PAL Fx JCM 800 Emulator
Re: PAL Fx JCM 800 Emulator
Postby Manfred » 12 Oct 2017, 19:30
J0K3RX wrote:Look here > http://www.uk-electronic.de/Download/Be ... JCM800.pdf
Most of the values will be the same...
Thanks, that looks good.
But there's one thing:
The middle pot wiring looks a little unfamiliar, but a traced the wiring on the shot and drew down the circuit as I had seen.
Maybe there was a wiring error.
Has thanked: 962 times
Have thanks: 508 times
Postby J0K3RX » 12 Oct 2017, 22:01
Take a closer look.. The wiper/lug 2 of the mid pot is going to the white connector gn2. Lug 3 of the mid pot is going to lug 1 on the bass pot. Lugs 2 and 3 of the bass pot are soldered together and then connecting to lug 1 of the treble pot...
J0K3RX
Has thanked: 318 times
Have thanks: 489 times
Postby J0K3RX » 12 Oct 2017, 22:03
The added tone adjustment trimmer is 10k
J0K3RX
Postby Manfred » 13 Oct 2017, 01:27
J0K3RX wrote:The added tone adjustment trimmer is 10k
Thanks, I going to revise the layout und the schematic.
Postby Manfred » 16 Oct 2017, 00:14
I made test DC-circuits for each stage and alter the trim pot setting until I could read the anoted drain voltages of the PCB shot.
After that i measured the trim pot values.
Here the results:
RD1 = 34 Kiloohms
RD2 = 98 Kiloohms
RD3 = 18 Kiloohms
RD5 = 15 Kiloohms
RD6 = 20 Kiloohms
The measured forward conductanceof the applied J201 = 1.8 Milliamps/Volts.
Postby Manfred » 16 Oct 2017, 22:30
The circuit simulation confirmed the measured trim pot values.
I am not entirely satisfied with the outcome.
All except one of the trim pot settings are in the range of a 47 Kiloohms.
The stage with the sources resistor value of 10 Kiloohms needs a trim pot setting of ~100 Kiloohms to achieve the noted drain voltage.
Where do the difference of the setting range of this stage come from?
Either the measured drain voltage is measured incorrectly or another JFET type id used.
Who knows, perhaps a trim pot with a value of 100 Kiloohm or more is installed in the origianl circuit.
Postby Manfred » 16 Oct 2017, 22:39
Typos corrections.
Why is EDIT-button sometimes not displayed and therefore the function cannot apply?
Either the drain voltage is measured incorrectly or another JFET type is used.
Who knows, perhaps a trim pot with a value of 100 Kiloohm or more is installed in the original circuit.
Postby Manfred » 18 Oct 2017, 03:51
Revised schematic and layout:
PAL_JCM800_PCB_ComponentSide_2.pdf
Zipped Sprint-Layout 6 file:
jcm2pcb.zip
For this message the author Manfred has received thanks: 4
FeVeR2112 (03 Nov 2017, 17:46), hyrk (05 Nov 2017, 19:34), Intripped (18 Oct 2017, 20:54), peterc (18 Oct 2017, 12:51)
Postby Optical » 20 Oct 2017, 06:26
Nice work. Based on this, you could modify the circuit slightly to achieve several other marshall variants such as the Freidman amps
Optical
Have thanks: 13 times
Postby roseblood11 » 20 Oct 2017, 18:39
It would be great to have a pcb with the option to build many different circuits that are based on Marshall designs.
Maybe uk-electronic.de could sell them?
roseblood11
Has thanked: 348 times
Have thanks: 309 times
Postby sego91 » 05 Nov 2017, 16:22
I just finished similar build of a jcm 800
Using this Schematic I ordered some boards. Looks, and sounds, really the same to the Pal 800.
sego91
Have thanks: 8 times
Postby sego91 » 08 Nov 2017, 15:47
Okay I just finished my Build of The JCM 800, using a very similar Schematic to the one of the Pal 800. Basically is the same with some small differences.
The guts, with on board Pors :D
And I'm still having some boards for this project if you are interested
:block:
sego91
Postby Nefi_fatobene » 28 Jan 2018, 02:47
I saw a video on YouTube about the mod #34 prototype for pal 800. Does anyone know how to modify the jcm emulator for a similar sound? Any suggestions?
Nefi_fatobene
Has thanked: 10 times
Have thanks: 5 times
Postby roseblood11 » 28 Jan 2018, 16:09
Is anybody working on a vero board layout?
roseblood11
Postby bmxguitarsbmx » 28 Jan 2018, 22:56
I own and have owned several jcm800's. I had the pal800 in for mods, which I declined to do. I don't see it similar to a jcm800. It was very compressed and reminded me of the pod 2.0 jcm800 model. Yes, it is similar. The real amp is less compressed, much less saturated, and has life. Sorry to be harsh, but it may be a let down. So, heads up. The bsiab2 is 100x better.
For this message the author bmxguitarsbmx has received thanks:
J0K3RX (29 Jan 2018, 05:11)
bmxguitarsbmx
Has thanked: 253 times
Have thanks: 76 times
Postby fuzz_germanium » 05 Sep 2018, 05:44
Manfred wrote:Revised schematic and layout:
jcm2pcb.zip
Hello the pcb board, what measure does it have? nice design!
fuzz_germanium
Postby Manfred » 05 Sep 2018, 23:48
85mm x 40mm.
Users browsing this forum: eipeht, Google [Bot] and 9 guests
