Caline - English Man  [schematic]
Postby Manfred » 08 Apr 2017, 10:13
I traced the Caline English Man pedal,
here the schematic of it.
For this message the author Manfred has received thanks: 11
Andy2No (20 May 2018, 10:57), atreidesheir (21 May 2017, 04:19), floris (11 Feb 2018, 12:52), karul (08 Apr 2017, 11:50), mirosol (05 May 2017, 15:09), modman (08 Apr 2017, 23:04), sixthfloor (21 May 2018, 09:50), snofla1900 (08 Apr 2017, 12:19), tbo (14 Oct 2018, 23:11), TubeDude22 (02 Jul 2017, 00:54) and one more user
Manfred
Has thanked: 982 times
Have thanks: 531 times
Re: Caline English Man [Schematic]
Postby Manfred » 08 Apr 2017, 14:23
Oh, I forgot, i made curve traces of the clipping LEDs too.
For this message the author Manfred has received thanks: 5
Andy2No (20 May 2018, 10:59), AuditoryDriving (11 Apr 2017, 06:06), floris (11 Feb 2018, 12:59), microbailey (23 May 2018, 00:04), modman (08 Apr 2017, 23:04)
Manfred
Re: Caline - English Man
Postby mirosol » 05 May 2017, 15:09
So it's a single channel c. martin plexitone. :)
+m
mirosol
Has thanked: 156 times
Have thanks: 361 times
Postby Andy2No » 20 May 2018, 11:07
Thanks, Manfred.
It looks like the TC1044S doubles the supply voltage, so it's permanently 18V internal? Those can be a source of high pitched whine, if things aren't quite right, of course.
I don't see a volume knob, in the schematic. I assume it's a 100K pot, or maybe a 10k pot, across the output?
It would be nice to see some gut shots. I had assumed all of Caline's analog pedals were through-hole, but I see the Red Devil isn't, from mirosol's picture of it:
viewtopic.php?f=1&t=28774
I have modified a couple of pedals built with SMD parts, like that, but it's pushing the limit of what I can do, and I'd far rather work on through-hole ones, like the Orange Burst and Pure Sky.
Andy2No
Has thanked: 153 times
Have thanks: 4 times
Postby Manfred » 20 May 2018, 14:34
You cannot see it, since in that case it is "LEVEL" called.
Andy2No (20 May 2018, 15:26)
Manfred
Postby Andy2No » 20 May 2018, 15:28
Thanks, Manfred.
Calling it Level wasn't the problem - I just missed seeing it all together. I'm so used to seeing a pot across the output, which is a bit half-assed, but seems to be the most common way of doing it.
Andy2No
Users browsing this forum: No registered users and 10 guests
