Caline CP-11 Puffer Fuzz  [schematic]
Postby mirosol » 08 Nov 2017, 20:40
Someone on this forum suggested this might be a Fooltone '70 clone and as these sell for peanuts, i wanted to try one. Came in the mail today. Fooltone '70 - bullshit. It's a basic Si FF with rheostat in front of it. Sounds horrible. To call this abysmal would be a praise. Highly moddable, but still. Surely worth 20€ shipped, but still.
BOM (designations per original board):
Rx 100R (trace cut and added post design, most likely to cure possible oscillation)
R1 47K
R5 1M
R6 100K
R7 22K
R8 4K7
R9 4K7
C1 4µ7/50V
C3 220n/100V panasonic
C4 22µ/50V
D1 1N4001
Q2 2N3904
Q3 2N3904
Fuzz B2K
Tone B100K
Level A100K
For this message the author mirosol has received thanks: 7
Andy2No (19 May 2018, 21:24), dv8r601 (18 Nov 2017, 05:49), Manfred (09 Nov 2017, 23:32), modman (10 Nov 2017, 12:01), smurfberry (11 Jan 2018, 03:11), tbo (05 Jan 2018, 20:14), tp801 (09 Nov 2017, 21:15)
mirosol
Has thanked: 155 times
Have thanks: 359 times
Re: Caline CP-11 Puffer Fuzz
Postby mirosol » 09 Nov 2017, 20:00
Modded mine.
-Transistors to MP38A (hFE 78 and 91)
-R1 to 33K
-R7 to 10K (trimmed on breadboard to find good bias setting)
-R8 to 470R
-Shorted Rx
-Added 2k2 between fuzz pot pins 2&3
-C1 to 10n
-Cut trace between Tone pot's lug 1 and C1
-Shorted Tone Pot's lugs 2&3 with C1
-Added 2µ2 between Tone pot's lug 1 and C1
Basically swapped the transistors for a pair of nice old russian NPN germaniums, changed resistors per classic fuzz face values (setting the bias by ear) and tweaked the idiotic "Tone" pot to act as input cap blend. Pretty nice sounding pedal and quite usable now.
lolbou (12 Nov 2017, 22:53)
mirosol
Postby blackcorvo » 17 Jan 2018, 19:57
Hello, I purchased one of these the other day, and it sounded awlful! So, after checking this topic, I made some changes of my own:
https://cdn.discordapp.com/attachments/ ... 012332.jpg
https://cdn.discordapp.com/attachments/ ... nknown.png
Here's what it sounded before:
https://cdn.discordapp.com/attachments/ ... Before.mp3
and now after:
https://cdn.discordapp.com/attachments/ ... _After.mp3
I only forgot to put the 100pF capacitor between the Base and Collector of the first transistor in the schematic. It both cuts out the oscillation of the circuit at high gains, and smooths the treble a little. You might want to play with the value to reach the type of sound you're looking for, but I do recommend adding that capacitor for a more stable circuit!
For this message the author blackcorvo has received thanks: 2
Andy2No (19 May 2018, 21:25), modman (19 Jan 2018, 09:25)
blackcorvo
Have thanks: 16 times
Postby blackcorvo » 19 Jan 2018, 04:09
After a little more fiddling, I ended up returning the 22k Collector resistor into place, and replacing the 4k7 resistor with a 560R one, which really make the circuit sound like a classic Fuzz. Everything is staying in place, but I'm arguing, with myself if I should change the blue LED with some other color.
Peamiller (05 Jul 2018, 18:18)
blackcorvo
Postby Peamiller » 05 Jul 2018, 18:20
blackcorvo wrote:After a little more fiddling, I ended up returning the 22k Collector resistor into place, and replacing the 4k7 resistor with a 560R one, which really make the circuit sound like a classic Fuzz. Everything is staying in place, but I'm arguing, with myself if I should change the blue LED with some other color.
Hey, thanks for posting those before & after clips. I got one of these on the way and always had a mod in mind, I'm going to start off with the changes you've made and go from there, will report back if I come across any interesting variations.
Peamiller
Have thanks: 12 times
Postby thejoneslad » 12 Nov 2018, 22:45
blackcorvo wrote:Hello, I purchased one of these the other day, and it sounded awlful! So, after checking this topic, I made some changes of my own:
and now after:
Thanks for the schematic and mods. Bought a puffer to do my first mods on, so these will come in handy. One question though: What do the 100 uf and 10nf capacitors do?
thejoneslad
Users browsing this forum: naan and 13 guests
cron
