DOD - FX70 Stereo Flanger
Postby TubeDude22 » 18 Feb 2017, 19:06
I have a nice old DOD FX70 Stereo Flanger that uses the MN3007 and MN3101 chips. What I dig about this pedal is that with the regeneration turned all the way down, it has a sweet chorus-like tone. I want to get more of that. Are there any mods I can do to this thing to make it less like a "flanger" and more like a "chorus"?
Schematics are scarce for this but, I've attached what I could find on the web. Thanks for the input.
Reason: renamed and moved thread to Modern Stompbox Dissection
For this message the author TubeDude22 has received thanks:
modman (17 Apr 2018, 15:11)
TubeDude22
Has thanked: 15 times
Have thanks: 16 times
Re: DOD FX70 Flanger - mod to be more chorus like?
Postby Chrisfromiowa » 14 Apr 2018, 16:17
Did you ever figure anything out with this?
Chrisfromiowa
Has thanked: 23 times
Re: DOD - FX70 Stereo Flanger
Postby Gila_Crisis » 20 Apr 2018, 09:00
looking at the schem that 500kohm pot looks like being the regeneration/feedback knob. try working on that 62k resistor. I suppose putting a higher value will limit the feedback signal and give you a more chorus sound. What you could also do/try, it's put a switch to cut that feedback loop.
Gila_Crisis
Have thanks: 65 times
Users browsing this forum: paleojenn and 11 guests
