Caline CP-22 Purple Smoke Clean Boost
Postby mirosol » 29 Nov 2017, 18:54
Got mine in the mail today. Tried it out and it sounded like there was a bit too much low cut for my taste. Figured that this won't be all that big of an issue, so i fixed mine by replacing the 1µ bypass cap with 47µ. Sure, the "clean" isn't there anymore when the gain pot is maxed. I do find this quite usable with this one cap replaced. The 4k7 in parallel with the level pot is somewhat stupid solution. 5k log pot would have sufficed. Mine didn't have a battery snap, but the pedal came with a battery adapter for standard barrel plug. This circuit, like most of the Calines i've seen, are nicely build cheapos that are easy to mod. This one could be turned into a "Channel 2" with minimal effort. One would just replace the transistor for a MOSFET, short the bypass cap, add 8M2 from gate to ground and a zener from source to gate. Also one would need to tweak the value of that 22k. Nevertheless, it would be rather easy to do. I do like mine as it is, with one cap upped. Didn't bother with the bypass switching or the LED for the schematic drawing.
For this message the author mirosol has received thanks: 2
dv8r601 (29 Nov 2017, 23:04), Manfred (29 Nov 2017, 20:26)
mirosol
Has thanked: 153 times
Have thanks: 357 times
Re: Caline CP-22 Purple Smoke Clean Boost
Postby mirosol » 29 Nov 2017, 19:05
Grah. Got couple of the designations wrong. Fixed.
For this message the author mirosol has received thanks: 3
dv8r601 (29 Nov 2017, 23:06), storyboardist (30 Nov 2017, 19:53), tbo (03 Jan 2018, 00:33)
mirosol
Users browsing this forum: No registered users and 10 guests
