Diezel VH4 Pedal  [schematic]
Re: Diezel VH4 Pedal
Postby caspercody » 06 Nov 2017, 17:57
What do you use to attach the voltage regulator to the board? To help heat sink it.
caspercody
Has thanked: 30 times
Have thanks: 47 times
Postby bmxguitarsbmx » 06 Nov 2017, 23:38
caspercody wrote:What do you use to attach the voltage regulator to the board? To help heat sink it.
To sink what heat? Not being snotty, but the TO-220 package could easily be dropped to a TO-92 package and use only air cooling:
https://www.mouser.com/ProductDetail/ON ... %2fRhHA%3d
^100mA TO-92 12V linear regulator
bmxguitarsbmx
Has thanked: 271 times
Have thanks: 83 times
Postby caspercody » 07 Nov 2017, 16:07
I ordered a kit, and it came with the LM2940CT-12.
caspercody
Postby Svullgo » 08 Nov 2017, 17:25
First I wanna say thanks to all you heroes who put down a lot of time in this community and sharing your results and knowledge!
You have helped me a lot in learning and understanding the electronics of pedals!
I have built this after Alex Vero at tagboardeffects and everything works. (I needed to up the the 47p capacitor to 560p as reichi suggested to get rid of the oscillation/feedback on higher gain levels)
I wonder if the presence and resonance works as the original (which I never have tested)
The presence lowers the the perceived volume a lot when turned down and resonance feels like its to much in the lower midrange. (but thats what Bajaman on page 4 says that they should do but have anyone have had the opportunity to A/B-test it with an original?)
Svullgo
Postby Daza » 09 Nov 2017, 18:44
I set the bass version, and I also have oscillation with high gain (around 12 o'clock) I'll see if it goes down changing the 47p
Daza
Postby Daza » 09 Nov 2017, 18:49
Daza wrote:I set the bass version, and I also have oscillation with high gain (around 12 o'clock) I'll see if it goes down changing the 47p
I set the bajaman version, and I also have oscillation with high gain (around 12 o'clock) I'll see if it goes down changing the 47p
Daza
Postby brejna » 09 Nov 2017, 20:02
It does, but pedal sound muddier...
brejna
Has thanked: 66 times
Have thanks: 57 times
Postby bmxguitarsbmx » 09 Nov 2017, 21:37
The real way to tame oscillation is to examine the layout. IMO
For this message the author bmxguitarsbmx has received thanks:
J0K3RX (10 Nov 2017, 03:53)
bmxguitarsbmx
Postby Daza » 10 Nov 2017, 01:23
It would not be good muddy sound.
I put shielded cable and it improved a bit. Increasing the depth increases the oscillation considerably
Daza
Postby Daza » 10 Nov 2017, 03:06
Will you have a problem with the input impedance the scheme?
I put a buffer before the pedal as recommended by Brejna and the oscillations disappeared!
For this message the author Daza has received thanks:
bmxguitarsbmx (11 Nov 2017, 00:05)
Daza
Postby J0K3RX » 10 Nov 2017, 06:07
I wouldn't bother with shielding the output... I would shield the input and definitly the gain pot! Poke around with an audio probe and it should lead you right to the source of the oscillation...
For this message the author J0K3RX has received thanks:
bmxguitarsbmx (11 Nov 2017, 00:04)
J0K3RX
Has thanked: 326 times
Have thanks: 515 times
Postby bmxguitarsbmx » 11 Nov 2017, 00:07
I wish I could attribute this quote pertaining to pcb layout:
"rarely will stray capacitance to ground cause the problems that stray capacitance between any other traces have".
Shield it up! Proximity/phase is also worth considering.
bmxguitarsbmx
Postby sego91 » 12 Nov 2017, 18:24
Im gonna try to replace the 7660s with another IC to eliminate the oscilation and squeel, maybe a 1054 im gonna check it out .
sego91
Has thanked: 10 times
Have thanks: 9 times
Postby RockKenny » 02 Dec 2017, 19:07
sego91 wrote:Im gonna try to replace the 7660s with another IC to eliminate the oscilation and squeel, maybe a 1054 im gonna check it out .
Hi! Any good news after changing 7660? I'm also have oscillation problem & no ideas how to fix...
RockKenny
Have thanks: 2 times
Postby temol » 13 Dec 2017, 10:08
I've completed my VH4 build. Worked on first try, no oscillation. Because I did not have 25kC potentiometers, I used 25kB with an additional resistor, which was supposed to change the pot characteristics from LIN to ANTI-LOG. Unfortunately, it does not work as it should. In my opinion it still works as a linear potentiometer. It worked on a breadboard - I connected battery to the potentiometer, measured voltage, plotted a curve - definitely C characteristics. Maybe I should try with a lower resistor value. Now it's a 5k1 across leg 2 and 3.
T.
temol
Has thanked: 13 times
Have thanks: 132 times
Postby Silverhair » 13 Dec 2017, 20:42
Maybe the TC1044SCPA, in this version they use it: http://www.pedalpcb.com/product/valhalla/
Silverhair
Postby temol » 13 Dec 2017, 22:56
I have 7660SCPAZ in my build and no oscillation.
T.
For this message the author temol has received thanks:
bajaman (14 Dec 2017, 00:34)
temol
Postby bajaman » 14 Dec 2017, 00:34
nice build :D
Has thanked: 447 times
Have thanks: 1536 times
Postby RockKenny » 14 Dec 2017, 01:20
temol wrote:I have 7660SCPAZ in my build and no oscillation.
T.
What kind of 7660 do you use? I mean firs letters.
I have oscillation with ICL7660SCPA.
RockKenny
Postby bajaman » 14 Dec 2017, 01:45
No problem with any oscillation my board layout as Temol has found :roll:
Users browsing this forum: No registered users and 13 guests
