » 02 Jan 2011, 11:29
Thank you very much..........where did you get this schem? it was missing from that EH files.... :thumbsup :hug:
Boris
borislavgajic
Has thanked: 140 times
Have thanks: 249 times
Re: EH - Wiggler
Postby Fredenando » 02 Jan 2011, 15:46
Hello Boris, here is where I have found it:
http://music-electronics-forum.com/t16589/
Fredenando
Re: EH - Wiggler
Postby borislavgajic » 02 Jan 2011, 17:00
Thanks for info!
:thumbsup
Boris
borislavgajic
Re: EH - Wiggler
Postby kreeper_6 » 06 Mar 2011, 09:09
devastator wrote:take off the black stuff (with screwdrive) , then you pull the tubes , softly , doing a litle movement form right to left. They come easily.
Haha, Nah I meant literally taking the Valves and transformer out of the circuit/schematic altogether.
kreeper_6
Re: EH - Wiggler
Postby borislavgajic » 06 Mar 2011, 11:30
you have mqany articles about that ....mostly simulating tube preamps with FET-s ....but why do that? point of this thread is to make TUBE Wiggler :block:
Boris
borislavgajic
Re: EHX - Wiggler
Postby clintrubber » 17 Jan 2018, 13:23
FWIW, inside pic of the related/almost identical Nady TTV-2 added to this thread:
viewtopic.php?f=33&t=15386&p=172566&hilit=Nady#p172566
clintrubber
Has thanked: 13 times
Have thanks: 2 times
Re: EH - Wiggler
Postby clintrubber » 17 Jan 2018, 21:08
Fredenando wrote:Here are a schematics for the Rev B version:
Anybody still has this file somewhere ? Seems to be gone from imageshack after all those years.
clintrubber
Users browsing this forum: No registered users and 9 guests
