MF Drive by MOOG guts
Postby apollomusicservice » 24 Nov 2015, 15:32
MF Drive by MOOG.
For this message the author apollomusicservice has received thanks: 7
287m (26 Nov 2015, 14:10), Chugs (24 Nov 2015, 20:07), jsetov (29 Nov 2015, 18:54), modman (24 Nov 2015, 18:06), Nocentelli (24 Nov 2015, 20:40), nr372 (24 Nov 2015, 20:11), x-tn (27 Nov 2015, 18:54)
apollomusicservice
Has thanked: 65 times
Have thanks: 760 times
Re: MF Drive by MOOG guts
Postby NOC3 » 07 May 2017, 03:35
Didn't see this thread before posting this: http://freestompboxes.org/viewtopic.php?f=1&t=28322
Info for mods to the FET od section and adding a resonance control where the "peak" switch is so you can push the filter further and into oscillation!
NOC3
Has thanked: 10 times
Have thanks: 28 times
Postby pb+j » 11 May 2017, 10:43
The MF drive is a really great pedal. The tone control is a little odd--it's a lo pass then a mid cut then a hi pass. It's not very logical, but I have a hard time getting a bad sound out of this pedal.
pb+j
Have thanks: 2 times
Postby jrfox92 » 12 May 2017, 05:27
pb+j wrote:The tone control is a little odd--it's a lo pass then a mid cut then a hi pass.
Sounds like you just described a Big Muff tonestack. [smilie=a_cookiemonster.gif]
jrfox92
Have thanks: 52 times
Users browsing this forum: bobdorock2010, Google [Bot], MilesXC and 9 guests
