Boss OD20 and Fender Chorus competition series
Postby Akman » 04 Nov 2017, 13:30
Hi guys,
I would like some assistance with a mod that will help bring out the lower frequencies, mid range/lower midrange which these two pedals seem to block. They both are a bit thin sounding. Does anyone know what parts I could change and what I can replace them with to bring out a fuller warmer tone and wider range range of frequencies that is already in my clean tone. These pedals kind of remind me of what DS1s and metal zones do to ones dry tone.
My chorus has a mix knob that I like to turn way up- unfortunately it starts to suck up all the natural low end.
Thanks so much I’m new
Akman
Re: Boss OD20 and Fender Chorus competition series
Postby Nocentelli » 04 Nov 2017, 15:14
OD20 is a digital modelling effect: I think it probably has no parts you could change to alter the tone.
mmolteratx wrote:absolutely zero commercial use allowed. If I find anyone selling these, I'll fly to your house and kick you in the nads. And you may or may not find yourself in trouble.
Nocentelli
Has thanked: 850 times
Have thanks: 831 times
Postby Akman » 04 Nov 2017, 17:53
Yep, I’m not talking about changing each digital preset.
The pedal itself has a seperate tone knob, level , Drive etc which you can adjust , so I’m sure one can adjust those knobs especially the tone dial to bring out more low end and midrange.
Akman
Postby Nocentelli » 04 Nov 2017, 19:48
Can you save the tone setting alongside all the other parameters within the drive sound? Manual suggests you can. This makes me think the tone is manipulated within the digital domain cannot be globally altered by changing a couple of caps.
Nocentelli
Postby Akman » 05 Nov 2017, 16:24
Hmmm I’ll have to check that. But anyway with regards to my chorus pedal, there are theee knobs: depth, speed and mix. I like the mix knob cranked up but by doing so it thins the sound, removes lower natural frequencies and increases some gain and compression(tightens the sound) . What could I do to let in more bass warmth and natural openness?
Akman
Users browsing this forum: Ichabod_Crane, Stenca and 9 guests
