A BETTER FLANGER - Electronics Today January 1987  [schematic]
Postby Tham » 21 Jun 2017, 05:51
Well, I am being retrenched from my job after over twenty years.
So while packing up my considerable belongings (like moving house, really), I happened to find this 30-year old Electronics Today International magazine still at the bottom of my side chair.
Looks like a pretty good design. Based on the TDA1022.
It seems the TDA1022 has quite high distortion and a low noise replacement is the MN3004 or SAD512.
For this message the author Tham has received thanks: 6
bossman (22 Jun 2017, 21:10), deltafred (21 Jun 2017, 08:54), Fender3D (29 Jun 2017, 15:04), Manfred (21 Jun 2017, 07:06), modman (21 Jun 2017, 09:03), teddeeh (06 Jul 2017, 10:49)
Tham
Have thanks: 13 times
Re: A BETTER FLANGER - Electronics Today January 1987
Postby Tham » 13 Jul 2017, 05:01
Does anyone know if there are direct pin-for-pin substitutes
for the TDA 1022 ?
TDA 1022 is a 16-pin IC while MN 3004 is 14-pin, and
SAD 512 is an 8-pin chip, and their pin layouts are different.
Tham
Postby uncleboko » 13 Jul 2017, 07:16
Tham wrote:Does anyone know if there are direct pin-for-pin substitutes
for the TDA 1022 ?
No there are not, only TDA 1022 will do unless you have a............. (temp memory loss!) - you know what it's called - an adapter board I think!
I adapted this for SAD 1024 but never kept the details.
uncleboko
Has thanked: 48 times
Have thanks: 17 times
Postby uncleboko » 13 Jul 2017, 07:24
To run a TDA 1022 off 5 volts is disappointingly noisy and will have little headroom. I would have used 2 x 9v batteries to give it more beef!
uncleboko
Postby Dirk_Hendrik » 13 Jul 2017, 08:05
Why "adapt"? The TDA1022 is one of the few BBD's that is rather easy to source.
Has thanked: 246 times
Have thanks: 977 times
Postby uncleboko » 13 Jul 2017, 16:40
Dirk_Hendrik wrote:Why "adapt"? The TDA1022 is one of the few BBD's that is rather easy to source.
And it's good for the brain to adapt. I much prefer shorter delay of SAD 1024. A Hoax Flanger would be interesting with SAD 1024s.
uncleboko
Postby Fender3D » 13 Jul 2017, 17:20
SAD1024 has not a shorter delay.
you may set it up to half chip or parallel-mux to have the same "buckets" as TDA1022. Otherwise it is a ...1024 stages BBD.
Parallel-mux will have a better resolution though....
Fender3D
Has thanked: 93 times
Have thanks: 121 times
Postby Fender3D » 13 Jul 2017, 17:24
BTW
unless you have a reasonable cache of SAD chips (and you'd better keep very secret your address, in this case...)
I wouldn't waste a SAD1024 for a magazine project, I'd keep it for "vintage" repair or EBay
Fender3D
Postby uncleboko » 13 Jul 2017, 18:29
Fender3D wrote:SAD1024 has not a shorter delay.
I thank innit!!!
uncleboko
Postby uncleboko » 13 Jul 2017, 18:46
Ah but you can clock SAD 1024 considerably higher than TDA 1022, especially if double buffered by a couple of 4049 inverter arrays. So minimum delay is in the microseconds range, so a converted Flanger Hoax may benefit!!
uncleboko
Postby uncleboko » 16 Jul 2017, 12:03
I found Philips' modifications for lower noise operation of the TDA 1022!
uncleboko
Postby uncleboko » 17 Jul 2017, 17:57
No luck with EH Flanger Hoax schematic, obviously kept very hidden!
uncleboko
Users browsing this forum: Bing [Bot], SAMBER_DINO, Yahoo [Bot] and 11 guests
