Budda - Om Overdrive  [schematic]
Postby Frabbio » 09 Oct 2017, 11:37
I traced this unit a couple years ago, i took some photos at the time but i can't find them anymore.
T1 is a BC547, the Jfet is a J201 and the Opamp is LF353.
For this message the author Frabbio has received thanks: 8
287m (09 Oct 2017, 11:45), dv8r601 (10 Oct 2017, 23:10), Intripped (09 Oct 2017, 12:59), Manfred (09 Oct 2017, 18:23), mirosol (09 Oct 2017, 15:18), modman (01 Jan 2018, 16:38), TWAlex (11 Oct 2017, 22:55), Zokk (09 Oct 2017, 12:18)
Frabbio
Has thanked: 10 times
Have thanks: 76 times
Re: Budda Om Overdrive
Postby Frabbio » 09 Oct 2017, 13:50
I found the photos, there is a mod i did after tracing the pedal, adding a RC filter by cutting a trace and upping the stock 2.2uF filter capacitor.
In the hand drawn schematic part names are as in the pedal.
For this message the author Frabbio has received thanks: 6
dv8r601 (10 Oct 2017, 23:10), Intripped (11 Oct 2017, 00:43), Manfred (09 Oct 2017, 18:23), modman (01 Jan 2018, 16:38), okgb (09 Oct 2017, 16:31), roseblood11 (09 Oct 2017, 16:54)
Frabbio
Postby roseblood11 » 09 Oct 2017, 16:55
Have you built a clone based on that schematic?
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby Frabbio » 09 Oct 2017, 17:24
No I haven't, but it's a good sounding overdrive, i remember i did some mods also on the eq of the pedal to make it more full sounding.
Frabbio
Postby dv8r601 » 10 Oct 2017, 23:12
Thanks for this.
Ill try and whip it up and see if it works as is.
dv8r601
Has thanked: 397 times
Have thanks: 18 times
Postby JRombold » 26 Dec 2017, 23:24
Thanks for the great work on this. I had a couple questions about the caps on the board as compared to the schematic. C9, C10 and C11 mainly in comparison from board to schematic. Reason I ask Is I built this and the voice of the drive is killer but over is really bright and noisy. C10 schematic shows a 2.2uf on the board it looks like a standard cap. C11 I can't find on the schematic (could be me....I am blind as a bat). C9 on the schematic shows 2.2uf on the board is 5.6n. C6 on the board I am guessing is 1uf but c6 on the schematic is the 5.6n
Thanks for any help on this.
Sorry if this is a ridiculous question.
Thanks again for all the great work!
Dirty
For this message the author JRombold has received thanks:
modman (01 Jan 2018, 16:39)
JRombold
Postby Frabbio » 27 Dec 2017, 03:44
The hand written schematic in the second post shows the component name as in the pedal!
JRombold (27 Dec 2017, 05:23)
Frabbio
Postby Manfred » 28 Dec 2017, 19:31
I would very much appreciate it if you could measure the voltages at the transistor pins and give us the read values.
Which gain class has the BC547 A, B, or C?
Manfred
Has thanked: 987 times
Have thanks: 533 times
Postby Frabbio » 28 Dec 2017, 20:51
I am sorry but i don't have the pedal anymore. IIRC the transistor was a Bc547C.
Manfred (28 Dec 2017, 22:28)
Frabbio
Postby Manfred » 31 Dec 2017, 17:32
Frabbio wrote:I am sorry but i don't have the pedal anymore. IIRC the transistor was a Bc547C.
Thanks, I found the read values on this website:
http://runoffgroove.com/mayqueen.html
The OM overdrive is derived from the May Queen overdrive.
For this message the author Manfred has received thanks: 4
B Tremblay (01 Jan 2018, 22:02), dv8r601 (01 Jan 2018, 20:56), Frabbio (06 Jan 2018, 04:42), modman (01 Jan 2018, 16:40)
Manfred
Re: Budda - Om Overdrive
Postby dv8r601 » 15 Jan 2018, 18:03
Well I KNEW I'd seen this odd arrangement somewhere. Its a Escobedo punch in the face betwixt the two opamp stages. Well Lo and behold its a damn near exact copy of the wonderful Carl Martin Crush Zone Image
dv8r601
Postby Manfred » 15 Jan 2018, 23:09
Haha, I am hettin old, I do believe it. :?
I totaly completely forgot, I did trace the Martin Crushzone on my own. :shock:
http://freestompboxes.org/viewtopic.php?f=7&t=28021&hilit=crush+zone
Manfred
Postby Manfred » 15 Jan 2018, 23:19
Manfred wrote:Haha, I am hettin old, I do believe it. :?
The edit buttom did not work once again :evil:
I meant mean of course:
Haha, I am getting old, I do believe it. :?
Manfred
Postby Manfred » 15 Jan 2018, 23:30
I give up ,a further write error. :slap:
I should think about to use the preview function. :scratch:
Manfred
Postby Frank_NH » 16 Jan 2018, 16:59
I thought the Crushzone sounded pretty good, as does this. Too bad Budda didn't add something interesting to the design like 3 band EQ, rather than just producing a straight clone.
Frank_NH
Has thanked: 18 times
Have thanks: 67 times
Postby dv8r601 » 16 Jan 2018, 19:34
I built a crush zone off Tagboardfx a while back and noticed the input cap at 220pf was WAY smaller than anything I've ever used so I swapped it out for a 8.2nf and it was slamming. Then put a hot 2n5485 in the fet socket and its been on my board ever since. Now knowing what the om is I wonder if their compressor is a clone as its quite weird as well
dv8r601
Users browsing this forum: efe and 17 guests
