Caline Mark 4  [schematic]
Caline Mark 4
Postby Dr Bertson » 24 Aug 2016, 17:05
Hello Everyone!
I got the Caline Mark 4 today and has started to trace this pedal.
After when it's finished, I will post the schematic here.
Dr B
For this message the author Dr Bertson has received thanks:
lolbou (24 Aug 2016, 20:32)
Dr Bertson
Have thanks: 30 times
Re: Caline Mark 4
Postby Dr Bertson » 26 Aug 2016, 11:33
Hello Everyone!
Here comes the schematic of the Caline Mark 4 Distortion.
I have tested this schematic on a breadboard and compare it to the real pedal and both sounds almost the same.
I have also tried some different IC's, OPA 2134, OPA 2604, RC 4558P, JRC 4580, NE 5532 and LM 833.
All of them sounds good with a little different in gain.
The best reult I got with the JRC 4558D (original) and the OPA 2604 (this sounds a little bit more HiFi).
Caline Mark 4 _1.pdf
Enjoy!
Dr B
For this message the author Dr Bertson has received thanks: 9
Andy2No (11 Sep 2016, 17:57), Dirk_Hendrik (26 Aug 2016, 14:26), dv8r601 (11 Sep 2017, 02:25), Intripped (26 Aug 2016, 22:25), LowEnd (01 Nov 2017, 03:57), Manfred (26 Aug 2016, 21:07), Nocentelli (27 Aug 2016, 11:57), tbo (06 Dec 2018, 23:47), TWAlex (26 Aug 2016, 22:33)
Dr Bertson
Re: Caline Mark 4
Postby Dr Bertson » 26 Aug 2016, 18:16
Hello Everyone!
I have discovered that this pedal is a gem, because if I put this pedal before my homemade Mesa Bbogie Mark IV pedal (I built this about 4 years ago), then the pedal gives a good crunch in the Mark V pedal.
The Caline Mark 4 is a very simple circuit, but it sounds very good.
You can search for the schematics for Mesa Boogie Mark IV on the web, built this and put the Caline Mark 4 before it, then you got a good pedal.
Dr B
Dr Bertson
Re: Caline Mark 4
Postby Dr Bertson » 26 Aug 2016, 18:18
I have found a error in the schematic.
The diode labled D5 that is in the power line, should be labled D6 and it's a 1N4007.
Dr B
Dr Bertson
Re: Caline Mark 4
Postby Manfred » 13 Sep 2016, 22:38
Some shots:
Andy2No (20 May 2018, 11:18), dv8r601 (11 Sep 2017, 02:24), modman (08 Apr 2017, 23:04)
Has thanked: 982 times
Have thanks: 531 times
Re: Caline Mark 4
Postby Manfred » 15 Sep 2016, 09:09
I inserted the passive compont identifier according to the assembly print into the drawing
and corrected the LED identifier.
Andy2No (20 May 2018, 11:21), dv8r601 (11 Sep 2017, 02:26)
Re: Caline Mark 4  [schematic]
Postby Manfred » 15 Sep 2016, 09:34
I I am thinking about to adding a simple tone control, and found that the value of the R12 resistor is to low.
I measured the value and read about 50 KOhms in parallel with VR3 on the right stop.
The Value is 100 kOhms not 10 KOhms.
For this message the author Manfred has received thanks: 8
Andy2No (20 May 2018, 11:21), dv8r601 (11 Sep 2017, 02:26), InZik (22 Dec 2018, 15:22), mirosol (09 Sep 2017, 21:00), modman (08 Apr 2017, 23:04), roseblood11 (10 Sep 2017, 00:11), Skip331 (13 Jun 2017, 01:44), Zokk (15 Sep 2016, 10:17)
Re: Caline Mark 4
Postby roseblood11 » 14 Sep 2017, 20:20
What about a variable resistor in series with the 6n8 as a simple tone control? Or have you tried s.th. else?
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Re: Caline Mark 4
Postby roseblood11 » 27 Sep 2017, 20:13
The pedal sounds great, but it could be more versatile with (at least) a little more control over the high frequencies. What about adding the tone and presence control of the Crunch Box V2 or maybe even the TMB tonestack of the Guv'nor/Drivemaster, maybe modified to the values of the tonestack in the real Boogie Mk4?
http://1.bp.blogspot.com/-0zGoV3jSwJs/T ... tv2rx7.jpg
http://2.bp.blogspot.com/-kbEEXqIxX2A/T ... guvnor.gif
roseblood11
Re: Caline Mark 4
Postby Chugs » 27 Sep 2017, 21:45
Look at the MI Audio Tubezone for some tone control ideas.
The topology of the Caline appears to be a simplified version of the Tubezone.
Chugs
Has thanked: 59 times
Have thanks: 49 times
Re: Caline Mark 4
Postby roseblood11 » 27 Sep 2017, 22:14
Interesting! Do you have a schematic for the Tubezone (6 knob)? All I found was dead links
roseblood11
Re: Caline Mark 4
Postby Chugs » 27 Sep 2017, 22:18
Here you go...
For this message the author Chugs has received thanks: 4
blackboarcult (05 Feb 2019, 10:52), Manfred (28 Sep 2017, 03:02), mr coffee (29 Jan 2018, 17:57), roseblood11 (27 Sep 2017, 23:37)
Chugs
Re: Caline Mark 4
Postby DanAmpora » 22 Jan 2018, 13:48
It looks like C8 (2u2) should be the other way around.
DanAmpora
Have thanks: 22 times
Re: Caline Mark 4
Postby caspercody » 15 Jan 2019, 20:05
I made this pedal, using a vero board I created. The first gain stage works, but when I start to turn the gain 2 pot up, I get some weird noise. Just a little turn of the gain 2 pot I can start to hear a difference in the gain get dirtier, but once I start to turn the gain 2 pot more I get a loud shrieking sound. As I turn the gain 2 pot more clockwise it turns into wired noise, seems to get lower in frequency and reminds me of video game noise. Here are the voltage readings of the IC pins:
1 = 4.43
2 = 4.43
3 = 3.99
4 = 0
5 = 4.37
6 = 4.43
7 = 4.43
8 = 8.86
Voltage reading at source is 9.48 vdc. Any thought on why I am getting this weird noise on gain stage 2?
Rob
For this message the author caspercody has received thanks:
Manfred (16 Jan 2019, 01:00)
caspercody
Has thanked: 30 times
Have thanks: 43 times
Re: Caline Mark 4
Postby caspercody » 19 Jan 2019, 22:13
I found my mistake, missing (1) more cut. Now this is verified.
caspercody
Users browsing this forum: JimSalabim and 8 guests
