Boss GE-7 Problems
Boss GE-7 Problems
Postby Stevenrb718 » 09 Mar 2018, 21:16
Hey! I have a Boss GE-7 that has a couple issues I'm trying to get straightened out. Firstly, the pedal only works with a power adapter, and does not work with a battery. Also, the LED doesn't light regardless of battery or power supply use. The LED has been swapped and that didn't correct the issue either. The pedal is one of the older ACA adapter pedals. Any help would be great!
Stevenrb718
Re: Boss GE-7 Problems
Postby alexradium » 10 Mar 2018, 14:14
you should update it for modern supplies first,because it was designed for 9vac and 12vdc,then report back for more troubleshooting
http://stinkfoot.se/archives/1019
alexradium
Has thanked: 53 times
Have thanks: 60 times
Postby Stevenrb718 » 10 Mar 2018, 23:33
I swapped the 2 components to jumpers...same symptoms. Doesn't work with a battery, only works with a power adapter, and the LED never works. I never tried the unit with a 9v power adapter before, only a 12v one when it worked before conversion.
Stevenrb718
Postby Manfred » 11 Mar 2018, 00:02
I guess the DC-Jack is defektive, the switch in it do not close correctly any longer or a solder joint is broken.
Manfred
Has thanked: 990 times
Have thanks: 542 times
Postby Stevenrb718 » 11 Mar 2018, 05:57
What about the new LED not working?
Stevenrb718
Postby Manfred » 11 Mar 2018, 09:22
A had look at PCB-shots.
The LED is monted on the slider pots PCB too.
Check the flat cable including its solder points.
Manfred
Users browsing this forum: Google [Bot] and 12 guests
