DOD - FX70 Stereo Flanger
TubeDude22
Has thanked: 16 times
Been thanked: 20 times
Post by TubeDude22 »
I have a nice old DOD FX70 Stereo Flanger that uses the MN3007 and MN3101 chips. What I dig about this pedal is that with the regeneration turned all the way down, it has a sweet chorus-like tone. I want to get more of that. Are there any mods I can do to this thing to make it less like a "flanger" and more like a "chorus"?
Schematics are scarce for this but, I've attached what I could find on the web. Thanks for the input.
FX70 flanger_C.jpg (35.94 KiB) Viewed 1363 times
Reason: renamed and moved thread to Modern Stompbox Dissection
Chrisfromiowa
Has thanked: 22 times
Post by Chrisfromiowa »
Did you ever figure anything out with this?
Gila_Crisis
Been thanked: 124 times
Post by Gila_Crisis »
looking at the schem that 500kohm pot looks like being the regeneration/feedback knob. try working on that 62k resistor. I suppose putting a higher value will limit the feedback signal and give you a more chorus sound. What you could also do/try, it's put a switch to cut that feedback loop.
