Diezel VH4 Pedal  [schematic]
Re: Diezel VH4 Pedal
Postby bajaman » 21 Jun 2017, 06:53
from the photos C8 is 2200p 630v and C11 is 4700p 630v :wink:
bmxguitarsbmx (21 Jun 2017, 23:46)
Has thanked: 447 times
Have thanks: 1535 times
Postby bajaman » 21 Jun 2017, 06:56
I am pretty certain it would sound the same with less expensive 100v capacitors though perhaps they used 630v types to justify the high price of the pedal or maybe , being a tube amplifier manufacturer, they simply had lots of these high voltage capacitors in stock already :hmmm:
Postby bmxguitarsbmx » 22 Jun 2017, 00:03
bajaman wrote:I am pretty certain it would sound the same with less expensive 100v capacitors though perhaps they used 630v types to justify the high price of the pedal or maybe , being a tube amplifier manufacturer, they simply had lots of these high voltage capacitors in stock already :hmmm:
I agree you are probably right. The wima website is a very interesting read on capacitors: http://www.wima.de/EN/article.htm
The Wima FKP 4 series is an interesting one. Internally it is a series connection of two capacitors essentially.
Not to encourage cork sniffing, but I replaced every ceramic cap in my jcm800 with silver mica only to put it back to stock the very same day. Other amps sound top notch with silver mica, however.
Thanks for the verification Bajaman! :)
bmxguitarsbmx
Has thanked: 270 times
Have thanks: 83 times
Postby bajaman » 22 Jun 2017, 10:34
I finished the board layout and have uploaded it to OSH PARK as a shared project - file is: Weasel V84 pedal :secret:
Here are some pictures etc.
For this message the author bajaman has received thanks: 10
aishabag23 (11 Aug 2017, 21:35), apollomusicservice (22 Jun 2017, 17:48), bmxguitarsbmx (22 Jun 2017, 23:25), brddx1 (15 Sep 2017, 17:41), J0K3RX (24 Jun 2017, 05:08), jimini (23 Jun 2017, 21:18), modman (10 Aug 2017, 14:05), rcustoms (22 Jun 2017, 15:01), sledgehammer (22 Jun 2017, 18:19), zamguitar (22 Jun 2017, 16:50)
Postby bajaman » 22 Jun 2017, 10:36
Weasel V84 pedal.zip
The last file is the gerbers and drill files :wink:
Have fun
For this message the author bajaman has received thanks: 6
Belanger88 (27 Jun 2017, 17:54), brddx1 (15 Sep 2017, 17:43), bumblebee (15 Feb 2019, 01:49), J0K3RX (24 Jun 2017, 05:08), jimini (23 Jun 2017, 21:18), modman (10 Aug 2017, 14:06)
Postby rcustoms » 22 Jun 2017, 15:08
bajaman wrote:I finished the board layout and have uploaded it to OSH PARK as a shared project - file is: Weasel V84 pedal :secret:
great work bajaman,please post the final schematics ,i would like to do a single side pcb to share
thanks
Rcustoms
guitars,pedals and amps.
@zuleta.rafael(Instagram)
rcustoms
Has thanked: 348 times
Have thanks: 491 times
Postby bajaman » 22 Jun 2017, 22:18
Hello Rcustoms :D
thanks
The schematic posted previously in this thread by another member is correct - but as i mentioned R26 and R34 are 1k not 110R.
The back to back diodes are 5v6 zeners.
zamguitar (23 Jun 2017, 02:53)
Postby bajaman » 22 Jun 2017, 22:25
the previous pictures of the top and bottom layers are 300 dpi.
these further two pictures are half sized due to the forum restriction of 1M byte files :wink:
Postby bajaman » 22 Jun 2017, 22:28
Does anyone know where to purchase these horizontal mounting potentiometers ?
Postby 440hz » 23 Jun 2017, 07:10
Nice layout! Thanks for sharing.
OSHPark's pricing is $5 per square inch for 3 boards. Since your board measures 4.38x4.88 inches, that's 21.4 square inches, or about $107 for three boards.
That's just over $35 per board. Seems pricey. Are there any other PCB manufacturers that offer better pricing? Or is this really what you guys pay for boards?
440hz
Have thanks: 5 times
Postby 440hz » 23 Jun 2017, 07:18
Also, what size enclosure would this require? The 1590BB is the biggest I've used, and those measure 3.7x4.7 inches -- almost long enough in the longer dimension, but a half inch too short in the shorter dimension.
