Aria - AUM-1 Ultra Metal  [schematic]
Postby Bernardduur » 08 Jul 2008, 20:56
Had one today under my hands...... nice little box that could deliver nice sounds :)
Discofreq entry
Schematic
Quite similar to the Boss HM-2
For this message the author Bernardduur has received thanks: 2
modman (27 May 2015, 10:19), TWAlex (09 Aug 2016, 20:51)
Bernardduur
Has thanked: 87 times
Have thanks: 490 times
Re: Aria - AUM-1 "Ultra Metal"
Postby soulsonic » 09 Jul 2008, 08:41
I love this circuit! :D
Has thanked: 56 times
Have thanks: 280 times
Postby analogguru » 10 Jul 2008, 08:53
Sadly the schematic contains at least two mistakes:
1.) A missing 470k from the base of the input buffer to Vref.
2.) The 100k resistor at the last transistor of the EQ-section should connect to the base (instead of the collector) and the collector should connect to V+
And missing is the information if the trannies are -O, -Y, -GR or -BL types.
The diode at the base of the power-supply transistor is a zener diode with 9,1 V.
Anyway, thanks for the trace,
For this message the author analogguru has received thanks:
Have thanks: 116 times
Postby Bernardduur » 10 Jul 2008, 13:25
analogguru wrote:Sadly the schematic contains at least two mistakes:
Thanks man!
I'll check em!
Edit:
You were right :) I replaced the schematic with a new one. Transistors are of the GR type. Zener is 9.1V. Can't say much on the diodes other that they measure 0.646V (silicon diodes I guess; no markings on em) and 0.305V (germanium diodes I guess; again no markings).
Bernardduur
Postby seniorLoco » 11 Jul 2008, 02:53
Nice job B ....thanks! :applause:
seniorLoco
Have thanks: 10 times
Postby mailoszyarr » 10 Sep 2014, 19:51
Hi!
Link to schematic doesn't work. Can you give a new link?
Thanks,
Milosz
mailoszyarr
Postby Bernardduur » 16 Sep 2014, 13:03
I'll send a copy to your mailadress and will post it again here!
Bernardduur
Postby 287m » 25 Jan 2015, 17:51
hi Mr B
where the scheme? please, count me in :D
i want build this :D
Thanks very billion much. hehe
287m
Has thanked: 329 times
Have thanks: 57 times
Postby Franzki » 21 May 2015, 23:00
Would love to have the schematic as wel... bought an Aria ProII Ultra Metal pedal but want to figure out how the overdrive section works... I counted at least 6 diodes in the signal path...
Franzki
Postby modman » 21 May 2015, 23:29
Sent a pm;
Could you please reup the schematic, attach or if you like to have a partition of the fsb server for ftp upload, lemme know. I think I already proposed this before..."
Has thanked: 3283 times
Have thanks: 611 times
Re: Aria - AUM-1 "Ultra Metal"  [schematic]
Postby Bernardduur » 25 May 2015, 12:23
For this message the author Bernardduur has received thanks: 3
Franzki (29 May 2015, 01:39), modman (27 May 2015, 10:18), TWAlex (09 Aug 2016, 20:51)
Bernardduur
Postby EddieTavares » 25 May 2015, 13:53
This is a Boss HM-2 with minor diference, OK?
I have one but I duno where it is. Its noisy and harshy, I tried to mod but after that it sounds more like a DS-1 nothing about the "metal".
EddieTavares
Have thanks: 17 times
Re: Aria - AUM-1 Ultra Metal
Postby Franzki » 29 May 2015, 01:50
I recently bought the Aria... It may not be a real `metal` distortion but I like the way the sound cleans up when I keep the volume low on my guitar. Unfortunately the distortion taper is not working well anymore in the lower regions... but running this pedal in a low gain mode would probably make it great for blues and rock overdrive.
Franzki
Postby soulsonic » 29 May 2015, 02:17
Franzki wrote:I recently bought the Aria... It may not be a real `metal` distortion but I like the way the sound cleans up when I keep the volume low on my guitar. Unfortunately the distortion taper is not working well anymore in the lower regions... but running this pedal in a low gain mode would probably make it great for blues and rock overdrive.
I can't speak for the Aria, but the HM-2 has a really bad taper toward the bottom of the Gain control. From about 8 o'clock to 9:30-10:00, it jumps from almost low gain to almost maximum distortion and doesn't get very much more distorted the higher you turn it past that.
It does clean up very well, too, and I think the fuzzy edge of it gives it a unique tone for more of a fuzz than distortion sort of sound.
Postby Manfred » 25 Jul 2016, 01:17
I have got a Ken Multi MUM-7 for repair, it is identical in construction with the Aria AUM-1.
I found out the types of clipping diodes as follows.
The Silizium diodes are all 1N914 and both Germanium diodes are 1N34A.
Manfred
Has thanked: 1048 times
Have thanks: 629 times
Users browsing this forum: dgc85, fretless and 7 guests
