Page 3 of 15
Re: Diezel VH4 Pedal
Posted: 21 Jun 2017, 05:53
by bajaman
from the photos C8 is 2200p 630v and C11 is 4700p 630v
Posted: 21 Jun 2017, 05:56
by bajaman
I am pretty certain it would sound the same with less expensive 100v capacitors though perhaps they used 630v types to justify the high price of the pedal or maybe , being a tube amplifier manufacturer, they simply had lots of these high voltage capacitors in stock already
Posted: 21 Jun 2017, 23:03
by bmxguitarsbmx
bajaman wrote:I am pretty certain it would sound the same with less expensive 100v capacitors though perhaps they used 630v types to justify the high price of the pedal or maybe , being a tube amplifier manufacturer, they simply had lots of these high voltage capacitors in stock already
I agree you are probably right. The wima website is a very interesting read on capacitors:
http://www.wima.de/EN/article.htm
The Wima FKP 4 series is an interesting one. Internally it is a series connection of two capacitors essentially.
Not to encourage cork sniffing, but I replaced every ceramic cap in my jcm800 with silver mica only to put it back to stock the very same day. Other amps sound top notch with silver mica, however.
Thanks for the verification Bajaman!
Posted: 22 Jun 2017, 09:34
by bajaman
I finished the board layout and have uploaded it to OSH PARK as a shared project - file is: Weasel V84 pedal
Here are some pictures etc.
Posted: 22 Jun 2017, 09:36
by bajaman
The last file is the gerbers and drill files
Have fun
Posted: 22 Jun 2017, 14:08
by rcustoms
bajaman wrote:I finished the board layout and have uploaded it to OSH PARK as a shared project - file is: Weasel V84 pedal
great work bajaman,please post the final schematics ,i would like to do a single side pcb to share
thanks
Rcustoms
Posted: 22 Jun 2017, 21:18
by bajaman
Hello Rcustoms
thanks
The schematic posted previously in this thread by another member is correct - but as i mentioned R26 and R34 are 1k not 110R.
The back to back diodes are 5v6 zeners.
Posted: 22 Jun 2017, 21:25
by bajaman
the previous pictures of the top and bottom layers are 300 dpi.
these further two pictures are half sized due to the forum restriction of 1M byte files
Posted: 22 Jun 2017, 21:28
by bajaman
Does anyone know where to purchase these horizontal mounting potentiometers ?
Posted: 23 Jun 2017, 06:10
by 440hz
Nice layout! Thanks for sharing.
OSHPark's pricing is $5 per square inch for 3 boards. Since your board measures 4.38x4.88 inches, that's 21.4 square inches, or about $107 for three boards.
That's just over $35 per board. Seems pricey. Are there any other PCB manufacturers that offer better pricing? Or is this really what you guys pay for boards?
Posted: 23 Jun 2017, 06:18
by 440hz
Also, what size enclosure would this require? The 1590BB is the biggest I've used, and those measure 3.7x4.7 inches -- almost long enough in the longer dimension, but a half inch too short in the shorter dimension.
Posted: 23 Jun 2017, 08:05
by bajaman
OSH PARK also offer a medium run double layer service at $1 per square inch for a minimum 10 board order, ($214.00 for 10) which makes the single board price $21.40
Posted: 23 Jun 2017, 08:08
by bajaman
The layout was traced directly from the Diesel pictures - so that is the size of the Diezel enclosure. Now where can one get those potentiometers
Posted: 23 Jun 2017, 09:13
by bajaman
update - found two small errors around C3 and C4 on my board layout - now corrected (Rev 1) file shared at OSH PARK
Posted: 23 Jun 2017, 15:03
by 440hz
bajaman wrote:Now where can one get those potentiometers
Are those not just your average right-angle PCB mount pots like these?
http://www.taydaelectronics.com/potenti ... mount.html
Posted: 23 Jun 2017, 16:41
by Jan1966
Posted: 23 Jun 2017, 17:57
by bmxguitarsbmx
bajaman:
What is your opinion on counterfeiting?
Do you feel that the market should not dictate the price of a product and that there should be some limit to what stompbox builders can earn?
Is there an "activist" role that DIY people should play to punish companies that charge above a reasonable limit?
Thanks! Curious to better understand these topics!
Posted: 23 Jun 2017, 22:51
by bajaman
Hello bmxguitarsbmx
Since you are asking me personally on a public forum i will give you my answers - these are my opinions only and do not neccessarily reflect the views or opinions of any other member of this forum
I do not think counterfeiting is good if the counterfeiter is using another person or company's good business name in an attempt to sell their own product to the "marketplace" in an attempt to fool the potential purchaser that the product is genuine. Behringer produces a large number of products that are derived from other manufacturers designs circuit wise but they do not advertise them as Boss, ibanez, tech 21, QSC, Peavey, Mackie etc, products, so in this sense would you say that they are counterfeiting ? Many companies in mainland China produce musical instruments such as guitars where they are clearly offering counterfeit product displaying the true owner's name such as Gibson, Fender, Rickenbacker, MusicMan etc. I guess they do not view counterfeiting as a crime in China.
Short answer is no to both questions
I don't believe so. If a company charges above a reasonable limit, they do not sell enough product to remain in business surely. I see no role for a DIY person to punish a company for any reason.
I do see DIY as a very satisfying way of learning how to build things differently - a great learning experience and very satisfying for the DIY builder when their actual build works first time, although this is not always the case and that is where the DIYer learns fault finding skills or enlists the help of more experienced DIYers to get his or her build working as desired. Incidentally many DIY folks that frequent this forum have gone on to become builders themselves and many of them produce fine products that are unique to them and not simply clones or copies of some one else's work - Brian Wampler comes to my mind.
Posted: 24 Jun 2017, 03:35
by bmxguitarsbmx
bajaman,
I really appreciate your time and thoughtfulness in writing your response.
DIY is fun and a fantastic way to spend the evening time. I was part of the BE OD project going on, and this VH4 is also up my alley. I am conflicted about this stuff. I wouldn't want to have a negative effect on the market.
In general, I think that reversing these designs could actually push innovation. Possibly and hopefully
Best wishes,
bmx
Posted: 28 Jun 2017, 05:43
by bajaman
After a few nights work I have shrunken the layout to fit inside a Hammond 1590BB enclosure - it will also fit inside the equivalent NSC enclosure
I decided to cut the board down so that the potentiometers, and sockets are connected by flying leads - this reduces the pcb cost by 50% and allows the use of any style of potentiometer and socket etc.
I have placed an order with OSH PARK for the minimum 3 boards, so will probably have a spare board available at some stage. Once i have actually built and tested the pcb I will share the board on OSH PARK. I think this is the best way of doing things in case of any pcb errors - i will publish some pictures of the board and pedal in this thread once built and tested
In the meantime here are some top and bottom views of the board layout for you all.
