Diezel VH4 Pedal  [schematic]
Re: Diezel VH4 Pedal
Postby psychepool » 20 Apr 2018, 09:12
I read all the contents and try to make my own layout. I have some questions that I need to confirm.
1. I want to run it through the 9v power supply for convenience.
I am going to get 9v and drive it by making bipolar doubler through 7660 or 1054.
What is worrisome is whether to supply 18v bioplar power or 12v bipolar power through a 12v regulator.
Is the 18v bipolar power source too much choice? Is it better to supply 12v through the regulator?
2. Are R28 and R34 100R or 1K?
3. There is a controversy about the tone stack in connection with the middle pot connection.
Is it correct to connect according to the current circuit diagram? Or is it just like connecting a vintage amp with a tone stack?
Thank you for always helping me to do happy DIY. please answer about my question.
psychepool
Have thanks: 19 times
Postby mnemonic » 21 May 2018, 22:27
I finally got around to building this pedal on Bugg's PCB. Great pcb as always, sounds great and works perfect.
I used the requisite TC1044SCPA and its silent, no switching noise.
pictures attached.
For this message the author mnemonic has received thanks:
sixthfloor (23 May 2018, 15:24)
mnemonic
Have thanks: 5 times
Postby the_ungod » 24 May 2018, 11:10
Does any one knows whats the point of the send? I understand that it may be a buffer if we dont make the pedal true bypass. But using a 3PDT does it make sense to include C3 and R4?!
the_ungod
Have thanks: 7 times
Postby Optical » 25 May 2018, 02:19
It's useful as a key input for noise gates or recording a dry signal.
Other than that you can leave it out
Optical
Have thanks: 13 times
Postby icziko » 29 May 2018, 21:58
Guys, thanks for this fantastic schematic and this thread - it is very useful and informative.
I built using Tagboard layout and pedal sounds fantastic.
I had problem with oscillation when gain is above 60%. I tried option with 560pF instead of 47p in C10 but additional cap decreased gain a lot and entire pedal became muddy. I prefered to have better sound but oscillation above 60%.
After, I used JHS Little Black Buffer in front of pedal (clone also as per Tagboard layout) and I can crank gain to 100% without any oscillation except when my MIDS are really hi (like 70-80%) and gain at 100% than oscillation came back. Anyway I did not plan to use total gain but I will try idea to shorten connection wires between pots and board. But just to let You know, buffer pedal helps a lot but not fixed situation completely.
I also had some squeal floor noise/background - I could play but it was annoying - I figured out I used 7660A instead of 7660S. Change to 7660S solved noise issue.
I have a question - maybe somebody had similar issues so it could help me out.
My Gain Pot from 0-40% of rotation is giving me clean sound. Then between 40-50% there is big jump and it gives me hi gain stuff. It does not look like original pedal shown on Youtube. Generally on promo videos I saw that this pedal can also deliver some blues crunchy stuff, however in my situation it gives me clean to 40% and then hi gain stuff.
I already replaced pot because I thought it might be good solution but I was wrong thus gain pot is still as it is.
Does anybody have similar issue?
icziko
Postby eddyc666 » 28 Jun 2018, 19:05
Hey guys,
Normally i tend to stick to reading and building, but there is something i dont understand about this build that isnt mentioned already..
The 10R resistors! (R38/R39) By the looks of the original pedal and the diy builds in this thread everybody uses 1/2watt resistors.. Arent they way to small considering the voltage that passes true them? Whats up with that! .. Is it because normal resistor wattage calculations are based on worst case scenario's? Or am i missing something?
Like i said i cant wrap my head arround it and its driving me crazy! :whappen: Thanks.. Also for this great forum and thread i love it!
eddyc666
Postby bmxguitarsbmx » 29 Jun 2018, 08:53
Ohms law says Power equals Current squared multiplied by resistance.
P=I^2 xR
I would be "supply current" on the op-amp datasheet added up for each op-amp.
For this message the author bmxguitarsbmx has received thanks:
eddyc666 (29 Jun 2018, 17:14)
bmxguitarsbmx
Has thanked: 268 times
Have thanks: 82 times
Postby eddyc666 » 29 Jun 2018, 17:27
bmxguitarsbmx wrote:Ohms law says Power equals Current squared multiplied by resistance.
P=I^2 xR
I know a little bit about ohms law but i always based my calculations on the Voltage of the circuit. And in this case that would tell me i needed one giant resistor.. If i make my calculation based on amps like you suggest the opamps combined would need a max of 10mA so the wattage minimum of the 10R resistors are only 0.001watt which makes much more sense... Thank you very much for answering my noob question.. :block:
eddyc666
Postby bmxguitarsbmx » 30 Jun 2018, 19:22
No problem man. You would need giant 10 ohm resistors if they were going directly to ground. But these 10 ohm resistors are feeding the rest of the analog circuitry. They are there to RC filter out noise that might be left over from the lt1054 voltage converter, which does some chopping up of the voltage to derive the negative supply.
You can use ohms law to find the voltage drop across this one of these 10 ohm resistors.
E= I*R. We'll use your value of 0.01A*10ohms = 0.1V drop.
bmxguitarsbmx
Postby dsvilanova » 13 Sep 2018, 14:38
edy_wheazel wrote:I also build mine a while ago with the PCB I posted.
