Diezel VH4 Pedal  [schematic]
Re: Diezel VH4 Pedal [Gut shots]
Postby zamguitar » 22 Dec 2016, 19:39
For this message the author zamguitar has received thanks: 13
bmxguitarsbmx (20 Jun 2017, 18:53), dv8r601 (05 Sep 2017, 02:00), Fermusicman (12 Jan 2017, 03:43), kingplank (27 Jan 2018, 16:00), Manfred (22 Dec 2016, 21:01), modman (20 Jun 2017, 12:07), ms691 (03 Sep 2017, 21:29), orcl2 (02 Apr 2017, 14:57), rcustoms (22 Dec 2016, 20:34), sledgehammer (03 Feb 2017, 21:54) and 3 more users
zamguitar
Has thanked: 21 times
Have thanks: 15 times
Postby rcustoms » 22 Dec 2016, 20:37
zamguitar wrote:
is 100% ok or there something so so in the final schematics
guitars,pedals and amps.
@zuleta.rafael(Instagram)
rcustoms
Has thanked: 346 times
Have thanks: 490 times
Postby Manfred » 22 Dec 2016, 21:09
D3,D4 looks like D1,D2,D5,D6 to me.
Did you measure the Diodes?
Manfred
Has thanked: 976 times
Have thanks: 523 times
Postby zamguitar » 22 Dec 2016, 21:18
rcustoms wrote:
Didn't build yet. But I'm pretty sure that the schem will give close results.
Just need to figure out the D3 and D4 zener values.
zamguitar
Postby zamguitar » 22 Dec 2016, 21:21
Manfred wrote:D3,D4 looks like D1,D2,D5,D6 to me.
Just drew from the pictures, D3 and D4 are indeed 500mW zener diodes with the 1n5XX code.
zamguitar
Postby rcustoms » 22 Dec 2016, 22:46
awesome work zamguitar,i design the pcb layout ,in this days
For this message the author rcustoms has received thanks:
zamguitar (22 Dec 2016, 23:12)
rcustoms
Postby Manfred » 23 Dec 2016, 00:05
For this message the author Manfred has received thanks:
zamguitar (23 Dec 2016, 00:06)
Manfred
Postby Manfred » 23 Dec 2016, 00:16
Who can check the clipping voltages of both polarities with an oscilloscope?
Manfred
Postby Manfred » 23 Dec 2016, 00:29
Why does the edit function sometimes not work?
I meant the pointed out position.
Manfred
Postby mozwell » 23 Dec 2016, 02:15
A simple way to check what the zener is without removing it.
POWER OFF the unit
Get a 9V battery, connect battery negative to the anode of the zener, connect the cathode of the zener to the 9V battery positive THROUGH A 1k RESISTOR.
Using a multimeter, measure the voltage across the zener
I would guess these are 3.3V zeners, or maybe even as low as 2.4V
mozwell
Has thanked: 22 times
Have thanks: 69 times
Postby Manfred » 23 Dec 2016, 02:52
Manfred wrote:Why does the edit function sometimes not work?
You are right, that is the easiest way to measure the zener voltages. :thumbsup
Manfred
Postby Manfred » 23 Dec 2016, 12:47
POWER OFF the unit
Here again, I quote my self in the last post . :slap:
Manfred
Postby sebjus » 04 Jan 2017, 10:48
Hi. anyone build a VH4 klone, based on a this schematic?
sebjus
Have thanks: 2 times
Postby RogerDude » 25 Jan 2017, 14:58
Hi, thanks for the schematic! I was waiting for this :)
I've build it and it looks like there is some kind of problem around IC1.
It generates a high pitch noise and seems to have something like a grounding issue or some kind of connection missing.
The gain pot reacts more like and gain on/off switch then gradually changing gain level.
After IC1 it seems to be working ok (EQ, pres, deep). The mistake might be in my build but I have checked it pretty thoroughly.
Anybody else who has build this?
Any thoughts? Different results?
For this message the author RogerDude has received thanks:
modman (10 Aug 2017, 14:02)
RogerDude
Postby gu50-freak » 21 Mar 2017, 19:29
Hi together,
The diodes are 1N5232. Could read 1N5 on one of them and 232 on the other one.
Measured both with app. 5.6V.
Regards
For this message the author gu50-freak has received thanks: 4
bmxguitarsbmx (21 Jun 2017, 04:39), dv8r601 (05 Sep 2017, 02:01), sledgehammer (22 Mar 2017, 18:59), zamguitar (21 Mar 2017, 23:06)
gu50-freak
Have thanks: 4 times
Postby Dave37LP » 29 Mar 2017, 08:02
Apparently the voltages of the D3 & D4 zeners are labelled on their respective silksreen layouts, under the diodes, they could be read as "5V6" for instance. Please try to bend the leads carefully to verify my guess, make us that favor.
Thanks in advance.
Dave
Dave37LP
Has thanked: 25 times
Have thanks: 3 times
Postby 440hz » 20 Jun 2017, 03:11
kh602 wrote:
J0K3RX wrote:kh602, excelent pics! Hate to bother you further but, do those pots have any values on them that you can see without lifting them? I have a few pots like that so I am fairly sure the values are on the bottom facing the board.. We can probably guestimate what they should be in the tonestack since it looks like your average marshall type stack with standard values judging from the cap and resistor values.
Measured values of the pots (most are in rheostat config, i assume master and treb are potential dividers at a glance).
Gain pot = 159.7k
Bass pot = 566k
Mid pot = 24.82k
Treb Pot = 262.3k
Master Pot = 10.93k
Pres Pot = 21.07k
Deep pot = 25.35k
Hope this helps
Did you measure those with a multimeter while they were still wired into the circuit?
I've always heard that you can't measure resistance when the resistor in question is still hooked up to the rest of a circuit. Is there any reason that it would work in this case?
440hz
Have thanks: 5 times
Postby bajaman » 20 Jun 2017, 08:52
R26 and R34 are 1k not 110R :wink:
For this message the author bajaman has received thanks: 3
modman (20 Jun 2017, 12:06), sledgehammer (20 Jun 2017, 17:43), zamguitar (20 Jun 2017, 15:20)
Has thanked: 438 times
Have thanks: 1506 times
Postby bajaman » 21 Jun 2017, 02:07
guess what I am doing with all the nice gut shot pictures :hmmm: :wink:
bmxguitarsbmx (21 Jun 2017, 04:32)
Postby bmxguitarsbmx » 21 Jun 2017, 04:35
bajaman wrote:guess what I am doing with all the nice gut shot pictures :hmmm: :wink:
Making magic happen? :D
I'd like to breadboard this. I realize these are 400V caps, but could C11 really be only 4n7? Seems a bit small for that late in the gain stages...
bmxguitarsbmx
Has thanked: 263 times
Have thanks: 76 times
