Budda Chakra Compressor  [schematic]
Postby johnnyg » 01 Nov 2015, 23:01
First optical compressor I've used and a nice change from DynaComp type I've only previously experienced. Also first attempt at publishing a full circuit trace; hopefully it's right.
BuddhaComp.pdf
Yet to break through the Space Charge
For this message the author johnnyg has received thanks: 7
Blitz Krieg (03 Nov 2015, 08:40), dv8r601 (15 Jul 2017, 06:21), lolbou (02 Nov 2015, 14:52), modman (15 Nov 2015, 21:50), rcustoms (02 Nov 2015, 04:41), roseblood11 (02 Nov 2015, 01:25), Scruffie (02 Nov 2015, 14:26)
johnnyg
Has thanked: 102 times
Have thanks: 49 times
Re: Budda Chakra Compressor
Postby roseblood11 » 02 Nov 2015, 01:30
have you measured the LDR?
roseblood11
Has thanked: 332 times
Have thanks: 304 times
Postby johnnyg » 02 Nov 2015, 12:35
Dark resistance in circuit was c. 250k. But any other parameters (like on and off times) I've no idea. I would guess, like most circuits that use an optocoupler, one would have to plug in different types of LDR or vactrol to find something that works.
BTW the circuit reminded me of Rod Elliott's compressor designs and Rod provides some explanation of the circuit (like the 100uf cap across the LED: "some LDRs may give distortion at low frequencies. A 100uF cap in parallel with the LED will probably help if this is a problem").
http://sound.westhost.com/project92.htm
johnnyg
Postby dv8r601 » 08 Sep 2017, 20:49
I'm really on the hunt for a non ota comp and I want to build this one correctly. So, the 2w10 diode bridge has a max Vf of 1.1v, could I just sub that with rectifier diodes? Or do I just need to pony up and order one? I know what a bridge does and is I'm just curious if the diode type matter as much.
dv8r601
Has thanked: 349 times
Have thanks: 16 times
Postby bmxguitarsbmx » 09 Sep 2017, 03:33
Hey dv8r601,
In my estimation, this schematic is missing some connections.
Here is the link from above, that is now dead:
http://sound.whsites.net/project92.htm
Wish I could be more helpful, as it looks like it could be an interesting circuit.
For this message the author bmxguitarsbmx has received thanks:
dv8r601 (11 Sep 2017, 17:22)
bmxguitarsbmx
Has thanked: 234 times
Have thanks: 71 times
Users browsing this forum: camsmit1 and 11 guests