Depending on the tone settings I also have a whistle when I turn the Gain up, but I don't use it at the max anyway.
Overall it's a kick-ass pedal! Try to use "C" pot's for "Presence" and "Deep", I used liniar ones and, as Bajaman said, the entire spectrum is available on around 15% of the pot's range. Also, I have the impression that the "Gain" and "Vol" pot's range is not liniar, but maybe it's just my impression and it' not a problem anyway.
Thanks for the schematic, it's a fun build!
Hi, I also have that whistle, any suggestions to solve it? This 'high feedback" is pretty bad :| I'm using pots B type for presence & deep, the circuit is on a veroboard, from tagboard effects.
Thanks anyway!
dsvilanova
Postby caspercody » 13 Sep 2018, 14:55
I put a buffered pedal right before the VH4, and I get not whistle. If I remove the buffer before the VH4, it whistles.
For this message the author caspercody has received thanks:
dsvilanova (13 Sep 2018, 15:08)
caspercody
Has thanked: 30 times
Have thanks: 44 times
Postby dsvilanova » 13 Sep 2018, 15:11
caspercody wrote:I put a buffered pedal right before the VH4, and I get not whistle. If I remove the buffer before the VH4, it whistles.
Interesting! I did everything, but not this :D
I will test some buffer before, thanks man.
dsvilanova
Postby dsvilanova » 14 Sep 2018, 12:58
Nope, connecting a buffer before VH4 didn't solve the whistle. The question is: does the original do it? The last try will be use the pots C type.
dsvilanova
Postby edy_wheazel » 23 Sep 2018, 00:29
dsvilanova wrote:Hi, I also have that whistle, any suggestions to solve it? This 'high feedback" is pretty bad :| I'm using pots B type for presence & deep, the circuit is on a veroboard, from tagboard effects.
Thanks anyway!
I left it that way. Have more then enough gain before the whistle starts :))
edy_wheazel
Have thanks: 25 times
Postby jhergonz » 16 Oct 2018, 16:36
A question for Mr. Bajaman :D . I saw that you compared the Diezel VH4 pedal to Friedman BE-od. Would you mind comparing Vh4 to your own design of VH4? i'm just curious. Please notice this. :cheers :cheers :cheers
jhergonz
Has thanked: 52 times
Postby vagos21 » 10 Nov 2018, 16:58
Hello everyone! I've been through the painstaking process of designing my own layout 3 times till I got one that doesn't oscillate at Max settings in all pots. Thinking this was a success, it still miserably fails at the voltage converter section. I tried both max1044 and 7660SCPAZ but still get the darn squeal from both! And yes it is not the first time I build it, and yes I've connected to pins 1 and 8 for the frequency boost.
I even disconnected the converter chip and ran it on a custom +/-15V supply. The thing works perfectly without any oscillations...
Anyone interested to check it out? I wouldn't mind sharing my layout since it's stable and would make people happy :
For this message the author vagos21 has received thanks:
DoomchildXXL (15 Jan 2019, 16:01)
vagos21
Postby syamilaliff » 26 Nov 2018, 04:21
vagos21 wrote:Hello everyone! I've been through the painstaking process of designing my own layout 3 times till I got one that doesn't oscillate at Max settings in all pots. Thinking this was a success, it still miserably fails at the voltage converter section. I tried both max1044 and 7660SCPAZ but still get the darn squeal from both! And yes it is not the first time I build it, and yes I've connected to pins 1 and 8 for the frequency boost.
Would you mind sharing your layout here?
Or you can email me at syamilaliff@gmail.com
Thank you!
syamilaliff
Postby DoomchildXXL » 15 Jan 2019, 16:01
I'd happily take a stab at a new layout, too. :horsey: I can't stop my weasel from screeching either. :scratch:
DoomchildXXL
Have thanks: 3 times
Postby EdCh3n » 17 Jan 2019, 12:37
Greetings guys.
I built this pedal using Bajaman designed PCB bought from UK-electronic. (great layout, very easy to work with)
Initially it oscillated pretty badly when the gain is turned past 1 - 2 o' clock (and when deep is turned up past 3 o' clock). I was messing with the wiring with the back open when I noticed the oscillation would go away when I touched the input cable (the wire that goes from tip of input jack to the board). Without really understanding why, I replaced the input cable (standard insulated solid core) with a shielded cable, and connected the shielding layer to the ground. Now the pedal doesn't oscillate at all even with everything cranked.
Sounds killer!!!!
I would recommend everyone with oscillation problems to give it a go. And can someone who understands electronics please explain why?
Many thanks in advance!!
Ed
For this message the author EdCh3n has received thanks: 2
bajaman (18 Jan 2019, 04:50), bossman (21 Mar 2019, 20:00)
EdCh3n
Have thanks: 2 times
Postby jhergonz » 18 Jan 2019, 03:25
I'am no expert, but maybe this is the reason why we must use shielded wire when not mounting the I/O jacks and pots when building high gain distortions, and maybe your fingers act like a ground(I'm not really sure, so please correct me if I'm wrong.)
jhergonz
Users browsing this forum: No registered users and 11 guests
