Ibanez BPL Bi-Stage Phaser and Ibanez PH10 Bi-Mode Phaser
Postby floris » 06 Feb 2018, 19:48
I have both Ibanez Phasers currently opened up, saw no topic on these pedals, so I took some pictures.
The Ibanez BPL Bi-Stage Phaser and Ibanez PH10 Bi-Mode Phaser have the same circuit and PCB.
Only the potentiometer types are different, values are the same.
Schematic:
Ibanez BPL Phaser
Ibanez PH10 Phaser
floris
Has thanked: 171 times
Have thanks: 55 times
Re: Ibanez BPL Bi-Stage Phaser and Ibanez PH10 Bi-Mode Phase
Postby floris » 06 Feb 2018, 19:56
Picts of the Ibanez PH10 Phaser PCB:
floris
Postby floris » 06 Feb 2018, 20:02
After adjusting the Width trim-pot, VR4 1k Ohm, I found that the maximum range of the Width could be a bit larger so that the Phaser can "move" from more low to more high.
For this I changed R66 82k Ohm resistor, that is in series with the Width pot, on the potentiometer PCB that holds the LFO, into a 62k Ohm resistor.
Then I adjusted the Width trim-pot again.
For this message the author floris has received thanks:
puppiesonacid (21 May 2018, 01:55)
floris
Users browsing this forum: Google [Bot], GrammaRed, pedalpimps, Serge75 and 8 guests
