Roland Jet Phase incoming!
Posted: 07 Jun 2019, 17:01
by chicago_mike
I have a Roland JetPhase AP-7 coming in the mail today. Does anybody need any measurements or anything from it?
Re: Roland Jet Phase incoming!
Posted: 09 Aug 2019, 02:43
by aion
I would love to get the specs of the matched JFETs! Vgs(10k), Vgs(off) and Idss if you’re able. I’m curious to see how the voltages match up with something more common
    like the Phase 90. I saw some taken from a unit awhile ago that were in the 0.7-0.8v range, which seemed really low to me - so I’m wondering if that was an anomaly or pretty standard.
    Posted: 09 Aug 2019, 09:32
    by modman
    We have a thread on the Roland Jet Phaser here: https://www.freestompboxes.org/viewtopic.php?f=1&t=589
    Links to service notes etc...most of the links to guts are dead though...
    Posted: 18 Aug 2019, 00:05
    by chicago_mike
    aionios wrote:I would love to get the specs of the matched JFETs! Vgs(10k), Vgs(off) and Idss if you’re able. I’m curious to see how the voltages match up with something more common
      Im cool with helping out!! Whats the easiest way to measure the fets ?
      Posted: 18 Aug 2019, 13:19
      by aion
      The Vgs(10k) measurement is the most important one for phasers - there's a super simple circuit here that could be breadboarded:
      http://www.geofex.com/article_folders/f ... tmatch.htm
      Vgs(off) (which is basically the same as Vp) and Idss can be taken with another circuit:
      http://tagboardeffects.blogspot.com/201 ... tcher.html
      (The 2nd one on this page is much simpler and should work the same)
      Posted: 18 Aug 2019, 14:45
      by chicago_mike
      Cool.
      I should test ALL fets in the phase section yes? Not just like 2 - 4 ?
      Posted: 18 Aug 2019, 18:37
      by aion
      chicago_mike wrote:I should test ALL fets in the phase section yes? Not just like 2 - 4 ?
      Yep. An average Vgs is helpful, but also knowing the spread of lowest to highest, to know what Roland considered to be matched well enough for the circuit.
      MXR was satisfied with up to 0.1V for the Phase 90, which is pretty wide, but matching 8 JFETs instead of 4 is even trickier so I’m curious if it’s tighter or broader than that.
      Posted: 22 Aug 2019, 16:09
      by chicago_mike
      breadboarding an Arduino fet tester for this. Should have the jets testedasap!
      Posted: 23 Aug 2019, 11:05
      by aion
      chicago_mike wrote:breadboarding an Arduino fet tester for this. Should have the jets testedasap!
      Oh awesome! Which one is it?
      Posted: 23 Aug 2019, 22:53
      by chicago_mike
      this one:
      https://create.arduino.cc/projecthub/pl ... ter-dbafb4
      I didnt really know there were others :hmmm:
      Posted: 03 Sep 2019, 18:20
      by chicago_mike
      Okay I posted my initial FET measurements. Only for the 8 phasing FETS right now.
      When I get more time, I take measurements of the other fets
