Joyo PowerSupply 2 schematic  [schematic]
Postby apollomusicservice » 09 Nov 2017, 19:55
From the Joyo's review it's isolated.
For this message the author apollomusicservice has received thanks: 6
Fredenando (13 Nov 2017, 09:07), Manfred (09 Nov 2017, 23:31), mirosol (09 Nov 2017, 20:03), modman (10 Nov 2017, 11:58), mr coffee (29 Nov 2017, 13:18), nr372 (10 Nov 2017, 03:20)
apollomusicservice
Has thanked: 65 times
Have thanks: 766 times
Re: Joyo PowerSupply 2 schematic
Postby plush » 09 Nov 2017, 20:01
apollomusicservice wrote:From the Joyo's review it's isolated.
Turns out it is not.
Nothing surprising.
plush
Has thanked: 22 times
Have thanks: 34 times
Postby Ice-9 » 10 Nov 2017, 02:53
Nothing surprising.
well that's no surprise is it. they use the wording 'isolated outputs' to mean separate output connectors and not actual isolated outputs. It is a bad play on wording.
For this message the author Ice-9 has received thanks:
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby Ice-9 » 10 Nov 2017, 03:03
to be fair only sellers describe it as isolated outputs and the joyo website describe it as short circuit isolated on individual outputs. two complete different meanings
JudgeMingus (10 Nov 2017, 03:14)
Ice-9
Postby apollomusicservice » 10 Nov 2017, 07:40
Ice-9 wrote:to be fair only sellers describe it as isolated outputs and the joyo website describe it as short circuit isolated on individual outputs. two complete different meanings
On the Joyo's original box the first sentence is: Ten isolated output.
apollomusicservice
Postby Ice-9 » 11 Nov 2017, 20:51
so even joyo describe it differently on the box and in other blurb. Does anyone fancy a forum project with real isolated outputs ? I might do one if anyone is interested.
hyrk (12 Nov 2017, 11:04)
Ice-9
Postby 287m » 11 Nov 2017, 21:27
Yes, please.
287m
Has thanked: 305 times
Have thanks: 56 times
Postby krome_magnon » 11 Nov 2017, 23:20
Ice-9 wrote:Does anyone fancy a forum project with real isolated outputs ? I might do one if anyone is interested.
Oh yes!
I can't imagine how it's done without individual taps off a transformer into normal linear regulator ICs. Would love to know how to do it.
The noise from the tape deck was only drowned out by the buzz from the wine.
krome_magnon
Have thanks: 18 times
Postby Frabbio » 12 Nov 2017, 15:12
Is it possible to have several isolated outputs starting from a single power supply using PWM ICs like the SG3525, give a look here.
http://www.aresaudio.com/stomps-power-supply.html
For this message the author Frabbio has received thanks:
68pedals (09 Mar 2018, 10:55)
Frabbio
Has thanked: 10 times
Have thanks: 76 times
Postby apollomusicservice » 12 Nov 2017, 16:30
Frabbio wrote:Is it possible to have several isolated outputs starting from a single power supply using PWM ICs like the SG3525, give a look here.
Supply with switching technology and half-wave rectification, I don't think that it's good solution for audio equipment.
apollomusicservice
Postby Frabbio » 12 Nov 2017, 16:51
It should work around 30khz switching frequency , bu eventually one can modify it to run on higher frequencies, i don't think it will cause any audio interferences.
Of course a classic linear power supply is better for audio, but it will need a secondary for each output.
Frabbio
Postby howmuch » 13 Nov 2017, 15:09
FYI
A very good value-for-money isolated power supply is the Harley Benton PowerPlant Junior (not the bigger one).
Outwardly, it looks similar to the T-Rex Fuel Tank Junior.
The gutshots here show that it has 5 secondary transformer taps, each with their own bridge rectifier and regulator.
It's odd that while most Harley Benton pedals are rebadged Joyos, Joyo don't make this power supply.
Now back to the DIY talk...
howmuch
Have thanks: 20 times
Postby Ice-9 » 13 Nov 2017, 18:45
I have had a quick look at what I think would be the most cost effective way to design an isolated PSU, it is using the small 'Block' transformers that have 2 completely separate secondaries per transformer which will allow for 2 outputs per Tx. I haven't bought any transformers yet to try out and the ones shown in the 3d render are just examples. I will need to select suitable TX's and then look at the correct dimensions for the PCB.
The PCB I have layed out as an example has 4 isolated 9v DC outputs with 100mA regulators and 2 9v DC outputs using TO220 1amp regulators . The PCB so far can be expanded easily just buy duplicating each section of two outputs.
As I say though, so far this is just an example of type and layout.
hyrk (13 Nov 2017, 19:53)
Ice-9
Postby Ice-9 » 13 Nov 2017, 18:59
sorry picture did not post correctly above, so I will try again.
287m (13 Nov 2017, 22:56)
Ice-9
Postby camljenkins94 » 14 Nov 2017, 05:31
Oh, it is isolated, let me show you! *proceeds to blow all of the fuses in it* See, every output is now completely isolated!
camljenkins94
Have thanks: 11 times
Postby krome_magnon » 22 Nov 2017, 14:57
So, what technology would the Gig Rig Isolator be using?
https://shop.thegigrig.com/isolator/
Obviously not a multiple secondary transformer.
krome_magnon
Postby marshmellow » 24 Nov 2017, 11:35
There are isolated DC-DC topologies that use transformers which are much smaller compared to the transformer in a standard AC supply. Could be that, or they are just as generous with the term isolated as Joyo.
marshmellow
Have thanks: 122 times
Postby alblupo » 24 Nov 2017, 13:18
Ice-9 wrote:sorry picture did not post correctly above, so I will try again.
[ Image ]
I agree. A friend of mine design a modular power supply following that approach. You can have a power bus, and than attach modules that has a transformer and one or two outputs. Accordint to the wiring and the transformer you can get the different voltages and currents you need.
alblupo
Postby plush » 24 Nov 2017, 17:06
marshmellow wrote:There are isolated DC-DC topologies that use transformers which are much smaller compared to the transformer in a standard AC supply. Could be that, or they are just as generous with the term isolated as Joyo.
You can't isolate DC from DC via transformer. Transformers work only with ac. Since this isolator runs on DC, it's based on pure bullshit.
plush
Postby lietuvis » 24 Nov 2017, 17:18
https://power.murata.com/en/nmk1209sc.html
lietuvis
Has thanked: 84 times
Have thanks: 58 times
Next
Users browsing this forum: lietuvis and 14 guests
