Fuses as clippers?
Fuses as clippers?
Postby FloPoeKo » 16 Sep 2018, 20:46
I heard a weird rumor that some pedals employ glass-fuses as clippers instead of diodes and transistors...
Does anyone know anything specific? Schematics? Pics?
Cheers, Florian
FloPoeKo
Has thanked: 25 times
Have thanks: 45 times
Re: Fuses as clippers?
Postby plush » 16 Sep 2018, 21:13
Yeah, they clip under high load...
But only once.
plush
Has thanked: 24 times
Have thanks: 39 times
Postby FiveseveN » 16 Sep 2018, 22:02
I guess you can use a diode for a fuse, kinda, but you definitely can't use a fuse as a diode.
FiveseveN
Has thanked: 127 times
Have thanks: 50 times
Postby Fender3D » 17 Sep 2018, 00:05
The same as you can tune a piano but you can't tuna fish...
For this message the author Fender3D has received thanks:
sixthfloor (20 Sep 2018, 10:09)
Fender3D
Has thanked: 97 times
Have thanks: 131 times
Postby phatt » 17 Sep 2018, 02:46
Yeah I wanted to use reverse wound diodes but could not find any. :mrgreen:
Phil.
phatt
Have thanks: 266 times
Postby Zokk » 17 Sep 2018, 16:54
It's probably more efficient to use fuses as jumpers 8)
Zokk
Has thanked: 178 times
Have thanks: 62 times
Postby Ice-9 » 19 Sep 2018, 21:42
I'm going to guess someone just say some glass germanium diodes and confused them with fuses. :slap:
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Users browsing this forum: bnm, roberttomasz and 10 guests