440hz
Postby bajaman » 23 Jun 2017, 09:05
OSH PARK also offer a medium run double layer service at $1 per square inch for a minimum 10 board order, ($214.00 for 10) which makes the single board price $21.40 :wink:
Postby bajaman » 23 Jun 2017, 09:08
The layout was traced directly from the Diesel pictures - so that is the size of the Diezel enclosure. Now where can one get those potentiometers :wink:
Postby bajaman » 23 Jun 2017, 10:13
update - found two small errors around C3 and C4 on my board layout - now corrected (Rev 1) file shared at OSH PARK :oops:
Postby 440hz » 23 Jun 2017, 16:03
bajaman wrote:Now where can one get those potentiometers :wink:
Are those not just your average right-angle PCB mount pots like these? http://www.taydaelectronics.com/potenti ... mount.html
440hz
Postby Jan1966 » 23 Jun 2017, 17:41
Jan1966
Has thanked: 13 times
Have thanks: 16 times
Postby bmxguitarsbmx » 23 Jun 2017, 18:57
bajaman:
What is your opinion on counterfeiting?
Do you feel that the market should not dictate the price of a product and that there should be some limit to what stompbox builders can earn?
Is there an "activist" role that DIY people should play to punish companies that charge above a reasonable limit?
Thanks! Curious to better understand these topics! :)
bmxguitarsbmx
Postby bajaman » 23 Jun 2017, 23:51
Hello bmxguitarsbmx
Since you are asking me personally on a public forum i will give you my answers - these are my opinions only and do not neccessarily reflect the views or opinions of any other member of this forum :wink:
I do not think counterfeiting is good if the counterfeiter is using another person or company's good business name in an attempt to sell their own product to the "marketplace" in an attempt to fool the potential purchaser that the product is genuine. Behringer produces a large number of products that are derived from other manufacturers designs circuit wise but they do not advertise them as Boss, ibanez, tech 21, QSC, Peavey, Mackie etc, products, so in this sense would you say that they are counterfeiting ? Many companies in mainland China produce musical instruments such as guitars where they are clearly offering counterfeit product displaying the true owner's name such as Gibson, Fender, Rickenbacker, MusicMan etc. I guess they do not view counterfeiting as a crime in China.
:roll:
Short answer is no to both questions :)
I don't believe so. If a company charges above a reasonable limit, they do not sell enough product to remain in business surely. I see no role for a DIY person to punish a company for any reason.
I do see DIY as a very satisfying way of learning how to build things differently - a great learning experience and very satisfying for the DIY builder when their actual build works first time, although this is not always the case and that is where the DIYer learns fault finding skills or enlists the help of more experienced DIYers to get his or her build working as desired. Incidentally many DIY folks that frequent this forum have gone on to become builders themselves and many of them produce fine products that are unique to them and not simply clones or copies of some one else's work - Brian Wampler comes to my mind.
bajaman :D
For this message the author bajaman has received thanks: 3
287m (22 Jul 2017, 09:08), bmxguitarsbmx (24 Jun 2017, 04:27), J0K3RX (24 Jun 2017, 05:13)
Postby bmxguitarsbmx » 24 Jun 2017, 04:35
bajaman,
I really appreciate your time and thoughtfulness in writing your response. :)
DIY is fun and a fantastic way to spend the evening time. I was part of the BE OD project going on, and this VH4 is also up my alley. I am conflicted about this stuff. I wouldn't want to have a negative effect on the market.
In general, I think that reversing these designs could actually push innovation. Possibly and hopefully ;)
Best wishes,
bmx
For this message the author bmxguitarsbmx has received thanks:
bajaman (24 Jun 2017, 05:43)
bmxguitarsbmx
Postby bajaman » 28 Jun 2017, 06:43
After a few nights work I have shrunken the layout to fit inside a Hammond 1590BB enclosure - it will also fit inside the equivalent NSC enclosure :wink:
I decided to cut the board down so that the potentiometers, and sockets are connected by flying leads - this reduces the pcb cost by 50% and allows the use of any style of potentiometer and socket etc. :)
I have placed an order with OSH PARK for the minimum 3 boards, so will probably have a spare board available at some stage. Once i have actually built and tested the pcb I will share the board on OSH PARK. I think this is the best way of doing things in case of any pcb errors - i will publish some pictures of the board and pedal in this thread once built and tested :thumbsup
In the meantime here are some top and bottom views of the board layout for you all.
For this message the author bajaman has received thanks: 5
440hz (30 Jun 2017, 02:34), bossman (15 Mar 2018, 18:29), lmkv15 (21 Sep 2017, 11:40), modman (10 Aug 2017, 14:09), sledgehammer (29 Jun 2017, 16:56)
Users browsing this forum: Iconnu, nagg and 10 guests
