Diezel VH4 Pedal  [schematic]
Re: Diezel VH4 Pedal
Postby bajaman » 26 Jul 2017, 10:06
Just checked the link at OSH PARK and it is working fine.
board is: Weasel V84 1590BB mini.zip
By the way, if you don't want OSH PARK to produce the board and you fancy doing it yourself, you can also download the gerber files and drill details in a zip file from the project page :wink:
Has thanked: 446 times
Have thanks: 1527 times
Postby bajaman » 26 Jul 2017, 10:10
So I used multisim 11 to differentiate a marshal tone stack with a fender tonestack to create the marshall response through my new fender clean channel.
hmmm - an interesting idea worthy of consideration for folks wanting to make their fender twin sound more like a plexi :hmmm: :wink:
Postby bajaman » 27 Jul 2017, 10:13
andlord (27 Aug 2017, 20:22)
Postby sledgehammer » 27 Jul 2017, 11:41
Since the minimum order are 3 PCBs - anyone interessted in teaming up to buy a PCB?
Me (located in Europe/Germany) and another forum user from the US are looking for others to split the order and reduce the shipping costs.
If there is someone interessted just write me a private message (so there is no additional spam here) and tell me where you are located.
And again thanks a lot for the time and design Bajaman - much appreciated.
For this message the author sledgehammer has received thanks:
bajaman (27 Jul 2017, 11:59)
sledgehammer
Have thanks: 2 times
Postby Neck-Pro » 27 Jul 2017, 12:35
I'm from the US and would like to put together an OSH park order with forum members as well. PM me if you are in the US and interested so we can get an order going.
Neck-Pro
Postby 12afael » 27 Jul 2017, 12:56
I will order 5 boards from pcbway soon. 5 is the minium. I´m in Finland so I could sell you one.
12afael
Postby 287m » 29 Jul 2017, 11:05
Hello, long time no building. I want this evilpedal so hard with my own layout
Some question :
- what alternative to LM2940ct-12? or can we not use this regulator?
- i see footswitch just use 2 pole. So, is okay with DPDT only then?
- where to get the cheapest 1590BS? like 1590B but more height.
Febri
287m
Has thanked: 313 times
Have thanks: 56 times
Postby Jan1966 » 29 Jul 2017, 12:25
287m wrote:- what alternative to LM2940ct-12? or can we not use this regulator?
Febri
Its just a 12 Volt regulator so check the data sheet for LM2940ct-12 and get any similar spec one.
Jan1966
Has thanked: 13 times
Have thanks: 16 times
Postby bajaman » 29 Jul 2017, 12:45
LM7812 will do fine
Postby 287m » 29 Jul 2017, 12:49
Febri
bajaman wrote:LM7812 will do fine
thanks Jan and Baja
time to place order at tayda :oops:
287m
Postby Jan1966 » 29 Jul 2017, 14:42
287m wrote:where to get the cheapest 1590BS? like 1590B but more height.
Febri
Also Rapid online and Farnell sell this enclosure but not sure if this is the price you wish to pay. The ones on ebay seem more expensive.
Jan
Jan1966
Postby LeeTab » 01 Aug 2017, 14:42
Hi guys, do you have a list of components by any chance, i really want to have a go and making one of these bad boys.
LeeTab
Postby andlord » 02 Aug 2017, 07:56
There is a schematic a few pages back. It should be enough so you can make a BOM on your own or you could use the gerber files from bajamans pcb and read the components printed in the silkscreen
For this message the author andlord has received thanks:
bajaman (02 Aug 2017, 09:59)
andlord
Have thanks: 5 times
Postby alltrax » 03 Aug 2017, 14:52
LeeTab wrote:Hi guys, do you have a list of components by any chance, i really want to have a go and making one of these bad boys.
Here you go
For this message the author alltrax has received thanks: 5
aishabag23 (11 Aug 2017, 21:31), bmxguitarsbmx (03 Aug 2017, 18:15), Chingon (13 Aug 2017, 17:55), DonDougie (15 Aug 2017, 19:47), LeeTab (08 Aug 2017, 16:49)
alltrax
Has thanked: 15 times
Postby 440hz » 04 Aug 2017, 04:29
Alternatively:
Code: Select all
Capacitors
1x   47p
3x   100p
1x   560p
1x   1n
2x   2.2n
1x   4.7n
4x   22n
1x   330n
4x   1u
3x   2.2u
2x   10u
5x   47u
Diodes
4x   1N4148
2x   1N5232         (Alternative: 1N4734 (which is 1W, whereas 1N5232 is 1/2W))
1x   LED
ICs
1x   LM2940CT-12      VR1   (Alternative: LM7812)
1x   OPA2134          IC1
1x   TC7660S          IC4
2x   TL072CP          IC2, IC3
Pots
1x   A10k
1x   A250k
1x   A1M
1x   B25k
1x   B250k
2x   C25k
Resistors
2x   10
1x   47
1x   100
2x   110
1x   2.2k      CLR
1x   4.7k
4x   10k
1x   39k
1x   56k
5x   100k
1x   150k
5x   220k
2x   470k
1x   680k
3x   1M
1x   1.5M
For this message the author 440hz has received thanks: 5
alltrax (04 Aug 2017, 09:42), Chingon (13 Aug 2017, 17:55), DonDougie (15 Aug 2017, 19:47), ms691 (12 Aug 2017, 00:21), Optical (12 Aug 2017, 12:49)
440hz
Postby andlord » 12 Aug 2017, 07:57
I got a batch of Bajamans PCBs produced and have some leftovers that i'd like to trade or sell.
(Big thanks to Bajaman for the great design and for allowing me to do that.)
Drop me a PN if interested.
bajaman (12 Aug 2017, 13:22)
andlord
Postby Optical » 14 Aug 2017, 07:21
I see there is a Version 2 of this pedal available now
http://deluxeguitars.com.au/effects/dis ... al-v2.html
Optical
Have thanks: 13 times
Postby alltrax » 14 Aug 2017, 11:11
There are 2 mistakes in by BOM above : R26 is 1k instead of 110 ohms, and R28 is 100 ohms instead of 1k
There are also a few in 440hz's one, I let you check
I finished building Bajaman's board and wow, what a great distortion, very different from the BE-OD as expected, sounds killer, well worth having both.
I must say that Bajaman's pcb is really great, very easy to solder :thumbsup
I have some squealing with the gain full open, from 8 to 10. I'll shield both in and out when boxing it
I didn't solder the regulator as I will use it on a good quality 9v power supply so jumped pins 1&3. With wall 9V V+ is 8,82 and V- 8,22
bajaman (14 Aug 2017, 11:18)
alltrax
Postby andlord » 14 Aug 2017, 12:43
Nuce work. I also started populating the board today but sadly I don't have all the parts in stock :(
andlord
Postby 440hz » 15 Aug 2017, 05:51
alltrax wrote:There are 2 mistakes in by BOM above : R26 is 1k instead of 110 ohms, and R28 is 100 ohms instead of 1k
If R26 was supposed to be 1k (rather than 110R), then the error was on the schematic, not our BOMs.
I knew 110R sounded odd. Now that I've taken a closer look at the gut shot, it looks like the color code is "brown black black brown," or 100 × 10^1 = 1k.
When I have a bit more time, I'll re-read this topic and make sure I didn't miss any other corrections. I'll try to post a corrected schematic, as well.
440hz
Users browsing this forum: b-spot, Google [Bot] and 8 guests
